Question about Fisher and Paykel DEGX1 Electric Dryer
Need to reset fisher paykel DEGX1
Where is the reset switch for these units and how do I reset it? I've pulled the front off of the dryer and looked to the left side (see two yellow colored wires running to a small rotary switch but I don't see anything else.  Oh and what is that little white plastic rotary dial?
thanks!!
  • 145 Answers
That appliance is fairly complicated. If you want to service it yourslef, my honest answer is to get the factory service manual from fisher paykel. You can get it here:
http://fisherpaykelparts.net/index.php?categoryid=115&productid=39
Posted on Dec 12, 2008
My Fisher Paykel DEGX1 US dryer has no power after I reset the manual thermostat and vacuumed lint from inside the dryer and outlet pipe. It beeps when I plug it in so power is coming to the unit.
if the unit got backed up with lint and over heated then its a good chance that the Non resettable safety temperature switch has gone , you'll find it just by where the pipe exits the dryer , should have two wires on it and should be about the size of a nickel id bet its open .
Dec 16, 2016 | Fisher Dryers
Where is the reset switch located inside dryer housing?
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Oct 06, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Degx1 dryer where is the reset button on this machine ser# EHN 302448 fisher-paykel
Jul 23, 2010 | Fisher and Paykel DEGX1 Electric Dryer
hi how are you...my name is michael...you said you reset the manuel reset on the hi limit ....sounds like one of your heaters is staying on ...ran into a problem a month ago....the control board on the bottom right side was keeping power on to one of the heaters..just plug in the dryer...take front off of dryer,front panel...put your head down by the heater ,see if its coming on an off..do not touch an thing ,make sure not to touch anything...so you dont get shocked...if it is the problem replace the main control on bottom...number for fisher an paykel..1-888-936-7872...my phone if need futher assitance is 1-843-384-8474...take care...hope this helps .....doctor airr appliance repair...michael....
Mar 25, 2010 | Fisher and Paykel DEGX1 Electric Dryer
FISHER PAYKEL DRYER
there is a reset button located inside the front panel on the dryer. Try pushing it.
Jul 14, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Fisher paykel degx1 electric dryer
Restricted venting is the most likely cause, they did change the thermostats a couple years ago. the small t-stats should look cut out on the metal side they should not be solid, also check to make sure the elements are not shorted to ground.
Feb 08, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Fisher and Paykel (NZ) tumbler dryer
Try switching off the power to the machine for 5-15 mins and then re-switch power on
Had same symptoms with my multi-temp F&P front load dryer.
Andy
Nov 30, 2007 | Fisher and Paykel DEGX1 Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Logo
453 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
