Question about Emerson TC1325 13" TV
VCR/DVD is this tv unable to connect to any kind of vcr or dvd player?? i can't find the input holes anywhere...are they hidden, or do they not exist? I have a TC1365B... inherited from Grandma... any place to hook up DVD player?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, it would appear that the only INPUT possible is through the RF connector. Should this be the case, a workaround would be to connect the RF OUT of a VCR to this RF/ANT/Cable IN of the TV, set the TV to Channel 3. An RG59 patch cable would do the job. Should you want to connect a DVD, connect the Video/Audio OUTPUT of the DVD to the Video/Audio INPUT of the VCR. Incidentally, the regular cable/ant should be connected to the RF IN of the VCR.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 12, 2008
Ok, i want to hook up a vcr/dvd player to my tv/cable box, i want to make tapes of programs i am unable to watch at the time of airing. my tv is a slyvania LD200SL8 LCD WITH built in dvd player. my...
A VCR / DVD player is not a recorder. If it is a recorder you need to advise what input and output ports you have on each of the devices that you wish to connect, then the connection would be from the cable box thro' the recorder and into the TV.
Nov 22, 2017 | Televison & Video
Does it matter if it is a old tv, one that has a vcr, can I still connect?
Yes, you should be able to connect using a coaxial cable, connect the cable to the TV using the Coax (IN) input on the back of the TV.
Jun 16, 2010 | Memorex MVD2042 DVD Player
How do i connect a vcr to a dvd player that is already connected to the tv
First you hook vcr up to tv,
then
On back of dvd player, take your 3 cables, red, white, yellow, and match them up to the input jacks with same color on vcr.
Then turn vcr on to input channel
turn on dvd player
turn on tv to channel 3 or 4
Aug 15, 2009 | Sony HVR-1500 HDV VCR
Unable to separate VCR playback from Sat. Receiver input,both av2
try to find a multi-video selector swicth that the best you can do
Dec 19, 2008 | Dynex DXR24TV 24" TV
Connect tv vcr and dvd player to digital converter box
Yes you can first connect the converter box to the antenna first. Next hook the tv out on converter box to vcr in on vcr. Next hook the vcr out to the tv in and watch vcr and converter box on channel 3 sometimes channel 4.on the actual tv and of course change channels with converter box remote. For dvd player hook it straight to tv with red,white,and yellow cables that come with your dvd player. Then to watch dvd player if it's hooked up that way you have to put your tv on a input like video 1 or input 1. This can be done by using the tv remote and looking for a button that says tv/video or input or source button. This is some common names for that button on tv remotes.
Nov 02, 2008 | Insignia Digital-to-Analog Converter for...
Connecting a freeview box
Your dvd player should be connected to the TV INPUT under norma conditionsl.What kind of recorder are you using? VCR player ?, Is it also a VCR recorder ( one cannot assume because I happened to own a VHS\vcr PLAYER, not player & recorder)Is Your VCR recorder? Then It must be connected to freeview box with universal scart to RCA converter box.You have "" dvd player in av2, vcr av1"" where? TV? freeview box scart connector ?
You will need scart to RCA converter box for sure.
Aug 08, 2008 | Televison & Video
I have a 30 year old tv w/cable. I want to install a dvd/vcr combo player. What kind do I need? I've tried one and it didn't have the right connection.
If the original TV doesn't have audio/video inputs, you'll need a DVD/VCR player that has a built-in RF modulator. A RF modulator takes the audio & video and modulates a RF carrier to one of the channels that your TV can receive. In the U.S., this is usually channel 3 or 4. If the DVD/VCR player has a built-in tuner, connect your cable to the RF input of the DVD/VCR player and the RF Output of the DVD/VCR player to the cable input of the TV. This way, you can receive your cable channels through the DVD/VCR player and watch movies as well. If your DVD/VCR player does not have a built-in tuner, you can put a RF switch inline that will allow your TV to either receive the cable signal or signal from the DVD/VCR player.
- Jim
Jul 03, 2008 | Televison & Video
Hd tv to vcr
What model and manufacturer DVD/VCR combo are you using. if it has a HDMI port, you should buy a HDMI cable to your combo player than to your HDTV (most don't have this High Definition port.) 6f3606c.jpg
 otherwise, it probably contains a composite port, connect the red to the red (Left) white to white (mono) and yellow to yellow (Video) than connect the wires to the matching port on your HDTV) then switch the input to AV or Composite. 9701d83.jpgb5e3eb0.jpg
If this fails, you need a coaxial cable.85dec5e.jpgconnect a coaxial cable to your player then to the coaxial port on your tv. change the input to "either Coaxial, Cable 3 or any input that sets it to coaxial input.
Mar 24, 2008 | Sanyo DVW-6100 DVD Player/VCR
Unable to get sound when connecting DVD player to TV
connect one end of white cable to dvd/vcr audio output and the other end of white cable to tv audio input L .
connect one end of yellow cable to video output on dvd/vcr and the other end of yellow cable to video input jack on tv
If you connect like this after checking you connections this should fix problem.
Jan 02, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
How to record from KS 4110 DVD payer to VCR
Connect your DVD player to your VCR ( the out put from the dvd player is connected to the input of the vcr) then connect your vcr to the tv( the output from the vcr is connected to the tv)
Set your tv to what ever channel you connected your vcr to and hit the tv/vcr button on your vcr remote until you get the vcr displayed on the tv.(ensure your vcr is on when doing that)
now when you get your vcr displayed on the tv , turn on your dvd player and set your vcr to what ever channel you got the dvd player connected to(e.g INPUT 1 etc)
you dvd player should now be visable on your tv
simply insert a blank vcr tape and play your dvd and hit record on your vcr
Aug 26, 2007 | Koss KS4110 DVD Player
Televison & Video Logo
117 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
