Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Water is not flowing into the machine
Model Name : whirlpool whitemagic Top load Fully automatic
  • flyingtarzan May 11, 2010
    hot and cold?
  • Anonymous Mar 29, 2014
    I need circuit diagram of whitemagic FSHA651 top loading ECU
  • 833 Answers
There are a couple of possibilities:
  1. Are the hot and cold valves open?
  2. If there are filter screens in the lines, are they clogged?
  3. If set to warm, does any water flow at all?
  4. If there is no water flow, first check the water level switch to see if it is working...this is located on the bottom of the machine...it is generally round and has a tube running to the tub and two or more wires.  It should have closed contacts to let the water valve work.
  5. If there is some water flow, the valve is likely bad or the supply is clogged.
  6. If the switch is continuous, the problem may be the timer.
  7. Is the water temp switch good?...unlikely.
Posted on Dec 12, 2008
Whirlpool f65 whitemagic top load washingmachine pe error
consult the user manual from the Whirlpool website eric
Jan 05, 2018 | Whirlpool Washing Machines
Whirlpool top load 1-2-3 whitemagic it is showing 1E error why does this error come
your not getting proper water fill hot or cold water is not flowing into machine fast as it should check make sure water is turned on all the way or replace water valve
Dec 23, 2016 | Whirlpool Washing Machines
I am having whirlpool washing machine model-whitemagic FSAN652 during washing machine suddenly stopped working and an error PE is displayed pl give me suggestion to rectify
whirlpool have a good fault code list on the net
go google and type in whirlpool top loader model------ and look for pdf version of manual or fault codes.
Jun 28, 2015 | Whirlpool Washing Machines
Whirlpool F65 6th sense Whitemagic top loader fully automatic - Cloth Mover (Agitator top assembly) slipping - India Model.
HOPE PICS HELP U MAY HAVE BAD AGITATOR COUPLER, BAD CAM DOGS, ETC
SEE PICS
In your case the cam dogs are repalced with this coupler.
Jun 06, 2015 | Whirlpool Washing Machines
My whirlpool Fully automatic washing machine is not functioning properly,what can I do to repair it?
Check to see if the machine has touched the on off tap at the back during spinning and cut off water supply.Or check the penny trap at the bottom of machine.if both are okay the it is likely to be down to faulty board or impeller motor which helps the flow of water into machine.
Nov 19, 2014 | Whirlpool Washing Machines
Whirlpool whitemagic pro 700h
The model no is Whirpool whitemagic pro 700H fully automatic top load
Dec 19, 2013 | Washing Machines
Fully automatic washing machine top loading model water is getting drained out automatically
Look at the height of the discharge hose. It must be run higher than the machine, or all water can run out.
Jun 08, 2011 | Whirlpool Washing Machines
Dear sir, I bought top loading fully automatic
you can contact appliancerepairplanet.vstore.ca for help in this matter
Dec 08, 2010 | Samsung Washing Machines
Whirlpool model LSR7233EZO / doesn't fill fully
The fill switch is a very sensitive device. You can test it by blowing into the tube, listen for the switch to click, or use an ohms tester. They are actually adjustble, the adjuster screw usually has glyptol (thread lock) on it. I would replace one before trusting an adjusted one.
Oct 16, 2007 | Whirlpool LSR7333 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
162 people viewed this question
Dan Webster
Dan Webster
Sal De
