Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Machine fills up with water
Hi:
My machine (whirlpool Easytronic 1000) doesn't rince properly and leaves the inside full of water.
There's a filter on the front side bottom right and underneath it there's a blue item, with a shape similar to a propeller.Can it be removed? and if yes how?
thanks in advance
  • lex2000 Dec 20, 2008
    i checked the lid switch, water pump and the motor seem to work as i was able spin. how do i check the timer control??
  • 36 Answers
Dear Customer
Please perform the following checks
Please rate this,Thank u
Posted on Dec 17, 2008
Why does the aquapump light come on when there appears to be no fault on my easytronic 1000 washing machine
hi this fault could be the programmer try selecting spin cycle see if it skips programs
regards
shaun
Oct 29, 2011 | Washing Machines
Hi...my washer goes through cycles and then stops at "light" . It won't go through rinse and spin. Help
Make sure your cold water tape is turned on and the screen in the water valve is not plugged up, it may be trying to fill with cold water and cant get any, try filling the washer with cold water on a "wash" cycle to confirm it it fills with "cold" then just the rince cycle ion the timer may be faulty and would need to be replaced
Aug 25, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Keurig B70 won't stop cycling water. it just keeps draining the resevoir. Water is cold, not heated.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Feb 02, 2011 | Keurig B70 Coffee Maker
The drum doesn;t turn during wash or spin cycle
Kindly remove the back panel of the unit and check whether the belt is properly fixed if it is ok means check the wire connection if everything is fine. kindly check the motor humming sound once the water is filled if you find the humming sound means kindly replace the motor
May 18, 2010 | Whirlpool LHW0050PQ Front Load Washer
The cold water keeps running in the rinse cycle. it nrver fills up it drains out as it flows in
you kind of lost me with that one, but the washer should spray in cold water when in the rince cycle , spining , draining, and spray of cold water. Thats a normal rince.
Dec 12, 2009 | Whirlpool LSQ9600L Top Load Washer
Aquarius df61 fill problems. My dishwasher does not fill with water on either the wash or the rince cycle. How can this be fixed
check the float on the inside of the machine. if it is stuck up, the machine assumes it is full of water and will not allow any more to enter. it looks like little cone or hat and should move freely up and down. if that is okay, it has to be the water inlet valve. good luck
Oct 25, 2009 | Dishwashers
Washer calypso
Unplug your machine for 5 min then turn on spin to remove water. If water won't go you have a bad water pump. Code FL refers to a low water flow problem ( won't fill fast enough ) or old water still in tub.
Next you need to turn off the water ot the unit and remove the water lines. Look into the water inlets on the washer to see if the dirt screens are clogged and not letting water into you unit at a fast enough pace.
Your unit has a water level sensor and should agitate when full, but I believe your machine might be "timing out" i.e. not filling as fast as your unit expects so even though it doesn't fill all the way it begins agitating because it has taken too long to fill. Good Luck!
barneyluc
Oct 03, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
97 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
