Question about Alpine CDA-7940
Face Plate My display is not working on my face plate. What can I do to fix this? Everything else works.
    Problem Solver:
  • 10 Answers
TRY RUBBING A LEMON ON THE CONNECTING MEDAL LIKE WHERE A CORLESS PHONE OR PHONE BATTERY HAS THERE MEDAL CONECCTIONS AND CLEAN IT WELL IF NOT NEW FACEPLATE OR BAD BRAIN HEADUNIT'S DO GO UP MAWYBE INTERNAL FUSE WHICH IF YOU REPLACE IT ONCE AND IT DOES IT AGIAN DEAD HEAD
Posted on Jan 15, 2010
    Novelist:
    Champion:
  • 218 Answers
If this is a "flip face" type of display then you may have a broken lead in the ribbon cable that connects to the main board from the flip face. This is a very common problem. You'll need to replace that ribbon cable.
Posted on Mar 16, 2007
Display OK lcd display is faded out. This is normal with time
Posted on Aug 20, 2007
I have a non-lighting Cobra 29 NW face plate, or EL Driver problem . EL Driver is the small metal box mounted inside, to the side, of the the Cobra 29 near the channel selector control . Can anyone tell me...
that is a power inverter. dc to ac inverter. 13-14volts to 40+ volts ac. to run the el display.. if the display is pulled away from the face like the glue is coming loose that indicates the el display is burnt and will not work unless replace the face plate the el face.. you should have 45volts AC on the two wires feeding into the main chassis face to the el display.
Nov 28, 2009 | Cobra 29 LTD CB Radio
JVC KD -S680 needs help
maybe short circuit or similiar problem inside since its geting hot, probably not a problem with the faceplate I would remove the cd player from your car and take it to a professional for a diagnosis / repair estimate. Can't solve this one with text only.
Jun 18, 2008 | JVC KD-S680 CD Player
I have a Kenwood KDC MP532U. The face plate will not display.
it more than likely has bad solder connections inside the radio on some surface mount resistors usually located on the right front of the radio as it faces you.
Sep 16, 2009 | Car Audio & Video
Alpine 7835 display lights not working, everything else is fine
if it's not under warranty, I would advise taking the face plate apart and checking for burned spots on the board and using compressed air to remove anything that is conductive that may cause a short in the face plate. The face plate should be really easy to take apart.
Feb 10, 2009 | Alpine CDM-7835
Alpine CDA-9830 doesnt want to work
the cda 9830 and 9831 are known to have issues with the face plate connection that cause all kinds of issues. remove the face plate and clean the contacts on the face plate and the unit.
Feb 07, 2009 | Alpine CDA-9830 CD Player
KRC-703 display does not work, sound does?
Check to make sure the right face came with your unit, I had an alpine once that did the same thing when I accidentally grabbed my friends face plate. Everything worked but the LCD. Check the model numbers to compare
Jan 31, 2009 | Car Audio & Video
Face plate buttons wont work
This is actually a common problem with more than just that radio. Sometimes the pins on the back of the face plate need to be cleaned. Take the face plate off, take a Q-tip and dip it lightly in some rubbing alcohol. Then use that to clean the metal pins on the back of the face plate. Make sure it is completely dry before you place the face plate back on. If this does not work, your better off replacing the whole thing.
Jan 20, 2009 | Alpine CDM-7874 CD Player
Psp anolog button faulty?
You just remove the face plate again and check it now your PSP is working OK if so there is some misalignment while placing the face plate on PSP and suppose your fault still remains same without face plate also then there is a possibility of Analogue button is being damaged which should be changed.
Feb 27, 2008 | Sony PlayStation Portable (PSP) Console
Dropped the system everything working but will allow me to go to the map screen
Did you try to reset the unit? Place you thumbnail in the groove located under the Garmin logo on the face plate. Gently pull off the face plate. Press the reset button. Turn the unit back on and see if it works - Of course replace the face plate carefully. Good luck! Dr. Know
Dec 20, 2007 | Garmin StreetPilot C330 GPS Receiver
all radios like your has two power inlets one is battery and the other is Acc or Ing. The battery line keeps power in the radio after you turn off your car both lines must work for the radio to turn on it sounds like a resister burn out thats why your face plate was warm.
Sep 25, 2006 | JVC KD-S680 CD Player
Alpine CDA-7940 Logo
291 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
