Question about Kicker KX600.1 Car Audio Amplifier
Crunch amplifier i got a crunch pzi.250.2 1000 watt amp i got a problem that when i play it it sounds good for like 10 min after that the subs get a huge whine sound and the subs go up and down real bad it looks like if theyre playin a 10hz tone so im thinkin it might be my radio so i took it out and tested it and sounds fine so does the rca cable and i took my car radio and my amp and hooked it to a 800 watt power supply so i hooked everything like i would in my car rca remote turnon etc. and everything sounds good so im not sure if theres somethin in the car thats makin it sounds like that or it might be the amp
    Scholar:
  • 96 Answers
There is a bad ground or some other wiring issue in your car you will have to re wire all new to find it unfortunately
Posted on Jan 10, 2009
  • wyatt connolly
    wyatt connolly Jan 10, 2009
    it may also be the subs are not getting enough power that amp is actually very small (only 250 real watts 1000 is the peak only)
Crunch 2000.4 car amp, need help tuneing
re-check the speaker connections are correct and use a matching ohm test speaker on the other connections for a sound check. Sounds like hi frequency output into the sub amp. Sub-woofers are a mono signal!!
Jul 17, 2017 | Crunch Car Audio & Video
I can't figure out if my crunch powerzone pzi 250.2. 1000 watt amp is compatible with my 2000 watt pioneer premier 12" sub, I seem to be blowing fuses will someone please help me out
There may be an impedance mismatch between the two. If the amplifier "sees" a load impedance of 2 ohms or less, for example, the fuse(s) will open to protect the output stage from failure.
Feb 09, 2017 | Pioneer Car Audio & Video
I have an amp that turns on (green light) but has no sound coming out
Crank up the rotary gain potentiometer for in and out from the amp.
Apr 30, 2010 | Crunch Maxxsonics PZi 3000.1D Car Amp
AMP WONT TURN ON
Hi.
A short on Amp power contact can blow the internal power adapter. Before deciding if to replace or repair the amp, check if it has an external fuse mounted at the back side of the amp. In that case replace it.
Also ensure that the wires that you are connecting to the amp are still powered. Read Volts on wires before connecting to test the amp.
If the Amp has blown, then the damage will be located in the power supply circuit, and can be repaired testing and replacing few components.
Mar 27, 2010 | Crunch Maxxsonics PZi 550.5 Car Amp
Power cutting on and off
had a similar problem with an 800 watt legacy. remounted it in a cooler place away from the speakerbox, no more problems it would overheat and shut itself down until it cooled
Jun 09, 2009 | Crunch PZi1000.1 Car Audio Amplifier
My amplifier is not in protection mode everything works fine but my subwoofers play a very small sound . and it is not my subs at fault i already tested my subs and they work fine. i know theres a problem...
THERES A PROBLEM WITH YOUR RCA'S,IF YOU JIGGLE THEM WHILE THERE HOOKED UP TO THE AMP AND THEY MAKE THINGS LOUDER OR POP THAN YOU NEED TO GET THE RCA TERMINALS FIXED.
May 07, 2009 | Crunch Maxxsonics PZi 3000.1D Car Amp
As soon as they turn on there start pumping with or without sound
You have the amp's gain turned up too high and you are getting feedback. Turn down the gain on the amp and you should be fine. If it doesn't go away until a really low volume, you may need to run a dedicated ground wire from the engine groud of your vehicle to the amp, or buy a ground loop isolator from radio shack or somewhere.
Mar 17, 2009 | Kenwood KFC-W2510 Car Subwoofer
I have 3500 watts of subs total of 1100 rms what size amp should
Make shure your running thick guage wire like 2-0 guage wire to get correct power to it also and check on amp the ohm's it can handle to make shure your not running to makny ohms.
Jan 12, 2009 | Car Audio & Video
No sound?
Check the outputs on the stereo. Maybe there's no audio signal going to the amp.
Mar 24, 2008 | Crunch Powerzone P2200 Car Audio Amplifier
Sub for lanzar mxa 282
2 X 18" Kicker CVR they will work really clean. 2000 watt max each and 1000 RMS just like your amp.
Nov 16, 2007 | Lanzar MXA282 Car Audio Amplifier
Kicker KX600.1 Car Audio Amplifier Logo
244 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
