Vokera 28 linea boiler cuts out intermitently. 04 Error code
Hiya,
I have a Vokera 28 linea boiler which cuts out intermitently. 04 Error code shows & a red light flashes. The Bar Gauge is at 0. Please help as I have called loads of service companies but they are all booked until after Christmas!
4 Suggested Answers
  • 4 Answers
SOURCE: my vokera linea 7 boiler
The pipe you call over flow. This would be the P/R valve and is set to relieve pressure in system. The first thing that needs to be checked - the expansion tank two types of tanks one would be what is know as a extrol tank, Most likey just hanging off pipe, it has air pressure on one side of rubber dia. and boiler water on other. The 2nd type is just a tank at ceiling height (most of the time). You would see a hose bib off the one end. Tank holds some water but must have air for boiler water to push into as it is heated. If you have the first tank it should be replaced. The 2nd type needs to be drained of all water. Shut off feed line to tank hook up short hose and drain into a bucket. if water stops you must break the vacuum raise hose above tank air should go into tank. repete draining till all water is out of tank. Some tanks have a way to open a valve to let air in as you drain if so use it. When all water is out of tank valve off everything (no air should leave tank) Open back up to system now you should have aplace for the water to expained to.
Posted on Nov 06, 2008
PSITECHNICAL
  • 71 Answers
SOURCE: No heating and no hot water, my boiler won't fire up
If there is a hi-limit switch, maybe it's open, reset the switch, and monitor the temperature, if the temp. increases over the set temp. replace stat, and clean lime off from the tank, if does not have a filtering system
Posted on Apr 21, 2009
hvac1960
  • 2133 Answers
SOURCE: Vokera 24/28 Europa Combi Boiler Water
Check sensor whether fix in proper place.
Posted on Dec 02, 2010
Vokera boiler problems
need to change thermostat and a thermocouple
Jan 28, 2014 | Water Heaters
Boiler cuts off after abt 20 secs of igniting,hot water goes cold then reignites ,hot water for 15-20 secs then repeat goes cold, burner goes off then rignites...ect was told ntc thermister problem but...
Yes usually it is indeed the thermostat, or Thermistor, all part of the control circuit. You did not indicate what type of setup you have. I suggest you Google for a thing called a service manual. This will aid in diagnosis, and repair of your system.
Mar 29, 2010 | Heating & Cooling
How do you reset the vokera boiler
where is the reset button on a linea 24
Jan 09, 2010 | Heating & Cooling
I have a vokera unica 28 which pulses when firing
your fan may need attension fan runs after boiler shuts down is normal on some Vokera,s too clear fumes out the flue 2mins approx
Oct 04, 2009 | Water Heaters
Apr 21, 2009 | Heating & Cooling
Vokera linea 28 boiler. I am continuously having to re-pressurise the loop (about twice weekly) also i keep getting a code 3 error appear which i know is a fan flue problem i have reset the boiler. The...
I have a similar problem with this boiler. When CH on, boiler overpressurises, (check relief valve outlet) You will then lose water from the CH loop and will have to repressurise when the CH loop cools. The problem is most likely caused by a loss of air from the expansion tank, which will need re-charged. This is not a big job as it has a standard tyre type valve connection but needs an accurate pressure gauge. Probably best left for plumber.
Mar 12, 2009 | Water Heaters
I have a vokera linea 7 boiler and i get a 01 error code
01 is ignition failure . flame sensor or blocked pilot
Jan 18, 2018 | Heating & Cooling
Vokera linea combiboiler error code CO
It's got nothing to do with carbon monoxide. CO means the boiler is in combustion test mode, that's all (and in this case -- long since fixed, I imagine, but other people will no doubt find this page in the future -- failing). Vokera could probably have made this clearer, but hey.
Dec 23, 2008 | Water Heaters
Vokera Linea 28 combi boiler
sounds like you have an earth leak or defective pump winding
Nov 04, 2008 | Water Heaters
Heating & Cooling Logo
148 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
