Question about Fargo DTC550 Thermal Card Printer
Error/ Head Lift Error
During printing the Card stop under the printhead by making strange noise and then error message appears ERROR/ HEAD LIFT ERROR
This machine is one year old.
  • benito_gomes Jan 26, 2009
    Solution was that we replace the black O" ring Rubber place on the motor pulley which moves the card backward and forward.
    The Black O" ring was damage and also causing noise.
    Problem Solver:
  • 6 Answers
If you replaced the o-ring on the headlift assembly and that did not solve the problem, most likely you may have a sensor out that controls the position of the head lift.
Posted on Apr 16, 2009
How do you replace ask2000 printhead
Normally you can follow these given steps..It can be different for different model.....
Turn on the unit, and open the print-carriage access door by lifting the handle until the door locks into place.
The print carriage will move to the center of the unit. After the print carriage stops, release the gray print carriage latch and lift upward to access the printheads.
Remove the old printhead by lifting the printhead handle and pulling upward.
Being careful to touch only the black plastic remove the new printhead from the packaging and gently remove the plastic tape.
Using the printhead handle, push the new printhead firmly down into the appropriate slot; matching the color on the top of the printhead to the color on the printhead carriage.
Move the print carriage latch down, and make sure the loops catch the hooks. Snap the latch into place, and close the print carriage access door.
After the message to align the printheads appears in the front panel display, press Enter . A page prints to confirm alignment.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Dec 06, 2012 | FUJIFILM Ask2000 Thermal Photo Printer
I am getting ink error message Oxc19a0013
Is the phrase "Ink System Failure" in the message?
First check the cartridges. Remove all of the cartridges. Replace any that are low or empty. Check for damage or a blocked vent. Clear the blockage with a pin. If it is clogged with tape or the orange tab (that was in place during shipping), then remove the tape. Replace any that are damaged. Reinsert the cartridges and make sure that they are fully seated (clicked into place). Check if the error persists when you close the cartridge access door.
Try running the printhead cleaning utility from your computer. (HP Solutions Center under Setting, Print Settings, Printer Toolbox and follow the on-screen directions).
Remove the printhead and clean it. Then reinsert it and make sure it is fully seated. Remove the cartridges, lift the latch handle on the right and lift the print head straight up. This is done with cotton swabs or lint free clothes (coffee filters will work) and distilled or bottled water. During the cleaning do not touch the nozzles; also do not touch the contacts with your fingers. Wet the swab or cloth and wring out the excess water. Wipe the contacts on the printhead with the damp cloth first by wiping up towards the nozzles. Then with another damp cloth wipe the edge between the contacts and the nozzles (work in a right to left motion). Finally wipe down the ramps going away from the nozzles with another cloth. (Wipe each part until there is no ink left.) Dry each area with a fresh cloth.
Next take another damp cloth and wipe the contacts inside the printer. (work from top to bottom.) Dry the area.
Reinstall the printhead and lower the latch handle. Then reinsert the ink cartridges until they snap in. Close the cartridge access cover and check for the error message.
If the error persists, reset the printer. With the printer on, disconnect the power cord from the back of the printer. Disconnect the other end of the cord from the wall outlet. Wait at least 15 seconds and then plug in the cord (first to the wall outlet and then the printer). Turn on the unit.
If the error persists, then either the printhead needs to be replaced or the unit needs service. Unfortunately a new printhead is not returnable if you put it in and find the error persists.
For details and pictures: see http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3737195#N65 .
I hope this helps.
Dec 12, 2010 | HP Photosmart Premium C309A All-In-One...
How do you change the print heads on HP DesignJet 500ps InkJet Printer
first select the ink menu on front pannelthen enter select the print head replacement then enter carrige moves towards left then stop & message appears open the door then open the door & remove the head lock & remove the printheads during this process no power off
????????????/pls reply thanks mishrajk21@rediffmail.com
Apr 27, 2010 | HP DesignJet 500ps (42 in.) InkJet Printer
Error: print head not installed. Install print head
Make sure the contacts on the carriage assy. where the printhead sits are clean also. If your printer is still under warranty it will be repaired free of charge, if not, it sounds like you may need a new printhead. The part number for the printhead is printed on one side, it's always a qy6- number followed by 2 sets of 3 numbers each.
Jun 22, 2009 | Canon PIXMA MP610 InkJet Printer
37,004.40:39187 with the fan running
You have a failed resivor heater in your print-head, your print-head will need to be replaced, unfortunately more expensive (800$) then buying a new Xerox Phaser 8550dn from Tiger Direct. ($750 ish)
Mar 06, 2009 | Xerox Phaser 8400 Laser Printer
My Canon i860 just can't print out black words, it's frustrating
pull the ink cartage back out to see if a clear film is not on the cartage??? Check the area by cleaning the ink cartage with rubbing alchole, and also the area that the ink cartage goes into. Use a cotton ball the clean these area with.
Jan 31, 2009 | Canon i860 InkJet Photo Printer
IDS failure, call HP message comes up
Hope this helps you. This error is caused by either a correct or incorrect detection of air in the manifold. The steps below will clear the error condition, which should solve the problem if it is caused by an incorrect detection of air. If there really is air in the manifold, however, this procedure will not solve the problem and the printer will have to be serviced. Step 1 - Remove all printheads CAUTION: Do not touch the printhead tower. Do not remove the printhead handle. Keep printheads out of the reach of children. Figure 1: HP 14 printhead c00042423.jpg 1 - Handle 2 - Tower
  1. Make sure the unit is plugged in and the power is turned on.
  2. Open the print carriage access door by lifting the handle until the door locks in place. The print carriage moves to the center.
  3. Wait two or three seconds, then unplug the power cord.
  4. Open the printhead latch. See the illustration below. Figure 2: Open the printhead latch c00042424.jpg
  5. Remove each problem printhead by lifting the printhead handle and pulling up. See the illustration below. Figure 3: Remove the printhead c00042425.jpg
Step 2 - Reset the internal error state NOTE: This step must be performed before the printheads are re-installed.
  1. Close the printhead chute.
  2. Close the access door.
  3. Plug the power cord back in.
  4. Turn on the power. The front panel should read No Printhead. Will damage Product. Insert [color name] [icon] printhead now . NOTE: The carriage may make a grinding noise when you turn the power on. This noise is normal.
  5. Open the print carriage access door by lifting the handle until the door locks in place. The print carriage moves to the center.
  6. Wait two or three seconds, then unplug the power cord.
  7. Open the printhead latch.
Before re-inserting the printheads, make sure all the electrical contacts have had at least five minutes to dry. Step 3 - Insert the printheads
  1. Place each printhead in its slot in the printhead carriage. The colored shape on the top of the printhead should match the colored shape on the proper slot on the printhead carriage.
  2. Press down firmly and evenly on both the front and back of the printhead, as shown in the illustration below. Proper seating is essential to making good electrical contact.
Figure 4: Seat the printhead c00042431.jpg Step 4 - Close and check the printer
  1. Close the printhead carriage latch and make sure the loops catch the hooks. See the illustration below. Figure 5: Loops catch hooks c00042432.jpg
  2. Snap the latch into place.
  3. Plug in the power cord.
  4. Close the print carriage access door.
  5. Turn on the power.
  6. If the error clears, a message to align the printheads may appear on the HP Officejet D and HP Officejet 7100. Press Enter to align. If the error persists contact HP. Printhead replacement will not resolve this problem - the printer will have to be serviced.
Jan 08, 2009 | HP OfficeJet D135 All-In-One InkJet...
Have Ultra Hi-Definition RX595 Photo all-in-one print,copy,scan,photo. After setting everthing up and when I print from word or anyting the print comes out in color. I thought I could have color or b/w...
1) Make sure the printer is turned on but not printing. Ensure there are no error lights or messages appearing in the LCD.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2) Load letter size paper.
3) Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. RIGHT-CLICK your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then RIGHT-CLICK the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4) Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5) Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6) When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7) If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8) If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
Aug 21, 2008 | Epson Office Equipment & Supplies
Black ink
Please try the following to resolved the issue:
Run a series of head cleaning
1. Make sure the printer is turned on but not printing. Make sure there are no error lights or messages appearing in the LCD.
2. Load letter size paper.
3. Click on START, CONTROL PANEL, PRINTER & FAXES then right click on CX3200 printer Icon then select printing preferences
4. Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5. Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6. When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7. If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9. Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s) with genuine Epson inks, your printer will require service.
Mar 02, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Fargo DTC550 Thermal Card Printer Logo
3,101 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
