Microsoft Streets and Trips 2008 Full Version for PC
Problem for Microsoft Streets and Trips 2008 Full Version for PC
Error message with microsoft streets and trips 2009
By corkerm65 on Dec 12, 2008
the message is ...your regristry settings for this application where not copied correctly,it;s telling me to reinstall,doesn;t solve the issue,had to create a shortcut from program files and then run it as administrator,the normal short cut will not open program,i had the 2005 version,same issue went to website,followed all the fixes,none worked
Same Problem
Mar 31, 2009
-   "error message registry settings for microsoft streets and trips didnt copy" . When I run open as administrator it opened as usual ,after I reinstalled it.-   77shadow
Jan 25, 2009
-   I have the same problem. When try to start the program (streets and trips) I receive this message "Your registry settings for this application were not copied correctly. To correct these settings, run Setup again for this application from the location where you originally installed it.My program is install as administrator. Hope somebody can help me
Claude-   claudeletour
Jan 10, 2009
-   I have the same problem. When try to start the program I receive this message "Your registry settings for this application were not copied correctly. To correct these settings, run Setup again for this application from the location where you originally installed it." I did it without result. The OS is Vista HE.-   Guest
Popular Solutions for Microsoft Streets and Trips
Questions and Unsolved Problems for Microsoft Streets and Trips
Do you recommend Microsoft Streets and Trips 2008 Full Version for PC?
Answer
Answer
i've been using street maps 2006 .it wont reinstall comes up with k:\error 1327 the disk is actually... (More)
Answer
oxc004d301 eror when trying to open ms streets & trips
Answer
I can not open Microsoft Street & trips 2008. It was fine one day and not the next. I have... (More)
Answer
I get a error code oxc004d301 streets and trips 2009
Describe your Operating Systems problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Operating System Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
