Question about IBM Infoprint 1332 Laser Printer
Printing from Other Drawers
I cannot figure out how to print from other drawers. I have 3 drawers on the machine but it only feeds from drawer one. Please help.
  • steve50donna Jan 28, 2009
    I have the same problem, but I am trying to print from the AS400 and the CL command OVRPRTF. One of the parameters in the command is DRAWER. What I want to do is print letterhead paper from one DRAWER # and plain paper from another DRAWER #, but it will not print from each tray from one CL with 2 different OVRPRTF commands.
  • 624 Answers
When you go to print as Noggin said you should be able to specify which tray to print from. When you select the print option from your program you will be taken to a print dialog box that should display your printer name. To the right of that is a properties button; clicking on that will take you to the printers properties page. Somewhere on that you should see a section labeled Paper source with a pull down menu to select the tray you want to print from. Select it, close the box and send the print job and you should be good to go. If you don?t see all of your trays listed the printer driver may not be configured correctly. Manual link: http://www-1.ibm.com/support/docview.wss?rs=95&context=SRATE7&dc=DA410&q1=english&uid=pub1g510247801&loc=en_US&cs=utf-8&lang=all Good luck and let us know if you have any other questions.
Posted on Mar 14, 2007
  • 944 Answers
This is the link to the manual if you need it http://publibfp.boulder.ibm.com/epubs/pd... page 47 shows how to manually describe the paper type in each tray - after that, when printing click on properties and select paper type - it should automatically select the correct tray - if you want the same paper in more than one trays, it will always use the first one first, then start using the others. Hope this helps :)
Posted on Mar 13, 2007
2 Suggested Answers
  • 624 Answers
SOURCE: Printing from Other Drawers
Duplicate posting, click the following link for the active post: http://www.fixya.com/support/t136860-printing_from_other_drawers
I want to print envelopes 11/23
You can ask manufacturer for Envelope printing options they may Additional Separate Trays for this or use the existing tray with Envelope adjustment
Jun 25, 2015 | Ricoh Aficio Mp C5000 Color Copier - 129k...
With 2 drawers, when you close the door tightly, it pushes open the top drawer, so the printer feeds from the incorrect drawer
take both drawers out and find the bit of rubbish blocking it up
a bit of paper or a clip or a staple is stuck in a seem ,,, or runner
Mar 05, 2015 | OKI B4600 Laser Printer
Bypass feed
this is set by the computers driver
or its detecting no paper in the main drawers
Jan 10, 2015 | Toshiba e-Studio 350 Copier
Aspire 7535 7235 series
Changing drawers wont solve a problem like that. You have to clean the printing heads, and all the area around the printing head. It's best to let a proffesional do the job.
Apr 01, 2014 | Konica Minolta Office Equipment & Supplies
How do I clean around the rim of the refrigerator drawers?
Samsung draws are removable, but they are a pain and have to be pulled out, then lift up which allows you to bet the nylon wheel guide to dip under stops, and sometimes takes a little force taking out, and putting back in.
CERACOAT-NANOTECH.com
Feb 22, 2012 | Samsung RFG297AARS (285 cu ft) Bottom...
Lexmark T644 Drawer 2 Missing error message but drawer 2 is in place. Drawer 2 always has problems pulling form form drawer when printing from drawer 2.
If job prints from the wrong tray or on the wrong paper or specialty media, this is an indication that the operator panel menu settings do not match the media loaded in the tray.
Make sure the Paper Size and Paper Type specified in the printer driver match the paper size and type in the tray.
For further assistance, please contact Lexmark Technical Support
Feb 09, 2012 | Lexmark T644 Laser Printer
Need to take off u-line 2075 drawer refrigerator doors - how?
Hi
Frost in u-line drawer dwrr models happens because of 3 things. The most common is that the drawer wasnt sealing properly. At the ends of the slides you see a white plastic end. This is called door closers. Remove your drawers,Unplug the top drawer. Then remove the closers on all slides. Take a small screw driver then push on the top of the slide. You should see a piece of the closers. While pushing down pull the ends out.You see the hook and spring, sometimes the hooks get off track and keep the drawer from closing. By keeping them out this should help. Also if you have vegetables keep them in sealed containers. The 3rd thing is you have the display set at 34 and this will cause the unit to run 100% of the time. Recomend 36 degrees.
Jan 17, 2009 | U-Line Echelon Series 2075DWRRSS...
Xerox 8830 - 2 Drawers / Trays non-operational
I would suggest to have the proper service rep work on it. albeit pricey if you want it to work correctly have it professionally serviced.
Or say, Dearly beloved, we gather here today LOL.
Dec 18, 2007 | Xerox 8830 Copier
Solution
do you mean print via network or print via copier on glass or doc feed tray? network means you dont have your cassettes recognized in your software, or its useing the bi-pass as a default drawer.. copier reproduction means fault in you drawers, reprogram them.
Dec 07, 2007 | Canon imageRUNNER 4570 Copier
this is the link to the manual if you need it http://publibfp.boulder.ibm.com/epubs/pdf/51024780.pdf page 47 shows how to manually describe the paper type in each tray - after that, when printing click on properties and select paper type - it should automatically select the correct tray - if you want the same paper in more than one trays, it will always use the first one first, then start using the others. Hope this helps :)
Mar 13, 2007 | IBM Infoprint 1332 Laser Printer
IBM Infoprint 1332 Laser Printer Logo
326 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
quennie732
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
