Tappan 18 in. MDR251RE Built-in Dishwasher
Problem for Tappan 18 in. MDR251RE Built-in Dishwasher
Someone told me to rplace the float switch, how can i do that?
By Ross - usenet poster
Solution #1
posted on Aug 08, 2005
Somewhat Helpful)
Luisa_K
Rank: Apprentice
Rating: 0%, 0 votes
1. Turn off power to the dishwasher by unplugging it or turning off the circuit breaker.
2. Remove the service panel that runs along the bottom front edge of the dishwasher. If it is screwed to the dishwasher, remove the screws with a screwdriver. If the panel hangs on hooks, pull the panel out and swing it up to get it off the hooks.
3. Locate the float switch. Wrap each wire with masking tape and label each so you can reinstall them correctly on the new switch. Then remove the wires with needle-nose pliers.
4. Remove the old switch, using a screwdriver or a nut driver and socket to loosen the fasteners.
5. Take the switch to an appliance store and purchase an exact replacement.
6. Install the new switch and attach the wires.
7. Replace the service panel, turn on the power and test the machine.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Tappan 18 in. MDR251RE
Questions and Unsolved Problems for Tappan 18 in. MDR251RE
Do you recommend Tappan 18 in. MDR251RE Built-in Dishwasher?
Answer
Answer
My Frigidair dishwasher model # FDB510LCB2 will not drain. It leaves water in the bottom and did not... (More)
Answer
can any dishwasher be connected to the sink and used without installation? like in an apartment... (More)
Answer
Our Matsui MF145 dishwasher does not finish its cycle, it doesnt beep and the cycle light stays on... (More)
Answer
bottom arm does not rotate, cleaned all filters and arms what to try next!
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Tappan 18 in. MDR251RE...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
