Question about MGE UPS Pulsar Ellipse Premium 800 UPS System
Pulsar ellipse 500 problem
I have a Pulsar ellipse 500 and suddenly one day when i press the on button it maked a bip noise and goes off automaticly. it is doing it all the time like it cannot stay in the on condition. I change the battery from a working one and it still do the same. Is there a fuse or something inside? cause i cant open it since i dont have a polygonik screwdriver that it need so i cant check.i change the battery using the down door. i m not a technitian so if you can talk simple or with pictures. please help me.
No, you don't have to undo all the screws...
There is a hidden compartment in the bottom (near the fan). Just use a screwdriver to gently prize it open and it will expose the batteries :)
From
Rookie at: www.DomainWorld.com.au
Posted on Apr 25, 2009
Please use a flat screw driver. Press it a bit hard and you can turn the screws and open it. There is a problem with the RELLY. I suggest you see a technician.
Posted on Mar 08, 2007
SOURCE:
Circuit diagram
all MGE UPS systems below 15 KVA is a part of EATON long ago
Sep 26, 2013 | MGE UPS Pulsar Ellipse 500 UPS System
I need to conect to my UPS via my computer . Not sure who to do this?
Is easy, here is how to do it:
  1. Plug your computer in your UPS
  2. Plug the UPS to an outlet/plug
  3. Start the UPS
  4. And done
If you want your monitor conected to the UPS make sure it has 2 spacest to plug them in or use an extension cord with 2 outlets or more.
Hope it was usefull
May 06, 2011 | MGE UPS Pulsar Ellipse Premium 500 UPS...
Hello, could you please let me know the battery type of MGE premium ellipse pulsar 800VA ups? Thanks in advance.
The batteries in an UPS are sealed lead acid batteries. The voltage and amp hour rating depends upon the VA rating of your UPS.
I suggest you shut down your UPS and remove the batteries and get replacement ones that are the same rating as the ones in the UPS. Be careful of the size of the battery, they are a neat fit inside the UPS battery compartment.
Oct 05, 2010 | MGE UPS Pulsar Ellipse Premium 800 UPS...
Ok.. MY PROBLEM IS THAT I TURN ON MY PS3 AND IT MAKES THE SOUND BIP..THEN WITH NO VIDEO ON THE TV OR SOUNFD COMING ITS DOES 2 BIPS AND IT TURN OFF AGAIN,,I HAVE TRY TO LEAVE IT ON A COUPLE OF...
lets try a few things bronx,
lets start by going over the beeps and lights. when you power the unit on. it should go Blue and stay blue. this means the unit is so far functioning correctly.
if your unit turns on lights up blue, then yellow , then red and stays red you have an issue
if you are experiencing the first scenario, press the power button till it goes red. which is standby mode.
then press button again till you hear two beeps, let go. make sure you have all your cables plugged in. this will send you to the diagnostic screen on the ps3 to select anyone of your options. since you are not getting a video display select the display settings and reset yours according to your type tv. if you are using a standard old school tellie, then its 480i, if you are on a plasma or lcd it would be 720p,1080i or 1080p. then you should be good from there
okay, if you are experiencing the second scenario its a much more severe issue. the GPU on the motherboard has gone bad, which is common on ps3s. if it is under warranty contact sony and they will send you out a refurb'd unit. if it is not under warranty there are a few good companies out on ebay that reflow or reball gpu chips on ps3s to repair this known issue.
since you are getting beeps and lights this is one of your scenarios. if you get no lights,no beeps then you got a bad Power Supply.
Good Luck!
Ruben
Jul 19, 2009 | Sony Playstation 3 (PS3) Console
Toshiba qosmio E-10 noises keyboard and start up
Sound like you have a stuck key and the bip noise is the keyboard buffer pverloading.
If you can't unstick this key, you need a new keyboard.
Apr 13, 2009 | Toshiba QOSMIO E15-AV101 Notebook
Ups problem
The batteries need to be replaced. They probably have more than 3 years.
Replace the batteries and let the new ones charge fully for a day and your UPS will work like new after that.
Oct 14, 2008 | MGE Pulsar Ellipse 800 (89363) UPS System
Ipod nano 1st generation trouble! help!
Sounds like a corrupt hard drive.
put it into disk mode
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Find it in "my computer", right click it and select format. Choose the FAT32 option and hit OK.
Once its done, restart your computer and plug in your pod. Start itunes and it should automatically reinstall the ipod firmware.
Nov 30, 2007 | Apple iPod nano
MGE UPS Pulsar Ellipse Premium 800 UPS System Logo
728 people viewed this question
Top MGE Computers & Internet Experts
Marvin
Marvin
Jose Pino
Raj Patel
Are you a MGE Computer and Internet Expert? Answer questions, earn points and help others
