Question about Bunn Pour-Omatic Coffeemaker, 10 Cup White
I cleaned my Bunn pour o matic
I used CLR, did I ruin the machine?
  • themillers13 Jan 10, 2009
    Thanks,
    We have hard water and the build up is bad enough to slow the water down. I will never use CLR on this again! I have ran at the at least 30 pots through it. I just want to make sure that there is no bad taste.
    Genius:
  • 1,689 Answers
If the unit works okay, there is no damage. I would suggest using vinegar, or better to use a recommended cleaner from an appliance dealer, rather than something as strong as CLR.
After cleaning the coffeemaker with any type of cleaner make sure it is properly rinsed out!
Jerry G.
Posted on Jan 10, 2009
  • Jerry Greenberg
    Jerry Greenberg Jan 10, 2009
    Normally, after running 3 pots through the rinse should be okay. With hard water you can run 5 rinses. It is better to use vinegar, or to use the recommended cleaner that the appliance dealers sell.
    Jerry G.
I think my bunn-o-matic VPR needs cleaning and I do not have a manual for this machine. Can you advise on how to do this?
To clean the vpr you will need to take the lid off the machine. Be sure to unplug while doing this. First clean the water tray. You can unscrew the nut holding this tray and clean the tray in your sink. Put the tray back in and put the lid back on. Plug coffee maker in. Fill one coffee pot with vinegar and pour it in machine. After the water finishes coming out let the coffee maker sit overnight. Before you start filling the maker with water at least 6 times, be sure to clean the spray head. Make sure the 5 or 6 holes are free and clear of any build up. Then start with fresh water. Fill the coffee pot with fresh clean water and pour into machine. Let it finish and do this at least 6 times. If you can still taste or smell the vinegar repeat until you cant.
Mar 19, 2013 | Bunn Pour-O-Matic VPR
My bunn pour o matic coffee brewer will not brew. all burners get hot but it will not pump the water out into the filter basket. What could be the cause?
Hello Doug,
This is a clogging issue. Meaning it needs to be cleaned. So what I want you to do, if first read this manual that I am sending you via a e-mail link. Just copy and paste link in browser; I am positive it is just clogged. In the manual it will show you some tips on how to unclog it with tooth pick etc... then you want to flush whole system with water and vinegar. Here is the link to put in browser. http://www.bunn.com/pdfs/commercial/manuals/10424.0000.pdf
Mike
Sep 29, 2011 | Bunn Pour-O-Matic VPR
My Bunn Pour-Omatic Coffee Maker leaked all over the counter when I made my coffee. It was mild for a week or two but became very severe. I am pleased to say I followed a suggestion that I found only by...
Do you have the model and date code located on the bottom of the brewer? If you will call Customer Service at 800-352-2866 we will be able to assist you in resolving this problem.
Jan 15, 2010 | Bunn -O-Matic Corp. 10-Cup Pourover Brewer...
Pour o matic pours water through filter even if un plugged is it just full and needs to get rid of the h2o
YES.
The unit has a tank used to heat the water for brewing.
When you add more water, the unit starts the brew cycle.
Dec 29, 2009 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
Bad tasting coffee
you can always clean a coffeemaker with vinegar, but always pour in cold, so you can do it twice or more, but dont re-use the stuff you just used, wait till it's cold or just use some other.after use clean by let water through 2 or 3 times, (also only cold water)
Jan 28, 2009 | Bunn-O-Matic Coffee Brewer GRW8
BUNN VPR
It sounds like the tank isn't full. Unplug the machine and make sure there is a pot underneath to catch water. Pour clean water into the tank until it starts flowing out. Plug the machine in and let it heat up. Then try brewing coffee.
The way your machine works is that there is a holding tank for the water and it isn't actually brewing with the water you just poured in, it is using the holding tank water. If the holding tank gets low, and you pour water in all it does is fill the tank but nothing will come out.
Hope this helps.
Jul 19, 2008 | Bunn Pour-O-Matic VPR
Bunn Pour-Omatic Coffeemaker, 10 Cup White Logo
599 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
