Question about Sony PlayStation Portable (PSP) Slim (PSP-2000) Console
PSP slim analog joystick replacement problem.
I got some replacement sticks and pulled out the old stick and inserted the new and the stick does not work the pointer mover to the uper left. After trying the old stick It would hold position fine but after removing it the 2nd time I saw a small clear plastic part on the contacts of the old stick. I tryed to place this part (clear with copper looking fibers inpregnated inside for contact resones). I then installed the new stick with the plastic and the plastic would not stay in place. after several trys the plastic was dameged. Was the plastic part supose to stay on the main unit and not the stick? The new sticks did not come with the plastic part? Kinda lost for what to do now. H E L P (please).
Roger the 56 year old gamer
  • tari187 Feb 04, 2009
    Hi, I actually have the same problem!! dont know where i can find these?
  • 20 Answers
Yes,the clear plastic part is very important for the analog joystick controller,it is a Conductive Rubber, I check in this link:
http://www.logictoyz.com/sony-psp/sony-psp-2000/psp-2000-parts/original-psp-2000-joystick-conductive-rubber-contact.html
they are original, it is rare
and some seller just have copy (OEM) one,like this
http://cgi.ebay.co.uk/NEW-PSP-PHAT-100X-ANALOG-JOYSTICK-RUBBER-CONNECTOR_W0QQitemZ280442969996QQcmdZViewItemQQptZUK_VideoGames_VideoGameAccessories_VideoGameAccessories_JN?hash=item414bb41f8c
Posted on Apr 06, 2010
Analog stick broken
The following website does PSP analog joystick repairs. You can click on the "SEND US YOUR PSP FOR REPAIR" link on the following page:
PSP Slim PSP 3001 PSP 3000 Analog Joystick Assembly
Dec 04, 2013 | Sony PlayStation Portable (PSP) Console
Tip
How to Replace Analog Joystick on PSP-2001
If your PSP's joystick won't go in a certain direction -- or characters walk by themselves, this part needs to be replaced. It is sold at the website all the way at the bottom for $16.95 and they can do this repair job for $18 more! However, it's not very difficult. Here are the steps:
Step 1. Open PSP. There are 2 screws on the top of the PSP.
Step 2. There are 4 screws behind the PSP and one on the bottom, as circled in the picture.
Step 3. Remove the faceplate and locate the PSP 2001 Analog Assembly. It is held into the console by 1 black screw, as circled in the picture.
Step 4. Remove the black screw and pry the joystick out of the PSP as shown below.
Step 5. It is important that you remove this clear silicon piece from the old joystick and install it into the new one. Its purpose is to communicate the movement of the joystick from the assembly to the motherboard. It sits between the assembly and the motherboard.
Step 6. After you transfer the piece, pry the motherboard slightly up as you slide the new assembly back in place as pictured.
Step 7. You will need to pry this piece up to slide the assembly into place so that it is seated. Replace the black screw and close it back up.
RELATED ITEMS
PSP-2001 Analog Joystick Assembly
Precision Screwdriver Set
to open PSP, PS2
PSP PSP-2001 Motherboard Silicon/Rubber
on Apr 14, 2010 | Sony PlayStation Portable (PSP) Slim...
The analogue joystick isnt working properly. the character wanders off in wrong direction on its own.
simple, get a replacement joystick module and install it on your psp. i did a couple. the psp really isnt that intimidating to take apart. compared to an xbox 360 or playstation
Dec 01, 2010 | Sony PlayStation Portable (PSP) Slim...
Unresponsive analog stick
check to make sure the headphone/tv output jack is not pushed in farther than its supposed to be. youl know if its in to far. if its fine then you mite need to replace the joystick chip. its not that complicated of a procedure.
first off buy another joystick make sure its for your psp first there are different modles.
oper up your psp. to do this (depending on your modle) unscrew the little screw that are on the outside plastics. there is 2 under the batter one of tem you can see the other is under neith the sticker at the bottom poke around to find it
once you have your psp open your scree will get in the way so dont unplug it but just bring it out of the plastic brace that has it in there. there will be lil aluminun strips on the side that hold the screen still just pop those out of there holes careful not to crack the screen.
then your motherboard mite get in the way so you will need to just lift that one up and out of the way be carefult not to break any plugs. once you have that up your joystick should be acessable. if there is one more just unscrew that one andset it aside for now.
just insert your new joystick in place of the old one and go back threw that steps till its together again
i cant be held responsible if something goes wrong OPEN YOU PSP AT YOUR OWN RISK
good luck its isnt hard really
Dec 14, 2009 | Sony PlayStation Portable (PSP) Console
My psp joystick is having a problem.... the guy in the game is still going foward, but im not controlling it...even if i do it will still run foward it happen to my old psp before and then i threw it in...
dont throw this one in the trash. your analog stick on the psp is stuck in the forward position. just take your analog stick off and replace it to where it is centered.
Dec 14, 2009 | Video Game Consoles & Games
PSP-2002 Drifting Analog Stick
It will probably have to be replaced. A new one can be purchased on ebay for less than $10
Dec 05, 2009 | Sony PlayStation Portable (PSP) Slim...
My new installed psp analog stick doesn't work
most of the time when you think that your joystick is messing up its really just the psp's motherboard that is messing up.
choices=get a new motherboard or get a new psp
Feb 05, 2009 | Sony PlayStation Portable (PSP) Console
Did you make sure not to lose the small transparent rectangle that is "floating" on top of the analog (in the inside). The analog does not work without it.
Nov 27, 2008 | Sony PlayStation Portable (PSP) Slim...
Psp analog stick
If I'm understanding the directions correctly, all you need to do is pull up on the analog cap. It snaps back on so don't be afraid when it comes off. If you lose the cap, i believe they sell replacements for it separately in most Best Buys, Circuit City, etc. They cost like 5 dollars for 3 or something....
After you pull off the cap there should be kind of a small stubby joystick.
Good Luck!
Feb 18, 2008 | Sony PlayStation Portable (PSP) Console
Analog stick
then it is a internal fault is it under warranty if so id take it back and try your analog stick on the replacement one then your see if it your machine or the analog ?
Feb 09, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Slim (PSP-2000) Console Logo
595 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
