Question about Pioneer PureVision PDP-5030HD 50 in. HD-Ready Plasma Television
Pioneer PDP 5030 power supply problem
Last week I heard a pop sound from the inside of my Pioneer PDP 5030 plasma. I took it apart, examining the power supply board I found a resister had blown. I call pioneer and ordered a new power supply board. When it arrived I proceeded to install it back in the unit. All the cables were put back into its proper location. I turned the unit on and the power supply clicked, the green light on board came on and turned back off. Now the power supply will not even turn on. The power light indicator in front of the panel will only rapidly blink red. It repeatedly blinks without stopping. If I turn the receiver off the blinking slows but once the receiver is turned back on the red light speeds its pace. I do not hear clicking on the power supply unit any more. Please help. Thank you. JT
  • 3 more comments
  • jack tchil Mar 22, 2007
    M1013, thank you for your response! After replacing the power supply i failed to notice the white switch in the back was out. I'm assuming that the white switch is the one that is depressed when the back panel of the unit is screwed on. When i powered the unit on with the back panel of and the lever switch not depressed. The power supply turned on, I saw a green light on the power supply and then it quickly turned off and the light in front started rapidly blinking red. Since my post, I returned the power supply and purchased another. That too will not work and i see the rapid red light in front. So i think it's the switch you are talking about. Please tell me what to do with the interlock switch. Thank you very much!
  • gnx017 Dec 17, 2007
    I turned the power on, after 2 minutes of operation we heard a loud pop, the stand by light blinks rapidly 5 times. Is it the power suppy?
    If it is how easily can it be fixed?
    Thanks
  • Tranceman Dec 28, 2007
    Hi I have exactly the same problem as you had vezeer. I too had a power supply failure on my 50" (PDP-503HDE) and have replaced the power supply board for a new one, I also didn't notice the saftey switch. I know the switch is working ok and have taped it down and also I have checked the Y board for shorts but that appears ok... For some reason the power supply board isn't being told to fire up at all, it only did the first time and like yours it shut down and that's it. I too get the constant red power led blinking which goes faster once the media box is turned on but the system won't come out of this standby condidtion - I hope there's a simple silly solution to this... I have even tried putting the old board back in and that used to power up then off but that won't fire up either just the same flashing led?... Any help would be very much appreciated thanks... Rob.
  • Anonymous Mar 25, 2008
    I have been experiencing this problem described above for months!! Very annoying!! Even got it repaired by a designated Pioneer service agency and still the problem occurs. Unbelievable!!! I'm going to try solution 3 to see if it works. Why wouldn't Pioneer own up to it's defect, recall and resolve their issue and protect their BRAND NAME PIONEER!!
  • RYan Shawnego Apr 24, 2009
    I have a pioneer PDP 433cmx power supply failed.
    in other posts people have had there power supplies replaced for free from pioneer.
    called Pioneer said that they wont cover fixing anymore,, anyone else have same problem or a solution.
  • 3 Answers
Ok here's how I manage solve the problem... Having the back removed opens the contacts on the interlock switch so I guess if it powers up in this state it senses the high voltages are exposed and for safety shuts down... After this the unit will not power up and the power led flashes red continuously as described before…
After some thought it occurred to me that there may not be a problem at all, just be a simple reset function for this condition… I managed to find an easy solution to this… Just call up the hidden engineer’s service menu – On 3rd generation Pioneer Plasmas it’s as follows > Power down the screen > Hold down the “Input” and “Vol +” buttons on the front > Power the screen up and the Service menu comes up on the screen > You don't need to change anything just simply power off and from then the screen should operate as normal…It did for me so I’m well happy now!!
I hope this information will help someone else one day – Good Luck!!…Rob UK…
Posted on Jan 04, 2008
  • Silver1 Nov 26, 2017
    Thank you so much, I was literally about to throw away my TV when I stumbled across this post. Everything else I read suggested it was capacitor issue which I do not have skills for. I am amazed that I was able to enter Engineer mode using this method and after powering off it seems to be working perfectly. Many Thanks again
  • Tranceman Nov 26, 2017
    Glad to help Silver1, that interlock switch can really throw you lol... :)
    10 years on after the power board was fitted to mine and the Pioneer is still going strong every day without any problems.
    Kind regards Rob.
    New Friend:
What if its not a plasma, in other word's it has a large back lol
Posted on Sep 08, 2013
  • 103 Answers
There are 2 problems 1)you might have tripped the interlock switch which a white switch on back.2)what happened to unit(pop)you lost a scan ic and probably damaged the y sus board.use a multi meter and check the y-sus connector plug on power supply and check to see if it is shorted.If it is you also need a y-sus board. If you need help on the interlock switch please e-mail back
Posted on Mar 22, 2007
    New Friend:
Fix for Flashing red stand by light. Make sure media receiver light is on and green . My blu ray is just above the media receiver and someone pressed the receiver button thinking it was the blu ray and turned it off. Then press stand by light on the tv again and the tv should go back on.
Posted on Apr 28, 2013
Believe or not but I had the same problem and solved it by simply connect the VDAR connector that was loosen when remove the board
Posted on Jul 30, 2008
Where is the interlock switch located?
Also, we had white glove service mount the unit to the wall, how do remove from the wall?
Posted on Dec 17, 2007
Pioneer pdp-5030
REPLACE you power supply & THATS IT! TV PARTS www.shopjimmy.com
Jun 18, 2012 | Pioneer PureVision PDP-5030HD 50 in....
Tv won't come on...light in corner just blinks red
OK Its your power supply and it can be fixd for free due to a recall.
PLEASE READ BELOW what I found out.
Here's the whole notice:
Important: Free Power Supply Replacement for Certain Pioneer Plasmas
Pioneer is continuing to offer a free, in-home power supply replacement for certain of its second and third generation plasma models listed below for consumers who experience a problem with the original power supply. If a consumer model is not listed below, no power supply replacement is needed and no further action needs to be taken.
If you own or use a plasma listed below, please call our toll free hotline at 1-800-421-1404 to arrange a time to have your plasma's power supply upgraded in your home at no charge.
Consumer Plasma Models (12 listed):
PDP-505HD
PDP-503PU
PDP-5030HD
PDP-5031HD
PDP-433PU
PDP-4300
PDP-4310
PDP-4330HD
PRO-800HD
PRO-800HDI
PRO-1000HD
PRO-1000HDI
The issue with the power supply in the plasmas listed above does not pose any health or safety risk. Pioneer has received reports that the power supply in the affected models may fail. In some cases, a loud popping sound can be heard when a power supply fails. After the power supply fails, the plasma is no longer operable.
We apologize for any inconvenience, and we thank you for your cooperation.
Apr 02, 2010 | Pioneer PureVision Pro-800HD 43 in. Plasma...
Pioneer PDP 4330HD display flashes red LED 4 times
Just seeing if you had resolved the problem as my mum's Pioneer PDP-433HDE which she bought back 2002 has developed this same fault.
It has been a perfect TV and done very well with plenty of good use, but I have a feeling the cost of repair - even if it is possibale will be costly.
Cheers
Nigel
Mar 13, 2010 | Pioneer PureVision PDP-4330HD 43 in....
I heard a pop from my tv and then the tv didn't work
Anything is repairable as long as the screen isn't damaged.
The sound you heard is most likely was a capacitor that just went dead.
Solder in a new capacitor should fix the problem. It would most likely be on the power supply board somewhere.
You'll need the Service Manual for parts list, diagrams, and schematics. Here's one place for that:
http://www.manuals-in-pdf.com/advanced_search_result.php?keywords=pdp-503cmx+service+manual&forward=plist
Any other questions just ask.
May 10, 2009 | Pioneer PureVision PDP-503CMX 50 in....
Pioneer Plasma TV powered off and won't power back up
Power supply failure-checked Pioneer's website, there is a recall on the power supply.
Nov 17, 2008 | Pioneer PureVision PDP-4340HD 43 in....
Loud pop and tv went off...
Here is a solution from the Pioneer web site:
http://www.pioneerelectronics.com/PUSA/Support/Important%3A+Updated+Information+Regarding+Free+Power+Supply+Replacement+for+Certain+Pioneer+Plasmas
Important: Updated Information Regarding Free Power Supply Replacement for Certain Pioneer Plasmas Pioneer is continuing to offer a free, in-home/office power supply replacement for certain of its second and third generation plasma models listed below for customers who experience a problem with the original power supply. If a model is not listed below, no power supply replacement is needed and no further action needs to be taken.
If you own or use a plasma listed below, please call our toll free hotline at 1-800-421-1404 to arrange a time to have your plasma's power supply upgraded at your residence or office at no charge.
Plasma Models (15 listed):
  • PDP-505HD
  • PDP-503PU
  • PDP-5030HD
  • PDP-5031HD
  • PDP-433PU
  • PDP-4300
  • PDP-4310
  • PDP-4330HD
  • PRO-800HD
  • PRO-800HDI
  • PRO-1000HD
  • PRO-1000HDI
  • PDP-433CMX
  • PDP-502MX
  • PDP-503CMX
Anyone with questions can call Pioneer's toll free hotline at 800-421-1404.
We apologize for any inconvenience.
Aug 09, 2008 | Pioneer PureVision Pro-800HD 43 in. Plasma...
Supply board
The power supply board for this model can be found in the link below.
Buy PDP-5030HD Power Supply Board
Mar 20, 2008 | Pioneer PureVision PDP-5030HD 50 in....
Pioneer pro800hd plasma just made a loud pop and then went to black the power button(red led) is flashing. power supply??, flyback xformer??? any ideas. worth fixing??
The affected models of consumer plasmas are listed below. Anyone who owns or uses one of these models may contact Pioneer through its toll free hotline at 800-421-1404 to arrange for the free, in-home upgrade. If a consumer model is not listed below, no power supply replacement is needed and no further action needs to be taken. If consumers are not sure if their plasma is affected, they should call the toll free hotline for confirmation.
Consumer Plasma Models (13 listed): PDP-505HD PDP-4330HD PDP-503PU PDP-4300 PDP-5030HD PDP-4304 PDP-5031HD PDP-4310 PRO-1000HD PRO-800HD PRO-1000HDI PRO-800HDI PDP-433PU
Dec 30, 2007 | Pioneer PureVision Pro-800HD 43 in. Plasma...
PDP-4330HD
This exact same problem happened to me 2 weeks ago on my Pioneer PDP-4330HD, and it did indeed turn out to be the power supply. The good news is, you can get it fixed for free, because Pioneer actually recalled the power supply in this plasma and others a couple of years ago.
Here is a link to the announcement on their website concerning the recall. They say that they will do a free in home replacement of your power supply, but when I called the local pioneer repair place, I was told I would have to wait three weeks for an in-home appointment. I ended up taking it in myself, and it was fixed for free 2 days later. Now it works perfectly.
Here's the number to call Pioneer in case the link goes down:
1-800-421-1404
Nov 10, 2005 | Pioneer PureVision PDP-4330HD 43 in....
Pioneer PureVision PDP-5030HD 50 in. HD-Ready Plasma Television Logo
3,593 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
