Question about Dell (008HW) Motherboard
I am going to replace a motherboard and want to know of the 3 choices 5Y835, 6g040,9y422 (dell c840 & 8200) I want the fastest fsb and intel chip that I can run. I read that you can go above 400mhz to 533mhz and even to 800mhz. Seems if possible you could run up to 3.2GHZ. How do I find out and what bios will I need?
    Scholar:
  • 87 Answers
There are a few things that you need to check out.
First you need to make sure there isn't any extra colling systems that would of been installed in the higher speed laptops. Laptops with stronger video systems can't have a large cpu due to thermal issues. (8500 series had issues with overheating that would eventually cause the cpu to burn off or the gpu to burn off... burn off is when the silicon literally burns)
Second: You should see if there is a new laptop out there.that will do the job. They are going to be pretty cheap at the 4quarter. Most stores need to get rid of the inventory. You can pick up pretty nice systems for very little.
Posted on Jan 01, 2009
  • 35 Answers
You have to first read the motherboard model number and then try to find the bios
Posted on Dec 23, 2008
What processor can i use with 446476-001 system board
The HP 446476-001 laptop motherboard, or also stated as HP motherboard used for the HP Pavilion dv6000 series of Notebook PC's;
A) Has an Intel 965PM motherboard chipset,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Core_2_mobile_chipset
Has a;
B) Socket P processor socket, for Intel processors
http://en.wikipedia.org/wiki/Socket_P
Using this information you know;
1) That the Intel PM965 motherboard chipset supports
Intel Core 2 Duo processors,
with either a 533MegaHertz Front Side Bus, or a 667MHz FSB, or an 800MHz FSB.
[Note*
The motherboard chipset is the Northbridge, and Southbridge chip, for YOUR motherboard technology.
(Does not apply to motherboards that support the Intel Core i3, Core i5, Core i7, and Core i9 processors)
The Northbridge part number is Intel 82965PM.
You won't see this part number on a chipset, because the Northbridge chip is under a small finned heatsink.
The Southbridge chip is an Intel ICH8-M
Part number is 82801HM. This you should see on a chipset ]
2) That the processor socket is a Socket P.
So you need an Intel Core2 Duo processor, with either a 533MHz, or 667MHz, or 800MHz FSB, and fits in a Socket P processor socket.
For additional questions please post in a Comment.
(You may, or may not need a BIOS update )
Regards,
joecoolvette
Feb 18, 2012 | Computers & Internet
Can I make my Dell 0MG532 motherboard work at 800Mh FSB
upgrade the bios and check this url www.dell.com
Dec 31, 2011 | Dell Computers & Internet
Dell dimention 2350 socket 478 I upgrade celeron 2.0Ghz to pentium 4 3.0Ghz 530 The Bios show me the speed 1.5Ghz. Bios A02
The Dell Dimension 2350 Desktop PC motherboard, has an Intel 845GL motherboard chipset,
mounted to it. (System Information),
http://support.dell.com/support/edocs/systems/dim2350/specs.htm#1101572
Here we see that the Intel 845GL chipset supports processors, with a -> maximum <- Front Side Bus of 400MegaHertz, (FSB = 400MHz max.),
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4_chipsets
The Intel Pentium 4 model 530 (3.0GHz. Also has Hyper-threading Technology. HT), operates with a FSB of 800MegaHertz, (FSB = 800MHz),
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Prescott_.2890.C2.A0nm.29_2
(Scroll down. Pentium 4 HT 530 )
You can't make the Intel 845GL chipset support a processor with an 800MHz FSB.
BIOS update or not, the voltage range will be too low. Therefore the FSB is low. Changing just the Multiplier will not do the trick either.
(BIOS Setup, Advanced Chipset Setup. Doubt the options of changing the FSB, and/or Voltage, and/or Multiplier, is available with that BIOS program))
Note your 3.0GHz processor is operating at 1.5GHz?
Max FSB supported is 400MHz, and your Model 530 needs 800MHz? (For max operation)
Post additional questions in a Comment.
Regards,
joecoolvette
[ Chip and Chipset are shortened terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit
The motherboard chipset technology used for your computer, has a Northbridge chip, and a Southbridge chip.
(Does not apply to motherboards that support the Intel Core i3, Core i5, Core i7, and Core i9 processors )
The Northbridge chip handles the faster capabilities of a computer.
Processor, Ram Memory, and High-speed graphics.
[ The AGP technology, and the PCI-Express technology, is High-speed graphics.
Using a graphics card in a PCI slot, or using Integrated Graphics, is NOT High-speed graphics ]
The Southbridge chip handles the slower capabilities of a computer.
Anything connected to the PCI bus, (Such as a PCI graphics card)
IDE (PATA)
SATA
USB
Ethernet
Audio (Sound)
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
[ CPU stands for Central Processing Unit. Another term used is Microprocessor, or Processor for short ]
So it is first up to the Northbridge chip, of the motherboard chipset, whether it will support a certain processor, THEN if a BIOS update will help.
Nov 12, 2011 | Dell Dimension 2350 PC Desktop
Had this system for awhile but never had any problems. Todays internet media etc. are getting to be too demanding for the athalon processor that came bundled with this MB. What is the strongest/fastest...
http://www.xiew.com/product-detail/msi/kt4v-l/
A) Processor Socket:
Socket A (Also known as Socket 462)
B) Motherboard Chipset:
VIA KT400A
VIA KT400A Northbridge chip,
VIA VT8235 Southbridge chip
http://en.wikipedia.org/wiki/List_of_VIA_chipsets#Slot_A_and_Socket_A
[ Info reading across from the subheading KT400A, shows one, of two newer Southbridge chipsets could have been used.
The VT8237, or the VT8251.
Neither one was apparently used, or the website's info is mistaken ]
The Northbridge chip (VIA KT400A) will support;
A) Processors with no more than a 266MegaHertz Front Side Bus. (266MHz FSB)
It will support Processors with either a 200MHz FSB, or 266MHz FSB.
(AMD processors are 'double-pumped'. The 100MHz, and 133MHz FSB support shown, is 'double-pumped' to 200MHz, and 266MHz )
AMD Athlon XP with a 266MHz FSB, that fits in a Socket A processor socket, IMHO is the best.
[ To digress;
Chip and Chipset are slang terms to represent I.C.
Integrated Circuit,
The Northbridge chip is so aptly named, for one, because it sits on the North side of the motherboard. Looking at the motherboard as a map, the Processor sits due 'North'.
The white long PCI slots sit due 'South'.
{In the illustration of the MSI KT4V motherboard above in FixYa, turn the motherboard to the Left }
The Northbridge chip and the Southbridge chip is the Motherboard Chipset.
The Northbridge chip handles the faster capabilities of the computer.
The Southbridge chip handles the slower capabilities of the computer.
The Northbridge chip handles the Processor, Ram Memory, and High-speed graphics.
A graphics card inserted into a PCI slot is Not high-speed graphics.
Neither is Integrated Graphics.
{Integrated Graphics is also known as OnBoard graphics. ON the motherBOARD.
The GPU is soldered to the motherboard, not on a removable graphics card}
Motherboard Diagram, (That is for the technology used for the MSI KT4V motherboard.
Does not apply to motherboards supporting the Intel Core i3, i5, i7, and i9 processors),
The Northbridge chip is the motherboard chip to be concerned with, when deciding what Processors the motherboard will support.
Finding an AMD Athlon XP that fits in a Socket A processor socket, and has a maximum FSB of 266MegaHertz, is a wee tough.
In my recent search I have seen some advertised on Ebay. DO NOT know anything about them.
Here is an AMD Athlon MP 2000+,
http://www.weirdstuff.com/cgi-bin/item/13161
,that operates at a maximum of 1.67GigaHertz, and uses a 266MHz FSB.
Not advertising for the above website either, but I have dealt with them to great satisfaction.
For additional questions please post in a Comment,
Regards,
joecoolvette
Jul 14, 2011 | MSI KT4V (MS-6712) Motherboard
Hi I have a D420 its a small one thats what i like about it i also have a d620 but i wanted to upgrade my d420 with something to make it a little faster like a processor upgrade ...? im not sure about the...
Your thoughts are breaking up as you are typing.
You stated;
1) I have a Dell Latitude D420 and a Latitude D620.
The D420 is small, that's what I like about it.
I want to make my D420 faster, is there a possible Processor upgrade?
I'm not sure about the specifications of the motherboard, so I do not know if this is possible.
I know I can get an SSD Harddrive,............the rest is illegible to me.
A) The D420 keeps going slow.
Question: After what?
After you installed an SSD harddrive? After you flashed the BIOS?
B) Was fast when I flashed it.
Question: Flashed the BIOS?
Why?
Why do people always rush to try to upgrade their BIOS program with a flash, when they do not know if it will help, or not?
One mistake and you have a dead laptop. Use it for a paperweight.
When you upgrade the BIOS you have the option to save the original, so you can go back to it in case there is trouble.
Did you?
Post back in a Comment.
While I wait.
To upgrade to a better Processor you need to know;
1) What Processor socket is on the motherboard
2) What is the motherboard chipset, and specifically, what is the Northbridge chip of the motherboard chipset.
To explain;
The motherboard chipset is the Northbridge chip, and the Southbridge chip.
(For the Dell Latitude D420 motherboard. This does not apply to motherboards that support the Intel Core i3, i5, i7, or i9 processors)
{Note*
CPU = Central Processing Unit. Another term is Microprocessor, or simply Processor for short. Does Not mean Personal Computer}
Chip and Chipset are slang terms for I.C.
Integrated Circuit.
http://en.wikipedia.org/wiki/Integrated_Circuit
The Northbridge chip is so aptly name because for one, it sits on the motherboard to the North, or top of the motherboard. Generally right under the Processor socket.
The Northbridge chip handle the Processor, Ram Memory, and High speed graphics.
{High speed graphics being AGP, or PCI Express. Not a graphics card installed into a PCI slot, nor Integrated Graphics. {Integrated Graphics, OnBoard graphics, same/same}
The motherboard chipset is an Intel 945GMS,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Core.2FCore_2_Mobile_Chipsets
(Part number printed on the Northbridge chip is Intel 82945GMS. Part number on the Southbridge chip is Intel 82801GBM)
The Northbridge chip supports Processors with up to a 667Megahertz Front Side Bus. (667MHz FSB)
Will support Processors with either a 533MHz FSB, or a 667MHz FSB.
667MHz FSB being the maximum it will support.
The processor socket is a Socket M.
http://en.wikipedia.org/wiki/Socket_M
List of Intel Core microprocessors,
http://en.wikipedia.org/wiki/List_of_Intel_Core_microprocessors
Regards,
joecoolvette
Dec 07, 2010 | Dell Latitude D420 Motherboard - XJ577
We own a dell dx270 p4 it wont boot up should we just buy a new one or is this one worth upgrading and what is the biggest processor we can put into it.
darrinjensen all I can offer is my opinion, as can everyone else. The decision rests with you.
A) The best Processor that a Dell Optiplex GX270 can use, is a single-core Intel Pentium 4.
The best Ram Memory is DDR Sdram at 400MegaHertz. (PC3200)
This is shown by the fact that the Northbridge chip is an Intel 865G.
Supporting Data:
1) http://support.dell.com/support/edocs/systems/opgx270/en/ug/specs.htm
2) http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4_Chipsets
3) http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
[ The CPU {Processor} communicates through the Front Side Bus {FSB} to the Northbridge chip.
Think of an FSB as an 'Information Highway'.
Information {Data} goes back and forth across the FSB.
{Chip and Chipset are slang terms for I.C. Integrated Circuit}
The Northbridge chip determines what Processors are supported, what Ram Memory is supported, and High-speed graphics.
{High-speed graphics being AGP or PCI Express.
Integrated graphics is also referred to as OnBoard graphics. ON the motherBoard. The graphics chip {GPU) is soldered to the motherboard. Not to a removable graphics adapter card. (Graphics card/Video card/Graphics adapter card, all mean the same thing)
The Southbridge chip handles the slower processes of a computer. Therefore also handling anything to do with a PCI slot, or Integrated graphics ]
A motherboard is the 'Building Block' of a computer. From it, all hardware components are supported.
Processor, Ram Memory, Graphics card, (Or Integrated Graphics), and so on.
What Northbridge chip is used determines a lot about a motherboard, besides the internal connectors used.
When buying a computer this is what you need to look at, for one.
Things have changed with the introduction of the Intel Core i3, i5, i7, and i9.
There is no separate Northbridge chip. It may be integrated into the CPU, or not used at all.
There is no FSB. It has been replaced with the Quick-Path Interconnect.
Intel rates their Processors with a star system now. The budget, or entry level Celeron is a 1 star. Pentium's are 2 stars. Core i3 - 3 stars, Core i5 - 4 stars, Core i7- 5 stars.
Point?
With the introduction of computer utilizing the Intel Core i3, i5, i7, and i9 processors, the computers that can use Intel Core 2 (Duo and Quad) processors are becoming VERY economical.
You may be able to purchase a desktop computer that utilizes an Intel Core 2 processor for around
$400 to $500. One that utilizes a comparable AMD processor for the same, or less.
And has Windows 7. (I know, do not start a sentence with And)
One example, (Not advertising for website),
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6326393&CatId=6
Another example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6738683&CatId=6
The Power Supply is probably what is bad with your GX270. Also, has it been cleaned inside on a regular basis as needed? {To include the Power Supply. A can of compressed air for computers is used. Power unplugged to computer}
Oct 24, 2010 | Dell GX270 P4 256/40/48X/XPP/NONE...
I have a dell dimension 4600i. I want to upgrade
It should.. Here is a link to documentation.
http://support.dell.com/support/edocs/systems/dim4600/en/4600/sm/specs.htm
Apr 28, 2010 | Dell Dimension 4600 PC Desktop
Processor motherboard compatibility
Intel® Core™ 2 Duo T8300 (2.4GHz/800Mhz FSB/3MB) it is the Cpu that your mainboard support. no more faster.
May 27, 2009 | Dell Inspiron 1420 (dncwja1_1) Intel Core...
Upgrading CPU
Yeah, it was a bit hard to find, not being a currernt model I was stuck on the Asus site trying to find out for you.
Then I found this site -
http://www.hardwarezone.com/articles/view.php?cid=6&id=465&pg=
It says
  • Socket 478 for Intel� Pentium 4 / Celeron processors
  • Intel� Pentium 4 Processors 1.4GHz - 2.53GHz or higher
  • Intel� Celeron Processors 1.7GHz - 1.8GHz or higher
  • Supports processors at 400 / 533MHz front side bus
    Or higher, it says. But doesn't say how higher. It's a fair assessment that if it is a Pentium 4 socket 478 chip, it should work. Then it's a case of choosing one that suits your budget.
    Have a look on the Asus site for the latest BIOS updates too - they might have a clue as to what chip you can go to -
    http://support.asus.com/download/download_item.aspx?model=P4S533-MX&product=1&type=All&SLanguage=en
    Er, no - it doesn't tell you. But if you go thru the page you will find BIOS version 1005 that " P4S533-MX BIOS 1005
    Support new Intel P4 CPU" and the latest bios is 1007.002
    There's a motherboard user manual further down on the page. Make sure you choose the English one.
    Seems the issue is FSB speed, 533 or 400. No big problem for most, but I did see a Pentium4 3.0Ghz chip at 800 FSB so just check the speed of the processor matches the specs the motherboard handles. Like you say, looks like the 3.2 might be too fast because of the FSB requirement.
    Remember, a P4 is going to be quicker than a celeron anyhow so just go with the fastest 533 FSB chip you can find.
    A short-cut to the english manual, here - http://dlcdnet.asus.com/pub/ASUS/mb/sock478/p4s533-mx/e1187_p4s533-mx.pdf
  • Apr 27, 2009 | ASUS P4S533-MX Motherboard
    Dell Intel P4 Chip
    Your chip is a socket 478, the fastest chip you can get for that system that is still for sale is:
    Pentium 4 3.0 http://www.newegg.com/Product/Product.aspx?Item=N82E16819116027
    Jan 18, 2009 | Dell Dimension 2400 PC Desktop
    Computers & Internet Logo
    Alun Cox
