Question about HP LaserJet 3300mfp All-In-One Printer
HP 3300 THE PRINTER SAYS"MISPICK" PRESS ENTER TO RESUME. I PRESS ENTER AND IT SAYS READY..THEN IT GOES BACK TO MISPICK PRESS ENTER TO RESUME
  • Anonymous May 29, 2008
    hp 3030 document jam read
    Sergeant:
  • 329 Answers
Remove paper tray open door remove cartridge. In the middle of machine you will see a small gray rubber pick up wheel. clean the rubber with cleaner such as windex, water, etc. Put everything back together, run several test ( Wheel may still have cleaner on it) If after several test see if paper picks up and goes into the machine. If it does, then most likely you need a new pick up wheel, not an expensive job. If it does not help your problem there is also a seperation pad under this wheel that may need change, or you have other problems such as a switch or boards. Good Luck............
Posted on Jul 25, 2008
You have a piece of paper that is stuck. take all papers out and visually check find and pull out piece or sheet of paper.
Posted on Dec 17, 2007
  • 944 Answers
This procedure is described relating to a different error, but it resets and clears everything and would be worth a try http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=66359&prodTypeId=18972&prodSeriesId=66359&objectID=bpl10206 hp says for your specific error: "Reload the paper in the paper input tray; verify that there are no jams in the paper path, and press MENU/ENTER to continue the job. If the error persists, replace the printer pickup roller. Check paper path, including rear output door for jams, fuser area, and under the print (toner) cartridge." here is the complete guide to all the above http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=66359&prodTypeId=18972&prodSeriesId=66359&objectID=bpl11283 ask again if you need more Hope this helps :)
Posted on Mar 08, 2007
HP Deskjet 1280 Does not Switch On - only flashes the ON light for One second
you should reset the printer .
press resume button 3 second. release the resume button .May be your printer ready.
Feb 27, 2014 | HP DeskJet 1280 InkJet Printer
Cannot print printer is set offline and resume light is blinking
Press the resume button and then your printer will start printing one page... after all your printer is ready to use... Thank you
Aug 23, 2011 | HP Deskjet D4260 Printer
Hp laserjet 9050n appear disk not initialized .how to solve. thank you.
Turn off printer
Press and hold PAUSE/RESUME(START on MFP)
Turn on printer
Keep holding the PAUSE/RESUME or START until all 3 error lights light
Release the buttons
Press LEFT ARROW(5 button on MFP) until INITIALIZE DISKS appear
Press the CHECK(6 button on MFP)
Wait for printer to READY
May 11, 2011 | HP LaserJet 9050 Printer
"printer mispick enter to resume"is
replace pick up rollers and or the whole pick up assembly
Dec 25, 2010 | HP LaserJet 3330 All-In-One Printer
Message: Printer Mispick.[Enter] To Resume
Sounds like the pick up rollers are not pulling the paper in. Try cleaning them or replace if they look worn. When I try to examine all the parts you can find some small piece of paper caught in somewhere around.
Thank you!
May 18, 2010 | HP LaserJet 3330 All-In-One Printer
Problems with hp laserjet 3330
suspect either worn ADF(automatic document feeder) pickup roller or there is a jam in the ADF unit where the paper feeds to the scanner.
Mar 11, 2010 | HP LaserJet 3330 All-In-One Printer
Printer mispick
Hi ,
The print engine has failed to pick up a piece of media.There is a paper jam in the printer's paper path. Reload the paper in the paper input tray; verify that there are no jams in the paper path, and press MENU/ENTER to continue the job. If the error persists, replace the printer pickup roller. Check paper path, including rear output door for jams, fuser area, and under the print (toner) cartridge.
Feb 10, 2010 | HP LaserJet 3330 All-In-One Printer
I have a HP 3300 photosmart printer, have an error code that says 0xc18a0507?? i cant print or anything..
Try doing a reset by holding down the * and Menu/Enter keys while plugging in the unit, hold the keys down until the screen says that it is resetting.
The 3300 also has a "Secret Menu" that can be accessed by;
To View The Secret Menu:
1: Press Both The Left And Right Navigation Arrow Keys
2: It Will Ask You To "Enter A Special Key Combo.", Enter "123" (Without Quotes)
3: You Should Be In The Secret Menu Now.
P.S. Use The Arrow Keys To Navigate.
The manual can be found at;
http://www.fixyourownprinter.com/reference/manuals/public/hp
Hope this helps!
Dec 09, 2009 | HP LaserJet 3300 All-In-One Printer
Printer error as stated "Printer Mispick [Enter] to resume." There was a mispick but that was corrected; however the error message is constant.
Hi:
I own a HP Laserjet 3330, and usually all that it takes to fix this problem is cleaning off the paper pick up roller with a damp cloth.
It is having trouble picking up the paper sheets, and you will get the error time after time. It seems that the recycled paper is worse than others. Remember to use a cloth dampened with only water, as other cleaners will dry out the pick up roller
Oct 26, 2009 | HP LaserJet 3330 All-In-One Printer
Error 59.90
Firmware error, try perform a cold reset on the printer.
Turn off and on the powerswitch, when printer start count memory press enter button until select language came up in display, release the enter button, use the arrow until cold reset is displayed, press enter and the printer will reboot. When the printer goes to ready upgrade firmware on it.
Dec 08, 2008 | HP LaserJet 5550DN Printer
HP LaserJet 3300mfp All-In-One Printer Logo
562 people viewed this question
Clive
Clive
