Question about Sentry Fireproof Safe
Change combination for Sentry 1250 safe
The current combo has 3 numbers
4 Suggested Answers
SOURCE: Changing the combination
These sentry safes dial combinations are not built to be changed as they have no key change hole. Switching the order of the tumblers could be done by a trained locksmith. I would suggest buying the electronic sentry safes as these safes can be reprogramed.
Posted on Aug 05, 2010
SOURCE: know combination, but cannot open sentry safe 1250
Make sure you are working the dial properly for this type of safe. With the door lever fully counter clockwise, turn the dial clockwise a couple turns to start. It should turn quietly. Then turn the dial counterclockwise (LEFT) to the first number in the combination. Now turn the dial clockwise (RIGHT) a full turn passing the first number again, and additionally clockwise to the second number. Then turn the dial counter clockwise from the second number directly to the third number. Try to open with a sharp movement of the door lever clockwise. If this does not work the first time try adding or subtracting ONE to each number in the combination in case the mechanism is worn. If it still does not work it is time for a drill and a power saw to cut the thing open!
Posted on Mar 15, 2009
SOURCE: how do you open a sentry 1250 combination safe? I have the number
Locksmiths agree If your safe doesn't have a key, skip Step 3.
Turn the dial to zero.
Insert your sentry safe key and turn it until the plunger pops out.
Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
Turn the dial to the left to the last number (stop the first time on your last number).
Pull the handle down; cracking the Fireproof Sentry Safe open.
Posted on Aug 09, 2010
Sentry safe 1250 lost combination
Lost Key or Combination ' SentrySafe
https://www.sentrysafe.com > Support
Request a key replacement and a combination recovery for your SentrySafe product with our quick-and-easy replacement and recovery process.
Product Manuals ' SentrySafe
https://www.sentrysafe.com > Support All Support · Find Your Model or Serial Number · FAQs · Lost Key or Combo · Videos · Product Manuals · Contact Us · Check Your Electronic Fire Safe · SentrySafe Store · Visit SentrySafe on YouTube · Visit SentrySafe on Facebook · Visit SentrySafe on Twitter · Visit SentrySafe on Google Plus · Visit SentrySafe on Pinterest.
See the video, open it with a sharp bump and reset it.
Sentry safe 1250 lost combination Google Search
Dec 12, 2017 | Sentry Home Security
Don't want anybodythat might know my original safe combo to get in it door open cover off know original safe combo have all other info of ownership can I change combo of 1250 sentry safe
If the door is opened..Then you would need to remove the cover to the lock at the back..You will see a screw on the last wheel of the lock..Move that screw into a different hole on the wheel..Then you can dial the wheels to the lever..Each wheel is a number..This will give you a new combination..My advice to you would be to locate a Safe Tech/Locksmith..Have them do it for you..
Apr 18, 2017 | Sentry Home Security
How to change combination of model 1250 sentry fire safe
dear sir i was given a sentury safe#1250 ,serial #g969560 the safe is open how do i figure out the combination?
Feb 08, 2013 | Sentry Fireproof Safe
How do you open a sentry 1250 combination safe? I have the number
Jun 06, 2010 | Sentry Fireproof Safe
Have Sentry 1250 safe. I have the combo but can't get it to work.
A1 locksmith will tell you.
Pull the handle down; cracking sentry safe open.
Jan 29, 2009 | Sentry Fireproof Safe
Jan 04, 2009 | Sentry Fireproof Safe
Lost combination for Sentry 1250
Lost your sentry safe combination. First, find your safe’s Serial Number. The Serial Number is printed on the small label on the right side of safe ( on paper tag near hinge) or under handle. just note your model # and the serial#. sentry safe lost combination and the opening instructions.
Nov 16, 2008 | Sentry Fireproof Safe
Need assistance opening my Sentry 1250 safe. I have combination but do I start at 0 and pass the first number then stop 2nd time around at first number then go straight to the other 2 numbers?
Locksmith instructions for sentry safes
on how to dial open sentry fire safes.
NOTE: If your safe doesn't have a key, skip Step 3.
May 06, 2008 | Sentry Fireproof Safe
I can't seem to unlock my safe Sentry 1250.
Also make sure you are executing the combination in the right steps... For mine (a three-number combo), these are the steps that work:
* turn the knob to the LEFT, pass 0 at least THREE times and stop at the first combo number
* turn the knob to the RIGHT, pass 0 ONCE and stop at the second comb number
* turn the knob to the LEFT and go directly to the third combo number (do not pass 0, do not collect $200)
Feb 25, 2008 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
2,867 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Hannah Johnson
Level 1 Expert
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
