I have a Samsung P801 Washer (stacker) and an error message comes up " ed" power is on clothes are loaded, can u please help ? Thanks in advance, Michelle
  • mipepper Dec 12, 2008
    thank you so much!
    michelle
    President:
  • 373 Answers
"ED" is a open door error. try Closing the door properly or else there might be jam at the door.
Posted on Dec 12, 2008
  • Suresh Thrithandam Venkata Lakshmi Narayana
    i guess i already answered another post of yours Michelle.Well the solution for it is to only check for the door.If it stil continues to flash inspite of best trials, try contacting the technician.
Samsung washer error codes
My washer will wash a load of clothes then the next load it will wash but when it comes to spinning out it sits and beeps a DP code.
Jan 05, 2014 | Washing Machines
I have A samsung washer p801 and the washer wont close it keeps telling me Ed and i tried turning off the machine and closing the door and turning off the machine when i open it but the door just wont lock...
ED is a door not closed error code. The lock may be on and the machine will need to be reset. To do this either leave the machine unplugged for 24 hours or see if there is a reset option on the machine. If you need an owners manual, I can probably locate one for you .
Jun 05, 2012 | Samsung Washing Machines
Error code "UE" clothes have
UE = Unbalance Error
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Thanks for using FixYa !!
Dec 12, 2010 | Washing Machines
Washer not spinning correctly
4E - WATER SUPPLY ERROR
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 04, 2009 | Washing Machines
Samsung P801 Front Loader shakes violently during spin cycle.
When the washer goes into spin cycle it is suppost to start at a slow speed and continue to increase speed (to a maximum of 800 RPM) as the water leaves the clothes. Your washer is going directly to 800 RPM which causes the washer to shake and stop giving you the E4 code. The control board that controls this speed increase must be replaced.
Feb 23, 2009 | Hotpoint Ultima WD72 Front Load...
Samsung P801.washer....Error Message " ED" WHY??
"ED" is a door open error. try Closing the door properly or else there might be jam at the door.
Dec 12, 2008 | Samsung WF337AA Front Load Washer
Error codes
just fixed mine
i cleaned the filters inside the water lines. disconnect lines where they go into washer use needle nose pliers to pull out screens clean with water and put them back.
this wasn,t the problem with my washer .
mine i took the cover off and found the clear hose from the drum to the water senser had disconnected reattached it with difficulty as i have big hands works fine now
Nov 06, 2008 | Washing Machines
Hotpoint WF640
the f-01 error code on your hotpoint all in 1 washer/dryer is a short circuit code for the motor. the only way to clear the code is to have a service tech come and inspect the reason for the error.
May 12, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
403 people viewed this question
Top Washing Machines Experts
