Question about Dell Inspiron 5150 Notebook
My computer wont start up
At first my computer would work like normal but if i moved it it would shut off. now it wont turn on at all...when you hit the power button i can hear it start to run then it just shuts off.
  • 2 more comments
  • svxrated Dec 12, 2008
    didnt work
  • svxrated Dec 14, 2008
    that didn't do anything...any other suggestions?
  • Anonymous Jan 04, 2009
    I have the same problem, but I found that if I apply a slight pressure underneath the laptop, toward the front, under the CD ROM drive, it will boot up and continue to run. Once booted up, if I'm careful while releasing the pressure, it will stay on. I've also found that by placing something (like a CD case) in the same location and resting the laptop on it, the laptop will boot and continue to run. I'm a technician and plan to attempt to fix this problem. Right now I'm looking for someone who has already fixed this issue.
    I have the same problem, but noticed that if I apply slight pressure under the laptop near the CD ROM drive the computer boots and continues to run. Then if I'm careful while releasing the pressure it will stay on most of the time. I've found that placing something like a CD case under the same spot will allow it to boot and continue to run. Something seems loose within the laptop. I'm a technician and I'm looking for someone that's had and already fixed this problem. Seems to be common with this laptop.
  • 145 Answers
Remove the battery and wait about 20 min and pulg it up with out the battery
Posted on Dec 12, 2008
Acer aspire 5520
try f8 at the logo screen then disable automatic restart on system failure from the menu to find out what the error is
Jul 15, 2017 | Computers & Internet
Computer says its locked; change users, but my mouse is locked up too.Im using my desk top to contact you.
You can use the windows key to open the start menu, then use your arrow keys to hightight turn off your computer, hit the enter key, use your arrow keys to highlight restart and hit your enter key This will restart your computer and hopefully, unlock your mouse.
Let me know if this solution works for you. If all else fails, it is acceptable to push the power button until the computer turns off, then hit it again the turn the computer back on. This is not the normally acceptable procedure for shutting windows down, but in this case, it can be done without any negative repercussions.
Brian
Jan 02, 2011 | Computers & Internet
Hello no cdrom drive....eee pc900 wont boot up it...just keeps re booting and asking me start normal or safe mode i.e. can I get the recovery system copied to my usb for boot and system restore or mfg...
HI
Have you tried to start windows normally if so what happened because sometimes if the computer shuts down incorrectly when you restart it does ask you those questions so will you try to hit the start windows normally and if it dosent work let us know what happens next
Also try to start in safe mode and then do a system restore back to when it was working fine
we dont normally revert back to factory settings unless we have no other choice because you loose everything thats on your c drive and then you have a lot of work and updates to get it back to how you like it
So only do this if you really have to or you want to totaly clean and tidy it up
To do this i believe :-
Turn on the power swich and keep hitting the r key a few times that will hopefully take you into the restore area then follow the instructions
Hope this has helped you good luck
Nov 14, 2010 | ASUS Eee 4G Notebook
I wanted to put my pc like new but it didnt work now it wont turn on ...it gives me the esc..alt.del but it wont work
#1: Shut down your computer. You must first shut your computer down to initiate the factory restore.
#2: Start up your computer and as the computer logo appears (such as Dell or HP) hit "Ctrl>F11" simultaneously. This may be different for different machines, but the most common keys to hit are "Ctrl>F11." If this does not work, the F8 key has been said to work for certain machines.
#3: Select "Repair My Computer" from the list of menu options that appear and press "Enter."
#4: Choose the language settings that you would like and then click enter.
#5: Enter the administrator log in and password if it asks you for this information.
#6: Choose the factory reset option. This should reset your computer to the factory settings when you bought your machine.
http://www.supportdock.com/
Dec 16, 2009 | Compaq Presario CQ60-220US PC Laptop
When the screen is not used for a little while it goes in the sleep mode and I have to turn it off and back on. Is this normal
Normally a monitor will come out of sleep mode merely by moving the mouse or hitting a key on the keyboard. It all has to do with your power settings. If in Windows, click on START/ControlPanel/Power Your Power settings determine how long your monitor stays on as well as hard drive disks when computer is idle. Just select a longer period of time or "Never" for monitor shut off settings.
Nov 07, 2009 | Acer 22" X223w LCD Monitor
Mouse wont work
check your device manager and see if there is a problem there
to get there go to
start/control panel/performance maintance/system/hardware/device manager/mice. click the + on mice then right mouse properties and make sure the device is working properly and that it is enabled. then go to update driver and see if it will update
good luck
May 20, 2009 | Dell E228WFP Monitor
How do i get the monitor out of sleep mode? It was suggested I hit the ESC button on the keyboard but this hasn't worked. The only way to resolve it so far, is to turn everything off at the wall and start...
In windows click Start, Control panel, Power Options. On the first page "When computer is plugged in: Turn off monitor: Never. On the Hibernate tab the box for Enable Hiberation should be unchecked.
Please rate this fixya.
May 11, 2009 | HP w1907 LCD Monitor
Acer Aspire 5920 will not start up either in safe mode or normal
IF YOU DON'T NEED ANYTHING ON YOUR PC YOU CAN FORMAT IT WITH YOUR WINDOWS OR RECOVERY CD
SOUNDS LIKE YOU MAY HAVE ALREADY LOST FILES
LET ME KNOW HOW THIS WORKS
Dec 27, 2008 | Acer Aspire 5920-6727 Notebook
Dell Inspiron 5150 Notebook Logo
114 people viewed this question
Alun Cox
