Question about Tricity Bendix AW1400W Front Load Washer
Washing not being spun properly or machine emptying fully
Tricity Bendix washing machine - washing still soaking after a full cycle & 1100rpm spin. Can only empty drum fully of water by using 'drain cycle'. Drum is spinning & all lights are on on control panel . Advice please
  • pommies Mar 05, 2009
    washing soaked after cycle and not spinning. machine jumping when trying to spin
  • Tricity Bendix Master
  • 3,463 Answers
If it has a filter, remove and clean, check for blockage and or obstuction in drain hose
Posted on Dec 12, 2008
Tricity Bendix AW1400W Loud noise when spinning
The turning tube's belt or bearing may have problem.
If you know how to tighting the drive belt, you may try.
If not, maintenance or service persone should to call.
May 28, 2017 | Tricity Bendix Washing Machines
Tricity bendix BIW103W spins badly, clothes still too wet.
Hi, Your problem is very common and very easy to fix. You will first need to strip the machine down and remove the motor. Once you have done this then take off the motor carbon brushes, These are the little things in cases on the side of the motor casing. These should be at least 1" long! you will find that this is not the case and they will need replacing to resolve your problem. The parts should not cost anymore than around £20 for the pair.
Good luck any problems get beck to me............................
Mar 18, 2009 | Tricity Bendix WDR1040W Front Load Washer...
Problems after getting fluff in machine
Behind the little door is the filter which will be full of this stuff.
Just unscrew and take it out to clean.
Thankyou for using Fixya.
Jan 22, 2009 | Tricity Bendix AW1000W Front Load Washer
Tricity bedix spin query
First of all make sure you have selected the correct spin speed if there is more than one setting.
Check and make sure prog 4 is mot a delicate wash prog, as it will spin at a lower speed if this is the case.
If it has a filter, locate it and remove to clean.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Tricity Bendix AW1000W Front Load Washer
Dryer
We found that we needed to turn down the water inlet to almost off and then the dryer worked when we had the same problem.
Remember to turn it back up again before the next wash
Mar 13, 2008 | Tricity Bendix WDR1240W Front Load Washer...
Tricity Bendix 1000 washer
you need to replace the element. remove the rear panel and you can access it
Oct 22, 2007 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Aug 26, 2007 | Tricity Bendix AW1400W Front Load Washer
My tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Dec 14, 2006 | Tricity Bendix AW1400W Front Load Washer
Tricity Bendix AW1400W Front Load Washer Logo
505 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
