Question about Nokia 1100
My problem is i need the barring password of nokia
I want to active the incoming call but need the barring code can you help me to solve my prolem because i don't have a network coverage on my cell phone
    Brigadier General:
  • 7,752 Answers
Try 12345
Posted on Dec 27, 2008
I forgotten my phone barring password That's why has been Blocking my incoming outgoing call. How can i solve that problem. please kindly help me. Thanks
What is your mobile and model ?
If you forgot the security code you have to reset you mobile....... Its the only way to use your mobile again. After resetting you can enter a new security code again.
If you use nokia or alcatel mobile means just visit here Unlocking4u.com for the master reset code service and get the reset code........
Apr 05, 2012 | Cell Phones
How to bar my incoming call
just go to settings then select security settings... then select call barring services...select incoming calls only.. take note that when you select incoming calls and barred it you cannot also recieved sms or mms... ok... then activate it and it will ask for barring password.. a 4 digit password.. just put the default password 1234... ok... enjoy...
Aug 29, 2011 | Nokia N72 Cellular Phone
Please help mo to anblocked my call barring password.. i forgot my password and now it is blocked. :(
Call Barring - Enables you to restrict or bar certain or all types of calls to and from your mobile phone, i.e. outgoing calls, outgoing international calls, incoming calls. Barring is activated with a personal code.
Call barring is a mobile phone feature that allows the user to set certain prohibitions on incoming or outgoing calls. This is an effective means to prevent the phone being used to make expensive international or premium rate calls, particularly when the phone is to be used by people other than the subscriber.
Many companies that provide handsets for business use now employ call barring as a security measure, to control their use and restrict calls to pre-approved numbers. The user's personal code must be used to activate this feature.
How do I get it?
Contact your local Service Provider. You will need a four digit barring code. Initially this will be 0000. You should create a personal barring code for security. Please consult your cellphone's instruction manual.
What does it cost?
This service is free.
Also you can deactivate it from your cell phone..
Different cell phones have different setting functions,
You can try these out. It's the general way to deactivate call barring (NOKIA) .
Follow the below instruction:
Go to Menu,
Enter settings,
Scroll to Security,
You will see call barring on that list,
Click on it,and scroll to last option and you will see cancel call barring.
Your cell phone might not be the same with these functions,but the procedure are aways the same..
Good luck.
Jun 17, 2011 | Nokia C3 Cell Phone
I don't know what is the password of call barring belongs my cell phone SGH-L760
hi,
Before you can activate these barring services you will need a barring code from your service provider. Call Barring can not be activated if Call Forwarding diverts are already in use.
To Activate: * 330 * BARRING CODE # [SEND]
To Cancel: # 330 * BARRING CODE # [SEND]
To Check: * # 330 # [SEND]
All Outgoing Calls
To Activate: * 333 * BARRING CODE # [SEND]
To Cancel: # 333 * BARRING CODE # [SEND]
To Check: * # 333 # [SEND]
All Incoming Calls
To Activate: * 353 * BARRING CODE # [SEND]
To Cancel: # 353 * BARRING CODE # [SEND]
To Check: * # 353 # [SEND]
All Outgoing Calls
To Activate: * 33 * BARRING CODE# [SEND]
To Cancel: # 33 * BARRING CODE # [SEND]
To Check: * # 33 # [SEND]
All Outgoing International Calls
To Activate: * 331 * BARRING CODE# [SEND]
To Cancel: # 331 * BARRING CODE # [SEND]
To Check: * # 331 # [SEND]
All Outgoing International Calls Except To Home Country
To Activate: * 332 * BARRING CODE# [SEND]
To Cancel: # 332 * BARRING CODE # [SEND]
To Check: * # 332 # [SEND]
All Incoming Calls
To Activate: * 35 * BARRING CODE # [SEND]
To Cancel: # 35 * BARRING CODE # [SEND]
To Check: * # 35 # [SEND]
All Incoming Calls When Outside Home Country
To Activate: * 351 * BARRING CODE # [SEND]
To Cancel: # 351 * BARRING CODE # [SEND]
To Check: * # 351 # [SEND]
Canceling All Call Barring # 330 * BARRING CODE # [SEND]
i hope it will help you...
Apr 13, 2011 | Cell Phones
I have a nokia 2730c, my number is currently barred, do you know what the code for cancelling the barring? Thank You
hi,
All Outgoing Calls
All Incoming Calls
All Outgoing Calls
All Incoming Calls
Apr 13, 2011 | Nokia 2730 Cell Phone
I want to knw hw i cn use my nokia 2700c security setting like wt is barring code and pin codes (and plz gives this two default codes )
PIN code is for simcard security the default is 12345...But if what you say is Locked code ,its the security of phone the default is 12345 ...about Barring code ,here is some tips...
All Outgoing Calls
All Incoming Calls
All Outgoing Calls
All Incoming Calls
Apr 13, 2011 | Nokia Classic 2700 Cell Phone
Hwo to block the incoming call from a particular number in Nokia E5 mobile with the options with the mobile
You can bar the calls that can be made
or received with the device (network
Make calls 35
© 2010 Nokia. All rights reserved.
service). To modify the settings, you
need the barring password from your
service provider. Call barring affects all
call types.
Select from the following voice call
barring settings:
Outgoing calls - Prevent making
voice calls with your device.
Incoming calls - Prevent incoming
calls.
International calls - Prevent calling
to foreign countries or regions.
Incoming calls when roaming
- Prevent incoming calls when outside
your home country.
International calls except to home
country - Prevent calls to foreign
countries or regions, but allow calls to
your home country.
To check the status of voice call barrings,
select the barring option and
Options > Check status.
To deactivate all voice call barrings,
select a barring option and Options >
Deactivate all barrings.
To change the password used for
barring voice, fax, and data calls, select
Options > Edit barring password.
Enter the current code, then the new
code twice. The barring password must
be four digits long. For details, contact
hope this helps
John
Jan 31, 2011 | Computers & Internet
My mobile nokia n72 i need barring password from international call,incoming calls, wat to do pls sir help me waiting 4 u
This is the code you need to change call barring settings that are stored on the network. The default code is set by the network (0000 or 1919 for Vodafone,1111 for Orange,0000 for O2)). You can change it if you like, but make sure you don't forget the new code.
Dec 19, 2010 | Nokia N72 Cellular Phone
Don't know the password to de-activate call barring
how to release the blocked password of call barring
Jul 15, 2009 | Nokia N70 Cellular Phone
Nokia 1100 Logo
100 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
