Question about Canon CLC 1110 Copier
CLC 1110 E71?0007, E071?0002, E072 error codes.
Dear all,
On my CLC 1110 copier machine, I have an error code E71 – 0007 and some times E071 – 0002 and some times E072,
Theproblem is that when I turn on the machine the error code appearsimmediately after seconds of turning on the machine, or some times whenI passed the warming process and when I try to make copies, the machinestops and show me a jammed paper error, the paper do not make even awhole single rotation and the machine stop. any suggestions
  • Chris Coughlin
    Chris Coughlin May 11, 2010
    Will the paper make it to the transfer sheet? If not the problem may be with the transfer drive belt is worn out and is skipping when it is turning.
On my CLC 1150 copier machine, I have an error code E071 – 0002.
Sir plz send soluation this error
Posted on Jan 21, 2009
    President:
  • Canon Master
  • 990 Answers
Drum motor defect, replace drum motor assembly.
Posted on Dec 16, 2008
  • Everett Lin Dec 21, 2008
    Dear Sir; Since last time I post out your copier's problem I don't know have been taking care, please let me know I really concern about the trouble your copier has. good luck! If you need more help I'm always here, But don't forget give me a good rating.THANK YOU !!!
Canon CLC 1180 Copier Error Code: E071 0007
E071 / E072 / E073
Transfer Frame Connector
Poor Contact due to toner scattering around Transfer Connector
Replace Connector FG6 0948
TD Cleaner assy
Motor M8 being overloaded. Drive shaft from motor goes through long plastic bearings these were getting clogged with toner and oil
clean drive shafts
Transfer driver PCB
Static discharge onto transfer driver from peeling off old TD sheet too fast
Replace Transfer Driver PCB (FG6 - 2579) Remove old TD sheet SLOWLY to prevent problem.
Oct 21, 2011 | Canon CLC 1180 Copier
MI get an E072 at the atm, what could the problem be?
E072 refers to the cleaning drum motor transfer.
The transfer drum has a sensor on the inside that allows the internal mechanism turn initial position, from there to retention, transfer, separation and cleaning. This mechanism is easily positioned to the starting position from the service mode> FUNC, BRUSH, HP. If the problem persists, you have to remove the drum and check smooth transfer care to check their points of support to the main axis, sometimes is slowed by a rubber strip side to slip out of place becomes entangled in the shaft and causes this error.
I recommend you check this engine, in some occasions the main door switch when it flamed this problem also gives you disassemble and thoroughly clean your platinum.
May 05, 2011 | Canon CLC 1110 Copier
Cano CLC 1120 error E004 0203 E072 0203 the machine turns on and off the merger does not light not heat MOTHERBOARD TESTED OK, FUSION SYSTEM TESTED OK, TRANSFER SYSTEM TESTED OK, WHAT SHOULD SPARE CHANGE...
Hi
This error is caused due to faulty thermister however; you can check the fuser unit for any jammed paper around the upper fixing roller and try to clean that area. After this is done try to clear the error by entering the service mode, to enter press Additional functions, #. Then go to #7 Printer and press OK, then go to #4 printer reset and press OK, yes= *. If the issue returns then replace the thermistor. Hope this helps...please post back for further assistance.
Daniel
Mar 03, 2011 | Canon CLC 1120 Color Copier
I got an error code on my canon clc 1100:
E071 0007
Aug 19, 2010 | Canon CLC 1110 Copier
Canon CLC 1100 E072 0202
E072 0202 means :
The transfer drum cleaner brush motor (M8) is faulty.
The polishing roller motor (M9) is faulty.
The motor drive system is subjected to an overload.
The attraction/transfer locking cam motor (PM7) is faulty.
The attraction/transfer locking cam HP sensor (PS8) is faulty.
The registration path driver PCB is faulty.
The DC driver PCB is faulty.
The CPU PCB is faulty.
The attraction/transfer looking cam HP sensor does not go '1' within 4 sec after the attraction/transfer locking cam motor has started to rotate.
May 06, 2009 | Canon CLC 1000 Color Copier
Canon CLC 1130 Code E 072 0202
faulty.
faulty.
Mar 12, 2009 | Canon CLC 1120 Color Copier
Re: Canon 1140 E072 0002
change your transfer cleaning assy.
Aug 31, 2008 | Canon CLC 1140 Copier
E072 error CLC 800
i need a sub code like e072-002 or 003 and so on because it can be several things generally it has to do with yopur transfer drum any where that macvhine is way outdaTED AND THERE ARE VERY FEW THAT CAN SOLVE YOUR PROBLEM
Jun 04, 2008 | Canon CLC 1120 Color Copier
E072 - 0002
most of the time if you replace the transport cleaning unit it fixes the fault. on one machine i had a break in the wire lume that caused the problem. also make sure you don't have a piece of paper jammed in the unit.
Apr 09, 2008 | Canon CLC 1120 Color Copier
Canon CLC 1110 Copier Logo
1,024 people viewed this question
old marine
old marine
