Question about Microsoft Windows Vista Ultimate Edition
Can not start up my laptop - Microsoft Windows Vista Ultimate Edition
Insert the key in the ignition and turn it clockwise
Posted on Dec 12, 2008
My laptop does not start even after prolonged press of start button
Will it work on the 110 volt power supply ? If not then a new one is in order. Another source of a no start is the coin cell battery inside the laptop. I wouldn't think this is a problem on a new laptop.
Mar 20, 2014 | Battery Biz WIPRO AcerNote 350cx AC...
Hp laptop hp 430
Maybe the cpu fan is fubar - check that out.
Mar 18, 2017 | Computers & Internet
Fix a compaq presatio cq57 iz
you start on take the disc of windows & put in the laptop and you restart your laptop then you can start to intoll your windows on the laptop when you done you have to restart again then your laptop is goin to work.
May 20, 2013 | Computers & Internet
When ever I start the laptop, the laptop starts for a second or so and then goes off. If I start the laptop after 3-4 days, it starts properly and then goes off after 10 mins or so.
computers and laptops are designed not to damaged the hardware from it..thats why its automatically off you laptop encounters error from your harware..check the temperature, and check the fans if they working properly..if not try to clean the fans..
Jul 27, 2011 | Computers & Internet
When I start the laptop or when the screen is
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN ... Power LED and battery charge LED start flickering when you wiggle the power .... HP Pavilion dv7-4080us 17.3-inch Desktop Replacement Laptop PC ... High-Capacity Battery For Hp Pavilion Zd8000 Series Laptops ...
www.articlesbase.com › ComputersLaptops
Jul 19, 2010 | HP Pavilion zd8000 Notebook
IBM ThinkPad T30 2366 not start without battery
It is NOT Battery or Power Supply it is your laptop itself has gone faulty... You need to troubleshoot the Motherboard, hard Drive etc, to find the exact problem that will allow you laptop to start. A laptop, will go, with just the power supply, and NO battery, if it doesn't either Power Supply is faulty, regardless of lights, OR the laptop's motherboard or hard drive is faulty, you must isolate problem.
Feb 26, 2010 | IBM ThinkPad T30 2366 Notebook
Labtop wont start up
Hi I am a laptop technician, and it sounds like you have a power problem.
Try removing the main battery and starting the laptop on the mains cable only. If the laptop starts fine then you probably have a problem with either the battery or the power board in the laptop.
If the laptop doesn't start when doing this, remove the mains power lead from the laptop and put the main battery back on the laptop. Try starting the laptop off the main battery only and if the laptop starts normally then you most likely have a broken/loose socket that the power lead plugs into in the back of the laptop (a very common problem) or the power board in the laptop is faulty. If the laptop doesn't start or goes off very shortly after pressing the power button it could just be that the battery is flat as a broken power socket on the laptop often stops the main battery from charging.
I hope this helps.
Jan 03, 2009 | Acer Aspire 5315 Notebook
Unable to start laptop
I understand the urgency and also the importance of data stored in the laptop.
As the laptop is unable to start in normal mode let us try in safe mode.
Follow the steps below:
1. Turn the laptop off completely.
2. Press the power on button to turn it on and at the same time simultaneously keep tapping ' F8 ' key on key pad until you see a advanced boot options screen.
3. Select 'safe mode' and hit enter.
Thank you.
Nov 28, 2008 | HP Pavilion dv6000z Notebook
Microsoft Windows Vista Ultimate Edition Logo
23 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
