Question about Genius NewSketch 1212HRII (TB4A0R003) Graphic Tablet
Poweradapter for tablet 1212hrll
Dear Sirs,
I would be gratefull if you could tell me the output, volt and ampere, of the poweradapter for genius newsketch 1212hrll.
Thanking you in advance
3 Suggested Answers
  • 145 Answers
SOURCE: power adapter
you can get this info from there web page
Posted on Dec 13, 2008
Hello ditechirq.
I got the same tablet, but I search to use it on Win XP.
I't seem's that is no XP driver for this product, and the Pc tell's me that the tablet is not found (rs232)...
For the question, the adaptor output is 5V, 350mA, positive is the center pin of the connector on the sub-d9.
I hope this helps you, and sorry for my bad english, I'm French.
Posted on Jan 19, 2009
My ac charger stopped charging.
Most of the time any universal charger, with 5 volt and 1 or 2 amper output.
can be used. Also should buy a new charger cord, with the same mini or micro USB connector. Take the old one with you to the shop to show the selling staff.
Mar 15, 2015 | Prestige Visual Land 10" Tablet Android...
I have a model-JJB052000-2509 50/60 H2 Output5V-2000mA and I need power adaptor can you help me?
pls let me know where do u live,,you need 5volt 2 ampere adaptor,,u may use 2-5 ampere also,,volts should be =5 volts,,,u can charge ur note with laptop usb connector also,,,or u can find this adaptor on,,,ali express,,,or any other as per ur area
Jan 27, 2015 | Archos 101 Internet Tablet 16GB 10.1"...
How Can I Calculate the Power Consumption of the MA5600? Please tell me!
Power in Watt = Current (I) in Ampere X Volt (V)
Just multiply the current in ampere used by ur device by the voltage supply (either 220 or 110 volts)
May 30, 2014 | Ericsson T202g Gpon Sbu Voice, Data, And...
Back up generator 240 volt output is off balance?
So there is a problem. Where are you measuring voltage?
Say there is L1 - N - L2. Line1 to Neutral is 120 volts, Line2 to Neutral is also 120 volts, Line1 to Line2 is 240 volts. N or Neutral ( the grounded conductor ) is center tap between line 1 and 2.
With this system, the N wire carries the unbalanced load in amperes .
Now we are talking of L1 and L2 and amperes. When L1 and L2 are conducting 10 amperes each, N carries 0 amperes, Line1 and L2 are balanced. When L1 carries 10 amperes and L2 carries 5 amperes, Line1 N carries 5 amperes, the difference of L1 and L2. This is normal.
When there is a problem with a loose connection on N, there is a resistance and will not carry the unbalanced load normally, the voltages will Chang's under load, the problem will worsen with time, a fire hazard, connected loads may burn up from excessive voltage or not work at all.
Bottom line: Make sure the N line ( white wire ) is tight at every connection and inspect for overheating damage. You may have to open the generator connections panel to check there too.
Aug 06, 2017 | Electrical Supplies
I recently got this laptop from someone who did not have the power supply with it. Can anyone tell me what the required power supply must output? I really don't want to fry this computer, so I want to make...
You need a charger with this features: 90W Laptop AC Adapter / Charger for HP Pavilion DV5-1125NR / DV5-1127CL Replacement
Diameter : 5.0 mm x 7.4 mm
Input Volt Type : AC
Input Volt: 110-220V (Worldwide Use)
Output Ampere : 4.74A
Output Power : 90 Watt
Output Volt : 19V
You can buy one at:
for $19.89 including shipping.
If this was helpful, please rate me.
Thank you
Jan 13, 2011 | HP Pavilion dv5-1125nr Notebook
Can a nx9110 charger /ac adapter work on an ibm thinkpad t30
Thefollowing three conditions should be met for you to use a charger safely. 1)Output Voltage is within +/- 5% of your old charger's output.
For example, ifyour old charger provides 19.5V, then you can use a charger that provides 20.5Vor 18.5V.
2) Output Current is the same or higher than that of your old charger.
For example, ifyour original adapter provides 3.42 Amps, then you can use a charger thatprovides 3.42 Amps, 3.9 Amps or higher.
3) Connector tip must fit securely into your laptop. Pleasecheck carefully before using nx9110 adapter on t30.
Dec 11, 2010 | IBM ThinkPad T30 2366 Notebook
Power adapter
Hello ditechirq.
Dec 12, 2008 | Genius NewSketch 1212HRII (TB4A0R003)...
I require a step down plug
I'm disappointed that Dewalt does not have the full specs on their website so . . .
Check the specifications on the charger's label; they should read something like 120 VAC or Volts AC and 2.0 (or similar) amperes or just 'A' after a numerical value.
If the label does not give you an amperage value you can use the output value instead and substitute the output voltage at the high end if a range is listed.
To get the adaptor (step-down transformer) wattage, multiply the AC values such as:
120 X 2=240 watts input power.
If these AC values are not available;
Take the high end charge voltage if it is a multirange charger, and multiply those values;
One we own DW9108 (- yours is 7.2 - 18) is spec'd at 9.6 to 18 volts and 2.8 amperes:
2.8 X 18=50.4 watts.
You can see that the values do not correspond but it is a multirange device so the maximum current taken from the AC line can be ~ 2.0 amperes but this is charging a specific pack and the peak input current is only momentary so the maximum output current and voltage are the values one should use as a guide. In other words, the output wattage is closer to the value needed.
Since there are losses in any transformation (mostly heat), the required stepdown transformer must be capable of more than the indicated 50 watts.
A safe factor would be 1.5 X 50 (W) or ~ 75 watts minimum to ensure the charger receives the 120 volts it wants.
Anything that will step down your (?) 220 volts and is rated at 75 watts or more will do the job even if the Dewalt draws a little more current at your line frequency of 50Hz which it may.
Oct 09, 2008 | Dewalt 7.2-18.0 Volt One Hour Charger
HP compaq nx9110 has a very very dull screen when running on electricity. When you run it on battery it is perfect. However battery last for seconds and cuts out.Obviously the battery needs replacing....
You'll have to replace the battery, of course...but for fixing the screen'll have to see if the powersource has the exact parameters that are writen on for example I had the same problem with a fujitsu...and the actual charger, or powersource was having a lower output that the one writen on was a 14 Volt, and 2 Amper, that was writen, but it only had 12 Volts and 1.3 Ampers at the output, when I measured had to replace a 4.7 Ohm resistor, right at the exiting points, and it got fixed, so what I mean to say that after replacing the battery, you really have to check the powersource for any errors and see if the output is identical to the one writen on it...please tell me if I was right.
Jul 24, 2008 | Computers & Internet
Can you run Two screens with the Genius - G-Pen 340 - 3 x 4 Tablet with Cordless Pen
If you install another graphics card or have a graphics card with 2 monitor outputs then yes!
Windows will expand the desktop across both screens and you can choose the screen layout in the standard display properties.
You will probably need to set the G-pen to relative mode if not already (behaves more like a mouse).
If I didn't understand the question then please comment again before rating
Oct 24, 2007 | Genius - G-Pen 340 - 3 x 4 with Cordless...
Genius NewSketch 1212HRII (TB4A0R003) Graphic Tablet Logo
Top Genius Computers & Internet Experts
micky dee
Alun Cox
Are you a Genius Computer and Internet Expert? Answer questions, earn points and help others
