Question about Microsoft Windows XP Professional for PC
My software windows xp had encountered a problem and asks for a geniuna software what should i do
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 108 Answers
Dear sir
you have to apply the crack to activate to full version of windows xp.
please download the crack file from the following site. (you can download the text file ( insturction file) along with that crack file,
www.crack.ms
regards
murali
Posted on Dec 12, 2008
You got to buy a genuine windows XP from retailer...
Windows XP startup error: ppped.exe has encountered a problem and needs to close
Re-Install again the windows.Formatt it again.
There is a different windows XP for IDE Hard Disk Drive, and SATA hard Disk drive.Different softwares.
Maybe you are using the wrong windows XP
Mar 13, 2014 | UPG 12V 8Ah Geek Squad Best Buy GS-700U...
I am in a company that does not have license for all the computers. Recently we received a letter that lawyers will verify licenses. Can I buy a license from any dealer and have it installed in the Pcs ...
That's a great idea and thank you for supporting legal copy of Windows software. My answer to your question is Yes! Definitely, you can buy your own license and install it in your computer. However, I assume that all authorized retailer of Windows are only selling Windows Vista version and up. But if you encounter a store that still sells a legal copy of Windows XP, you can grab that copy. But before buying a software, please check the specification of your computer and make sure that it is compatible with Windows 7, in that way once you have the Bootable CD you will not encounter any problem.
I hope I answered your question.
Thanks a lot!!
Aug 16, 2011 | Microsoft Windows XP Professional
When I try to install the program, it says that I may to use a 32-bit system. I have Windows 7, 64-bit. Does this mean that the game won't work on my computer?
Maybe so. As alot of programs and software still recognizes windows xp and not windows 7. I have encountered alot of similar problems with windows 7 and the same program runs well with windows xp.
thanks,
G.
Jun 27, 2011 | The Learning Company Arthur's Thinking...
It is not starting up
Good day. I suggest for you to reinstall windows and use the repair options. Usually software encounter errors or some files might get corrupted causing your computer not to boot up properly. The repair option in Windows XP will help you to fix those issue. here are the steps to follow:
1. Rule out hardware issues. Windows Repair will only fix software problems. Hardware issues can also cause boot problems (i.e. bad hard drive, memory, CPU, or power supply).
2. Backup. It's always a good idea to backup your important data before making changes to Windows XP. Relax, if you follow these instructions your data will be perfectly safe.
3. Boot from your Windows XP CD. Insert the Windows XP CD into your computer's CD-ROM or DVD-ROM drive, and then restart your computer. When the "Press any key to boot from CD" message appears on the screen, press a key to start your computer from the Windows XP CD.
4. A blue screen will appear and begin loading Windows XP Setup from the CD.
5. When completed loading files, you will be presented with the following "Windows Setup" screen, and your first option. Select "To set up Windows XP now, press ENTER". DO NOT select Recovery Console.
6. Then press F8 to continue
7. Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation, or install a fresh copy of Windows XP.
8. Then just choose repair option to repair your Windows Xp
9 Then it should work. If iin any case that will not solve the issue, you might try to install fresh copy on Windows Xp
Hope this information will help you resolve your issue. Have a great day.
May 24, 2011 | Microsoft Windows XP Home Edition
WMI has encountered a problem and needs to close. We are sorry for the inconvenience.
This is not unusual, Sometimes the software encounters a order that it cannot follow and looks into its error data and sends this message. It maybe a problem downloading an update from Windows, it could be a virus encounter, it could be malware ( Advertisers hijacking your desktop). If it occurs often, then you need to clean somethings out. See: http://social.answers.microsoft.com/Forums/en-US/xpperformance/thread/bb4e514d-9afc-41ba-b926-366d2da5e65e
Dec 07, 2010 | Microsoft Windows XP Home Edition for PC
Im instaling windows xp in Acer Aspire but it
latest laptops do not have compatability
with xp. if you want to install xp you will have to use third party software for accessing hdd & installing XP
Nov 09, 2009 | Microsoft Windows XP Professional for PC
Windows xp media center says has encountered problem needs to clo
Well I would think back to when you started having the Media center problems, and did you make ANY new software installs just before the problem started? If so remove the newly installed program, or try to use "System Restore" to restore your system to a time just before you started having the problems. If this does not work, please post the EXACT wording of the error, eg: "fault in module..." "called from...." or make a screen capture or the error window expanded with all info showing.
Apr 10, 2009 | Microsoft Windows XP Media Center Edition...
Blank/black screen at power on
This is hopefully a possible fix. I have encountered a similar problem with windows xp and vista. the fix I found that will eliviate this problem and a startup-reboot-startup-reboot... If you have your original windows (xp or vista) CD lounch it like you would do to do a system install. As the installation starts it will show ask you if you would like to do a recovery using the recovery console, just press ESC and go on. Press the F8 to accept the license. If Windows is not completly broke, it will find the original installation on your hard drie. It will ask if you want to repair. Press the R key and windows will reinstall your operating system, without destroying your software or data. After it is done the system will go to the windows startup screen. You will need your windows product key located on your machine or on the original software packaging.
I hope this will fix your problem.
Mar 17, 2009 | Dell Inspiron 6000 Notebook
Microsoft Windows XP Professional for PC Logo
99 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
