Question about Toshiba Satellite P205D-S7479 Notebook
Black colors turns to red in toshiba laptop P205D no bad connection
  • Anonymous Jan 26, 2009
    mine was doing the same thing except black turned green. unfortunately, i don't know why it stopped doing that, except that when it was doing that i could usually put pressure on a spot to the right of the mouse pad to make it normal for a while.
    Novelist:
  • 166 Answers
It is not due to bad connection it is due to bad software driver version of graphics driver. I recommend you to install correct version of graphics driver like Intel's driver.
Posted on Jul 21, 2009
I need to know if the mother board from the p205d-s7436 is compadable for the s7438 model
Satellite P205d-s7436 motherboard,
http://www.sparepartswarehouse.com/Toshiba,Laptop,Part,K000056150.aspx
Satellite P205d-s7438 motherboard,
Same part number used for both laptop models.
Satellite P205d-s7436 specifications,
http://www.cnet.com/laptops/toshiba-satellite-p205d-s7436/4505-3121_7-33428376.html
Satellite P205d-s7438 specifications,
http://www.cnet.com/laptops/toshiba-satellite-p205d-s7438/4505-3121_7-32658635.html
Just by comparison of the specs the data suggests only a Processor change, Ram Memory amount, and Harddrive size.
Uses a Socket S1 processor socket on both model's motherboards,
http://en.wikipedia.org/wiki/List_of_AMD_mobile_microprocessors#.22Tyler.22_.2865_nm.29
Both models use an AMD 690V graphics chipset, (ATI Mobility Radeon X1200)
http://en.wikipedia.org/wiki/AMD_690_chipset_series
The answer is Yes.
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
Regards,
joecoolvette
Sep 15, 2012 | Toshiba Satellite P205D-S7438 Notebook
Toshiba satellite p205d-s7436 will not start.
Please remove the cable and remove the battery and connect the power cable and check it. if it working remove the power cable and connect the battery and check it.
Mar 15, 2012 | Toshiba Satellite P205D-S7436 Laptop DC...
Toshiba P205D-S8802 will not start up. Pressed power button, and hear the droves starting up and then stops. The screen remains black.
Hopefully you have more than 1 stick of RAM. I would remove 1 and try it again, if that doesn't work, try the other one. When it's powering up and then powering off quickly, that could also be a heat issue. Make sure all of the fans are powering on. Also you can try removing the battery, and trying with just AC power connected. Some laptops won't let you do this, but some will, and if the battery is causing the issue, it should work.
User guide can be found here, which will walk you through getting to the memory bay. http://www.retrevo.com/support/Toshiba-P205D-S8802-Laptops-manual/id/12395ag000/t/2/
If this helps, please provide a positive rating.
Jun 30, 2011 | Toshiba Satellite P205D-S8802 Notebook
Need to replace cpu battery for my P205D-S7438y
Straight from Amazon:
http://www.amazon.com/Replacement-Battery-Toshiba-Satellite-P205D-S7438/dp/B003O77162
If it's still under warranty though you can call up Toshiba and get it replaced at no charge.
Jan 02, 2011 | Toshiba Satellite P205D-S7438 Notebook
I have A Toshiba Tecra 10 Laptop that I have just tried to connect to a Toshiba 32" HD LCD TV. There is no RED color on the TV when the laptop is connected. What should be red is black. Everything else...
Sounds like a bad connection with the video cable. If not then with the mating connector on the laptop or the TV. Try to narrow it down to one of the three.
Feb 15, 2010 | Toshiba Televison & Video
Display Problem Black turns Red
sounds like you have a loose connection ....either into the screen or into the motherboard....the connection between board and screen runs through the hinge brackets and often comes loose after machine has been opened and closed a lot.....need to be comfortable opening up laptops to check the cables as it can be tricky to get to the back of the screen where the end of the ribbon cable is..
Dec 13, 2008 | HP Compaq Presario V2000 Notebook
Monitor color problem
please go to monitor menu and found degauss setting and select degauss this will get the flicker effect on monitor and all color guns get reset and your monitor will be ok again. and please note that this kind of problem occurs due to magnet so please do not bring any magnetic material or thing near the monitor. and use only computer speaker and avoid to use any speaker from tv or tape.
Dec 12, 2008 | Computers & Internet
the is some loos connection in the staip comming from lcd to motherboard.
check it.
Nov 24, 2008 | Computers & Internet
BIOS PASSWORD ON TOSHIBA P205D
contact me @ timothydjohnson@comcast.net
Jun 01, 2008 | Toshiba Satellite P205D-S7479 Notebook
Toshiba Satellite P205D-S7479 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
