Question about Acer TravelMate 517TE Notebook
Acer Travel mate 517TE C MOS low battery warning msf at Power up
During power up/boot the msg CMOS bettery low is displayied and if you clear it the system will continue to operate. You need to set date and time all times you power on and off.
Is there any C-MOS battery which need to be replace . Where this si located and if possible to have PN. model I can buy in a store.
Thank and kind regards
Romolo
  • rq_sdintl Dec 12, 2008
    Romolo
    Problem Solver:
  • 5 Answers
If you clear the cmos you are just loading the defalt bios settings but not solving the problem.
In this case you dont have to clear the cmos but instead replace the cmos battery.
Posted on Dec 12, 2008
Clear cmos how to;'?
What type of computer and motherboard ?????
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Power down the system and disconnect the power cord.
Wear an anti-static wrist strap to avoid electrostatic discharge damage to the Asus motherboard or CMOS chip or other sensitive components.
Remove the cover and locate the CMOS coin cell battery and remove it from the system by gently pushing on the retaining clip and popping the battery out although on some motherboards cmos batteries are soldered in
Discharge the CMOS chip by leaving the battery out of the system for up to an hour, depending upon the particular chip and motherboard combination.
Replace the battery and replace the cover on the system. Connect the power cord and boot the computer.
Save changes if prompted by the BIOS for system memory, drives detected, and other settings, and set the date and time if prompted at this time, or alternately set the date and time when the operating system finishes loading.
If your computer does not have a CMOS battery or you're unable to find it you'll need to do a hard reset on the CMOS using a jumper or dip switch on the motherboard.Information on finding these can be found through your computer or motherboard documentation.
or you might set failsafe or optimised defaults
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaultsor load optimized defaults press escape then press f10 to save to cmos to restart
Dec 03, 2013 | Computers & Internet
How to remove bios password
Hi JM,
On the motherboard, there are jumpers to reset the board, but you have to do it while the power is off. you can go HERE and put in your system info, which may help you find out how to do this or to reset the password without jumping the system. I found on another site the following:
"If the user can boot the Acer, he/she may be able to reset the BIOSpassword using Acer eSettings Management.
  • Click the Start button
  • Click the All Programs menu item
  • Click the Empowering Technologymenu item
  • Click the Acer eSettings Managementmenu item
  • Once inside Acer eSettings Management, click the Securitybutton.
Acer refuses to assist customers with BIOS password issues. The only option they discuss involves sending the laptop to them and paying a $100 fee."
I hope this is helpful to you
Joe
Sep 07, 2011 | Acer Computers & Internet
Should i use my new acer 5760 on mains power when possible
It depends upon how much time you run your laptop on battery power, you can keep an eye on the battery charge level when you connect it to mains power. You do not need to keep it on mains power all the time, only when the battery level drops to a low level and needs charging.
The laptop will warn you when it is low on battery power.
Aug 29, 2011 | Acer Travel Mate 7720G-932G50MN Notebook
Acer laptop was given to me needs password bypass, can not find BIOS battery or link
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there hope this helps
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Jul 13, 2011 | Computers & Internet
How can i swich on my acer aspire 5630 it ask me for hdd pasword
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Jun 11, 2011 | Computers & Internet
Low battery warning message on boot up
I'll give you the info for the cmos battery but afterwards observe any other issues with your notebook. Your notebook is not new anymore and may need other servicing besides a new cmos battery.
It should be housed driectly undeneath you notebook on a panel you can remove that houses the ram.
If you still cant find it, you may have to physicaly take apart the unit. I would search under the keyboard and all four corners of the motherboard and center. Just in case.
Let me know how it goes.
P.s: Be very careful If you are not use to opening up notebooks then I suggest taking unit to a professional for them to replace the cmos battery.
Mar 07, 2010 | Acer TravelMate 244LC Notebook
How to remove bios password from an Acer Travel Mate 5730
You can take the CMOS battery off for half an hr and then put it back and restart. that should clear the BIOS password.
Thanks
Oct 24, 2009 | Acer Computers & Internet
Break bios password in acer 2420 travelmate laptop
remove the cover which has your power button and covers the LCD cables. Remove the keyboard and flip it over, being careful to not pull too hard on the cable. There's 2 small triangular silver connection pads beside the keyboard connector on the main board - connect them together and power on your computer (flat screwdriver works fine). Press the f2 key - you'll find it doesn't prompt you for a password. You can lift off the connections now. Go to exit and save changes, and you're password free.
. . <-connect these
. . . __________________
. . . __________________ <-keyboard connector
Apr 05, 2009 | Acer Computers & Internet
MY PC HAS BOOTING PROBLEM
Hi bridey28, when you replaced the cmos battery & the bios did not maintain the correct time than the cmos is not at fault. More likely its your power supply. The cmos receives its power (Recharge) from the power supply. An average cmos battery should last for 5 years. The fact that you attempt to power up the PC & you have to wait, points to a power supply problem. Not a bios problem.
Bios corruption is rare, unless you have tried to flash the bios & it failed. Replace the power supply before attempting flashing the bios. Every manufacture warns against flashing the bios. Only flash the bios if your 100% sure that it will correct a bios malfunction. If the issue presist after replacing the power supply, Intel has instructions of (How to flash the bios) on their site.
Here are the instruction from Intel for your MB model number.
http://downloadmirror.intel.com/5519/ENG/BIOS%20Update%20Readme.pdf
You'll need this link to download the bios file;
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=899&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go%21#SAP
Good luck bridey28!
Need more info, post here.
Mike
Jan 14, 2009 | Computers & Internet
Asus p4s533 will not boot after replacing fan + heatsink
Try to remove the processor, then clear it with contact cleaner, then plugin it again..
There isn't beep : Processor, and long beep is memory..
Hopefully this be of some help/idea..
Nov 25, 2008 | ASUS P4S533-MX Motherboard
Acer TravelMate 517TE Notebook Logo
364 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
