Question about Nvidia GeForce4 MX440SE 64MB SDR AGP with TV-Out Graphic Card
Overclock MX440 64MB in Vista
Hi, I have installed Vista Home premium on my PC (865GBF, 1GBDDR(400MHz), 80GB SATA, DVD Writer and ASUS MX440 AGP). Can you suggest any good overclocking utility to OC my MX440 in Vista. RivaTuner does not work and tried coolbits, not helpful. Would be happy if you can suggest anything. Thanks in advance.
    President:
  • 2,961 Answers
To be honest, the MX440 is rather outdated, especially with only 64mb sdr, to make gaming experience better graphically, the minimum card you will need would be 256mb ddr and no doubt windows vista would look better also.
Posted on Mar 23, 2007
Help me overclock ASUS P5GC-MX/1333
LOOK IF A BIOS PASSWORD IS SET.
May 26, 2013 | Computers & Internet
Says my system does not meet requirements . Cannot download . Running Windows Vista with Service Pack 1
You need to install Vista Service Pack 2 Minimum System Requirements:
  • Microsoft® Windows 7 Home Premium (32- or 64-bit), Microsoft® Windows Vista™ Home Basic SP2, Windows® XP SP3 (32-bit) or SP2 (64-bit), 1 GHz processor and 512 MB RAM
  • 1024x768 DirectX 9.0c compatible graphics card with at least 16-bit color setting, sound card, DVD-ROM drive
  • 2 GB free hard drive space for installation
  • Windows Media Player 10 or higher
  • CD Writer for audio CD and DVD Writer for DVD
  • Internet Explorer 7 and 8
  • QuickTime player version 7.6 for some functionality
  • One available USB 2.0 port
Mar 01, 2011 | Roxio Easy VHS to DVD for PC
How do i setup sata dvd writer on asus motherboard p5s800. It does not see the writer
Hi dtoitj4, You have to find where the settings are for SATA mode in the bios.
Check the jumper settings on the back of the DVD burner you just installed, make sure that it's set for slave.
Let me know for any clarifications.
micro-
Dec 12, 2009 | ASUS P5S800-VM Motherboard
Hi my ASUS K8S-MX motherboard is not detecting SATA hard drive and Sata DVD Writer. Though my IDE hard drive and DVD Writer is working fine. Please help me with this .
Two thing here that can be the issue.
1. Bad Sata controller onboard
2. Sata controller is disabled in the bios.
The Fix
1. Purchase a independent sata controller there like $25 bucks.
2. Try going into the bios under advanced and make sure its not disabled.
I sure hope this finds your Very Helpful vote! Have a Merry Christmas and a wonderul New Year!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Dec 07, 2009 | ASUS K8S-MX Motherboard
PC Does not boot up with LG SATA DVD Writer
Did you try to move the small jumper next to the connector on the back of the DVD writer.
Then try to choose different places to connect your DVD on the motherboard.
Check if you have the right driver or reinstall it.
Hope its help, don't forget to rate.
Cheers
Aug 19, 2009 | ASUS K8V-MX Motherboard
Unknow ghost CD Drive icon in my computer
go to device manager and disable which ever you want
May 08, 2009 | Microsoft Windows Vista Home Premium...
Boot failure asus a7v 133 motherboard installed a pci sata raid
Hi whistler1410, you need to enter your bios menu. Press the delete key every couple of seconds to load the bios menu.
Once in the bios (See instructions located at the bottom of the menu, to help you move about).
You should see all connected drives at the main menu.
This includes the SATA writer & hard disk drives.
Go to the bios menu, BOOT.
SATA drive even DVD drives are seen by the bios as a master drive. So within the BOOT menu go to "Boot device priority".
The boot priority should read as follows.
First boot device [Floppy disk drive] (If one is connected)
Second boot device [Your SATA DVD writer]
Third boot device [Your primary hard disk drive] (The drive with windows loaded on it).
If you do not have a floppy disk drive than make the first boot device your DVD writer.
Save the bios & exit the bios. You should not receive "boot disk error message anymore".
Run into a problem, post here.
Good luck whistler1410!
Mike
Mar 25, 2009 | ASUS A7V133 Motherboard
Problems with getting bootable disks to be read - Dell/VISTA
Solution:
i) when you start your system press button(F8 or F10 or DEL) so that you can go into BIOS menu now     try explore BIOS menu and see whether
  a) SATA 0 - ST325082045 3.ADG
  b) SATA 1 HL-DT-STDVD +-RW GSA H31
   are just visbile(in sense, you can see them in  BIOS writen ), this will make sure system is able to        detect them, we will be assured that your a)HARD DISK b) DVD writer   are working perfectly ......
    if so without any hesitation format or reload system with  Windows Vista....
ii) if otherwise any one of them or both are not visible in your BIOS Menu like a)HARD DISK b)DVD        writer
   try to open your computer tower and locate cables that are going to ur DVD writer, HARD DISK
   and reseat them(just remove the cable and place them again), by this way we are making sure that    no loose connections are existing..............you can even try new cables .......
   now restart ur system and go in to BIOS menu and repeat the step (i) ....
   if you are enable to see any one or both
      a) SATA 0 - ST325082045 3.ADG ....................HARD DISK
      b) SATA 1 HL-DT-STDVD +-RW GSA H31................DVD WRITER
  then you are having problem with either HARD DISK OR DVD WRITER  and you have to buy them .....
 Thanking you
M. Sridhar
Dec 26, 2008 | Dell Inspiron 531 Athlon 64 X2 4400+...
Nvidia GeForce4 MX440SE 64MB SDR AGP with TV-Out Graphic Card Logo
223 people viewed this question
Top Nvidia Computers & Internet Experts
Terry
David
David
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
