Denon Protection Mode Question
Hi Tech48,
I was really happy to come across this site and your reply to the Denon AVR post about the protecion mode. You sound like the only guy that really knows whats going on. You said generaly the problem is one of 3 things and I checked the other two but what about this one?
Problem 1. This is the most common problem. One of the front channels shorts out. On the big heat sink the front channels are at each end. It is the front left channel (close to the display) This requires that the output transistors be replaced as well as some driver transistors and some resistors and a capacitor. Lots of work for a blown channel. Denon has put out a bullitin to upgrade the bias transistor and change a couple of resistors to help compensate for this failure. That channel overheats more than any other channel.
Is there any chance you can get more specific on this repair? I have the service manual and schematics and I am a technicin in training. I recently started working in a electronics lab and this is a little project I'm taking on.
Any expertise would really be appreceiated. A guy gave me this receiver and said I could keep it if I got it going. Its a AVR-1907. he said a power surge hit his house and it didn't work afterwards.
Thanks a lot, Grant
  • dynamike May 11, 2010
    Hi, tech48... I appreciate you sharing your knowledge... Can I ask you
    a question... I have a common Denon problem -- no audio anymore... I
    have a 3-yr old Denon AVR-2106, no audio anymore after ahutting down
    one day and a single pop from all speakers came... Turns on, starts
    normally, flashing then steady green, ending in 'Receiver' display, no
    "Protected Mode' display, I hear very slight power relay click-on (not
    a pop), just no audio... What do you suggest. is transformer bad?
    thermal fuse blown? I have some electronics repair skills. Thanks...
    President:
  • 624 Answers
Hi Grant,
I will be happy to help you figure this one out. First, let's make sure that the output channel is blown. Have you checked the output transistors on the heat sink? Are they shorted? This is the first thing to check for this failure. If you have verified that the channel is in fact bad, I will then give you a list of all the parts you need to replace.
You mentioned that the unit took a power surge. If this is true, it may not have a shorted channel, it could be the power transformer that is bad.
Does the unit turn on and then go into the protect mode with the display lighting up and then it shuts down a few seconds later?
Have you checked the fuse that is right near where the power cord plugs into the main board?
I just want to confirm the actual problem before proceeding any further, it will save both you and I time and trouble. Please wait to rate this solution until we have finished our communications and are sure of the problem.
Thanks,
Dave
Posted on Dec 12, 2008
Denon AVR-1513
disconnect speakers then try again if still shutting down you will have bad outputs.
Aug 26, 2014 | Denon Audio Players & Recorders
Denon AVR-2800
Hi, This is because your unit goes in to protection mode because of some bad connection in the input/output section .Disconnect your spkrs,inputs..turn the volume is Down all the way and power it up,Check your wiring for shorts at the inputs and outputs. at your service sreejith
Jul 31, 2007 | Denon AVR-2800 Receiver
Red power light blinking on my denon avr 1907, tried reset procedure, no speakers hooked up now and it still goes from green light to blinking red light and shuts off...Any clues?
This is a protection mode. The receiver protection circuit detects an internal problem like missing power supply voltage or blown channel and shuts down the receiver. You need to bring the unit to a repair facility.
Sep 26, 2011 | Denon AVR-1907 Receiver
I don't have any sound when I turn on the Denon DVD player. I have checked the back of both the receiver and the dvd player and there are not any wires off. As far as I can tell all the wires are in the...
Check the "Input mode" on the receiver for DVD input. Make sure the input mode is set to "Auto" if you still have a problem, post a reply and I can help you further
Oct 03, 2010 | Denon AVR-1706 Receiver
After power up delay then goes into protection mode denon avr 5600 how can i solve thios problem
Disconnect all speakers at the receiver then turn it back on, if it does not go into protection, post a comment and I can walk you thru troubleshooting. If it still goes into protection, it will need to be serviced. Hope this helps.
Aug 20, 2009 | Audio Players & Recorders
Amp comes on and goes right into protection mode I turn on my Denon stereo receiver AVR-1500 an it goes to protection mode? Can someone please help me?
Do you still have the AVR1500? I have one with a bad tuner--and would be interested in purchasing your for parts. Let me know if you still have it and if you'd be willing to sell it.
Dec 01, 2008 | Denon AVR-1500
DENON AVR-1404 switch on problem
Maybe the audio amplifier IC´s are damaged that´s why go on the protection mode
Jul 21, 2008 | Yamaha RX-V461 AV Receiver
Protection mode after about 3 seconds
The protection is most likely being triggered by an internal fault. Typically the power amp section. The receiver will need professional service.
Sep 18, 2007 | Denon AVR-681 Receiver
Denon AVR-810 going into PROTECTION mode
It sounds like there is a problem with the differential circuit. The bias I am not sure about, as every unit is different. You should get the service manual to be sure or call Denon and see if they can give you an idea. Good Luck
Jun 05, 2007 | Denon AVR-2106 Receiver
1,558 people viewed this question
 Grubhead
Grubhead
