Question about Philips GOGEAR SA6045 MP3 Player
My computer doesn't recognise my gogear, how do i charge it?
When i connect the USB to my computer its not recognised and my GoGear won't charge.
  • heviisa Jan 06, 2009
    i have service pack 3, windows media player 11.. my mp3 won't connect to pc. but on mp3 it shows that he is connected...
  • Anonymous Jan 20, 2009
    when i turn it on it says file system error
Your computer must have, the service pack 2, if not, you can´t charge your reproducer.
Posted on Dec 12, 2008
My MP4 won't charge or turn on and the USB port isworking fine, my computer won't even recognise that the mp4 is connected
You can turn off the Mp4 for a while and re-install the system ,and then you can change if the port is fit the computer ,you can also used a transfer interface to connected the computer .
Dec 11, 2012 | Philips Gogear Vibe 8gb Mp3 Mp4 Video...
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
My gogear does not recognize by my computer what should i do
What should I do if my player is not recognized by my PC?
Reset it. Use a pen tip in the RESET hole on the side of the player.
Connect the player to the PC to see whether the player is recognized.
Faulty USB port, try connecting the player to another USB port (or try another computer).
Is your computer Mac or Windows? eg Mac OS 10.7.2 had issues recognising media players that could be fixed by resetting PRAM.
Install Philips Songbird software and try Repair mode. Note this will delete files on the player.
Philips GoGEAR MP3 player SA2RGA04KS RaGa 4GB with FullSound
Sep 19, 2012 | Philips Gogear SA2RGA04KS Mp3 Video Player
My Philips Gogear is not recognised by my PC so I cannot download or upload music
Use the USB port at the back of your computer.
Set to MSC mode of your player. Select Settings -> PC connection preference.
Try to avoid using a USB hub. Try to avoid using a USB extension cable.
Oct 23, 2011 | Audio Players & Recorders
My computer is not recognizing the philips Go Gear MP3 Player.
Hi go to the philips web site, download required software
Apr 17, 2010 | Philips GoGear HDD075/17 MP3 Player
My philips mp3 gogear doesn't come on
Whenever this type of problem occurs in Hardware the best way and the right way is to change the battery. The battery of the GOGEAR may be damaged and may need replacing. I am sure that the problem will be solved when you change it.
May 24, 2009 | Philips GOGEAR SA6045 MP3 Player
Phillips gogear sa6185
player says i should not connect and then that detachment is ok.
Oct 22, 2008 | Philips GOGEAR SA6045 MP3 Player
Phillips GoGear not turning on
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Nov 29, 2007 | Philips GoGear HDD6330 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
212 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
