Question about Lexmark Office Equipment & Supplies
New z2400 will not print a page (worked fine for the last couple of days), pop ups state in process of printing 2 pages, printer is diconnected and power off, but unable to delete printing process on the new HP G60-ous notebook pc
    Scholar:
  • 87 Answers
This may help you
How to force delete print jobs Fortunately, there is a way to delete the hung print job without having to save all your work, close all your applications, and restart your computer. Here's how (note that this is intended for Windows XP systems, but a similar approach works on other systems - if this doesn't work for you reply below with your Operating System and version):
  • Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
  • Browse to your windows\system32\spool\PRINTERS\ folder
  • You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
  • Browse to Start -> Run... and type in "NET START SPOOLER" (this will restart the print spooler service)
  • Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Voila :) You should see that annoying hung print job finally disappear completely and you should now be able to resume printing without having to restart your computer.
From http://community.contractwebdevelopment.com/how-delete-or-cancel-hung-print-jobs-windows
Posted on Dec 20, 2008
    Sergeant:
  • 306 Answers
Go to Start>Control Panel>Printers and click on the z2400 icon. You will see options there for cancelling or restarting the printing process at the top menu or by right-clicking on the printer icon depending on your operating system. Make sure that the printer is selected as the default printer. The document may not show that it is cancelled until you close that window then reopen it. Steve
Posted on Dec 19, 2008
How do I Print double side on wireless printer
unless you a specific printer that can print double sided in one run
you have to set the printer manually
to do this when you go to the print command , it will show up as print all, print pages etc
click on print pages then type in 1,3,5,7 each number has to be followed by a comma until you get to the last page or click on print odd pages only
then print what you want
when finished pick up all of the printed pages and put them back in the tray upside down with the top facing in the right feed direction
then go back to print all pages 2,4,6 etc or print all even pages then print
if you are not familiar with that procedure , practice on a couple of sheets until you get the way the pages face correct
practice by opening a new document and just typing a few words on the page 1 and 2
then print it out
Apr 02, 2017 | PRINTER Office Equipment & Supplies
Printer prints test page and direct prints fine but anything sent from the PC only prints (at most) a thin line (about 2cm/1in) on the left side of the page.
Well, if it ran okay with Windows 8.1 until the last month and if it prints a test page ok, the problem is unlikely to be drum wear or wear of internal parts. You sometimes encounter weird streaking effects if the windows are not clean. Normally, if only one side of a page is being printed, parts are worn or the drum need replacing. But your test page prints out. The only thing I can see that would have changed is --Ta da! -- some automatic update by Windows 8.1. Re-installing drivers doesn't really undo any changes in Windows 8.1 itself or whatever you have installed in the last month or so. (Windows 8.1 experts can stop laughing--I am simply making an educated guess.)
If this were a home setup rather than a work computer, I might see what would happen if I returned the computer to a state prior to "the last month or so." If the printer then worked, you would know it was not a hardware problem but rather what had been installed on the computer after that. Is the printer actually using the Brother driver or is it deferring to a Microsoft driver? Just something for you to check in your device manager. If returning the computer to a former state fixes the problem, you may have to test subsequent installations to determine which one troubles the printer, a tedious process unless a candidate springs to mind.
Aug 11, 2015 | Brother HL-4040CN Laser Printer
Black cartridge is new,magenta is new blue is halfway and yellow is halfway but the hp color laser jet 2600n prints lighter and black prints as it is finished
Hi Good day!!
Follow this method hope it helps you!!
During the printing process, paper, toner and dust particles can accumulate inside the printer. Over time, this buildup can cause print-quality problems such as toner specks or smearing. This printer has a cleaning mode that can correct and prevent these types of problems.
This printer has two processes for generating cleaning pages: one is automatically generated and one is manually generated. When a new black print cartridge is installed, a cleaning page will be automatically generated prior to calibration.
Clean the fuser using HP Toolbox
NOTE: Use the following procedure to clean the fuser using the HP Toolbox. To clean the engine when the computer is running an operating system that does not support HP Toolbox, see the late-breaking Readme on the root of the CD-ROM, or visit http://www.hp.com/support/clj2600n .
1 Make sure that the printer is turned on and in the Ready state.
2 Open the HP Toolbox using one of the following methods.
On the Windows desktop, double-click the HP Toolbox icon.
* On the Windows Start menu, click Programs (All Programs in Windows XP), click HP , click HP Color LaserJet 2600n, and then click HP Color LaserJet 2600n Toolbox .
3 Click the Troubleshooting tab, and then Troubleshooting Tools .
4 Click the Print button next to step 1, "Click the "Print" button to print out the Cleaning Page."
5 Remove the Cleaning Page from the output bin, and load it printed side down in Tray 1.
6 Click the Clean button to complete the cleaning process. Press the GO button on the printer control panel. The Cleaning page will print, with a second page adhered to the first page. This is normal behavior during the cleaning process.
Cleaning spilled toner
Defective print cartridges can develop leaks. Also, after a paper jam has occurred, some toner might remain on the rollers and guides inside the printer. The pages that print immediately after the jam can pick up this toner.
CAUTION: When cleaning the printer, do not touch the ETB with a damp cloth or with fingers.
Cleaning the paper path
The device features a special cleaning mode to clean the paper path.
NOTE: If there is access to HP Toolbox, HP recommends cleaning the paper path by using HP Toolbox.
Clean the paper path
1. Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Service, and then press (SELECT).
2. Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Cleaning Mode, and then press (SELECT).
A page feeds through the printer slowly. Discard the page when the process is completed.
3. Load plain letter or A4 paper when prompted.
4. Press (SELECT) again to confirm and begin the cleaning process.
Calibrating the printer
Calibrations are performed at regular intervals. For best print quality, a calibration can be performed from the control panel using the following steps:
NOTE: This will calibrate the color and clean the black electrostatic transfer belt (ETB).
1 Use the (LEFT ARROW) or the (RIGHT ARROW) button to select System setup and then press (SELECT).
2 Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Print quality and then press (SELECT). Calibrate color will display on the control panel.
Press (SELECT).
3 Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Calibrate now and then press (SELECT).
4 Press (SELECT) to start the calibration.
Other options for print quality defects that still persist
Oct 26, 2010 | Office Equipment & Supplies
Alienment sheet prints every time I print a page.
just put the printed alignment test page paper on scanner glass and press the scan button to complete the process. It is alignment process which is printer is doing for self testing after installing new cartridge. Just finish the process.
. It is necessary to after aligning the page it need to scan with the scanner. Otherwise it keeps pop up.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Have a nice day and do not forget to rate please...!
Mar 15, 2010 | HP PSC 1315 All-in-One Printer...
Every time I change a cartridge in my HPC4280 printer, a window pops up on my monitor and says I need to do an alignment. Fine, but even though I tell it I already have an alignment sheet, it prints...
I believe that you are not completing the alignment process.
Let me explain the alignment process..
1- Remove the usb cable from printer and computer if connected through usb cable.
2- Turn off the printer, wait for 30 seconds, turn on the printer
3- It will print an alignment page
4- Place this page on scanner glass of printer from right hand corner
5- Press OK or SCAN button on printer
6- This will complete the alignment process.
It will not print an alignment page again and again.
Regards
Harpreet_351
Oct 11, 2009 | HP Digital Printers - Hewlett-Packard...
Middle of print job - stops to CLEAN - then starts from pg1 AGAIN
This is a simple 3 step fix
a) Get rid of printer
b) Get rid of husband
c) Get new printer
Hope this works!! :-)
Jul 16, 2009 | Brother MFC 210C All-In-One InkJet Printer
Bottom of page is cut off sometimes printing from vista computer
I had same problem with Vista machine and hp c309 printer cutting off 1/2 of last line. Tried all other listed fixes and none of them worked. Eventually I found a fix that worked for me though.
1. Go to the control panel and select the printer
2. Right click and select Properties
3. Go to the Ports tab
4. Uncheck 'Bidirectional Support'
5. Click apply.
Hope this helps! It worked for me.
Jul 08, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
718 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
