Question about Genius NewSketch 1212HRII (TB4A0R003) Graphic Tablet
Power adapter Dear Sirs, I would be gratefull if you could tell me the exact output,volt and ampere of the poweradapter for genuis newsketch 1212hrll. thanking you in advance. ditechirq@yahoo.com
  • ditechirq Jan 20, 2009
    Thank you very much for the information,which is very helpfull. I think your English is good and much better than my French.
    Thanking you again .
    ditechirq
Hello ditechirq.
I got the same tablet, but I search to use it on Win XP.
I't seem's that is no XP driver for this product, and the Pc tell's me that the tablet is not found (rs232)...
For the question, the adaptor output is 5V, 350mA, positive is the center pin of the connector on the sub-d9.
I hope this helps you, and sorry for my bad english, I'm French.
Posted on Jan 19, 2009
  • 145 Answers
You can get this info from there web page
Posted on Dec 13, 2008
PHILIPS CORDLESS CD245 TRIO AND other 2 handsets power requirements (Adapters lost)
It should say on the bottom of the base unit. I would expect 5-6 volt 500ma. That would be the size that would charge those batteries.
Oct 16, 2016 | Philips Lands Phones
The AC power indicator light does not torn on when the adapter is plugged. The adapter was tested and it puts out 19 volts. At first the prolem was intermittant, but now it is not working. The battery...
The AC adapter have two measure:
Output volt: 19 volts
Amp:
the Volt output can be tested and show 19V, but can`t leave the correct Amper.
I see these failure in anothers AC adapter. I measure the Volt and show 12 V, but don`t work the survellaince camera. I recommedn replace the adapter
Sep 14, 2011 | Computers & Internet
Pavilion DV3 not working on a car charger That is working flawlessly on other hp nc6400 laptop they both work great on the 220v standard adapter! Why isnt my laptop charging?? Please help
the 220 v power of cities has 25 Amper
has your inverter 25 A . of course not
so this is right that tow power sources have 220 VOLTS but the important matter for working
a device by power source is the out put AMPER plus output Voltage.
good luck
gorbesia
Jun 29, 2011 | Inverter 175 Watt Power Car Adapter for...
I recently got this laptop from someone who did not have the power supply with it. Can anyone tell me what the required power supply must output? I really don't want to fry this computer, so I want to make...
You need a charger with this features: 90W Laptop AC Adapter / Charger for HP Pavilion DV5-1125NR / DV5-1127CL Replacement
Diameter : 5.0 mm x 7.4 mm
Input Volt Type : AC
Input Volt: 110-220V (Worldwide Use)
Output Ampere : 4.74A
Output Power : 90 Watt
Output Volt : 19V
You can buy one at:
http://www.buy.com/prod/90w-laptop-ac-adapter-charger-for-hp-pavilion-dv5-1125nr-dv5-1127cl/q/loc/101/215845345.html
for $19.89 including shipping.
If this was helpful, please rate me.
Thank you
Jan 13, 2011 | HP Pavilion dv5-1125nr Notebook
Hello : I have a Tascam portastudio_dp_1fx. Anyone knows how to reset this message: Err: 12 Please PWR OFF
Hi!
This error will only dis appear when you replace the ac power adapter that comes with it.
Or you better check if the output voltage and the amperes are not dropping.
Your power adapter should out with 12 volts and 2.5 amps. Less of this value means its dropping and its not stable..
You can use a multitester to check if the output voltage and amperes did not meet the requirements.
Hope it helps!
Alpug
Dec 31, 2010 | Tascam DP01 All-In-One Recording Package...
Can a nx9110 charger /ac adapter work on an ibm thinkpad t30
Thefollowing three conditions should be met for you to use a charger safely. 1)Output Voltage is within +/- 5% of your old charger's output.
For example, ifyour old charger provides 19.5V, then you can use a charger that provides 20.5Vor 18.5V.
2) Output Current is the same or higher than that of your old charger.
For example, ifyour original adapter provides 3.42 Amps, then you can use a charger thatprovides 3.42 Amps, 3.9 Amps or higher.
3) Connector tip must fit securely into your laptop. Pleasecheck carefully before using nx9110 adapter on t30.
Dec 11, 2010 | IBM ThinkPad T30 2366 Notebook
Describe your Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive Problem Do you have a picture of the voltage and amperage adapter for the Western Digital 250GB MyBook External HD ?
I don't have a photo of the AC adapter, but if you look on it the Voltage and Amperage specifications are;
Input: 100-240VAC / 50~60Hz
Output: 12VDC / 2A
This means the Input power can be from 100 volts to 240 Volts AC, and at 50 to 60 Hertz
The Output power is 12 Volts DC at no more than 2 Amp's. (Amperes)
Asian Power Devices Inc. has a model DA-24B12 that fits these specs.
Also a Wattac AC adapter model number - BAO362Zl-8-A01 will work.
Otherwise just use a 12 Volt, 2 Amp power pack, with a positive on center contact, and a 2mm pin hole
Nov 23, 2010 | Western Digital 250GB MyBook External USB...
Please i need the power adapter rating for seagate
Have you got the original power adapter?
If so the voltage details are printed on the label on the bottom of the adapter.
If the external USB Seagate hard drive houses a 31/2" drive then it requires an power adapter that provides +12 volts and +5 volts both supplying approx 2000mA of current.
If the Seagate uses a 21/2" (laptop) hard drive then it only requires +5 volts power adapter.
The only problem is the power connector to the external drive, make sure it suits the external hard drive unit and the power pins are correctly wired for the Seagate. If the polarity of the plug is incorrect lt wired (ie reverse polarity) then it could damage the USB hard drive and adapter case.
Nov 20, 2009 | Seagate (ST3500601CB-RK) (ST3400601CBRK)...
Need cdlarification...
buy higher amperage value adapter...like for example 12 volt at 3 ampere if this not last long....then try higher amperage value 24volt at 6 ampere...or 24volt at 12 ampere......like this I mean...
Jun 22, 2008 | Protron PLTV-32 Television
Genius NewSketch 1212HRII (TB4A0R003) Graphic Tablet Logo
189 people viewed this question
Top Genius Computers & Internet Experts
micky dee
Alun Cox
Are you a Genius Computer and Internet Expert? Answer questions, earn points and help others
