Question about Mag Innovision LT776s 17" LCD Monitor
Does a bad power supply look like this?
My Mag LT776s is several years old. The display is is normal for 5 mins or so, then the screen goes black. The power button led goes from green to amber. If I power off and on I get a normal display that shuts down after a minute or two. Hit the off/on switch again and I get a 30 second display before the screen goes black. Would an overheated power supply do this? I hate to shell out $30 for a new power supply and then find out some other chip or board is faulty instead.
  • 56 Answers
I suggest that you buy a new monitor coz your current monitor is too old...there's some electric component is weaken...its better to buy new than to repair the old one..
Posted on Jan 28, 2008
When I turn on my computer and monitor, the monitor display is on for about 30 seconds, then goes black. The computer is on, the green light is on, but nothing on the screen.
get a bright light or torch and shine it on the screem if you see any faint image then the problem lies with your backlight, sometimes connectors come loose and thats your best hope. if you have a warranty of any kind its time to use it.
Sep 28, 2009 | Mag Innovision LT776s 17" LCD Monitor
Screen goes blank after being on several seconds
Is the green light on (still indicationg power? Ist put your ear to it and switch on - hear any buzzing? Most like the HV Fluro Inverter for the lamps has an issue. For some the 2SC5707 may have gone - common.
May 29, 2009 | Mag Innovision LT776s 17" LCD Monitor
Monitor Goes Black
There are defect at the main board.
Try checking the capacitors.
Apr 24, 2008 | Mag Innovision LT776s 17" LCD Monitor
Factory mode on Mag Innovision LT776s 17 in
Sounds like one of 2 things.
  1. The internal bios of the monitor has failed and the monitor is pretty much wanting to know what to do. It is of course waiting to be programmed as it would have in the factory.
  2. Someone has knocked the front panel accidently pressing a combination of buttons to put it into factory mode. This is normally POWER + MENU held together when switching on. The only problem with this theory is after a power down, it should reset to nomal mode. It can be a different combination of buttons also, like AUTO and POWER or even all three together.
Apr 15, 2008 | Mag Innovision LT776s 17" LCD Monitor
Presario v2000 display problems
there is someting loose inside the computer so you may have to open it and check for loose conections or pices that they may be loose or video conectors
Jan 05, 2008 | HP Compaq Presario V2000 Notebook
Mag Innovision LT776s Model 780
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Nov 23, 2007 | Mag Innovision LT776s 17" LCD Monitor
Mag LT776S Monitor (Screen turns black)
This is not quite clear. You say no image at home or at school but worked at the store Did you see it working at the store? Check the cord sonnector for bent pins and or replace the cord- then come back
May 16, 2007 | Mag Innovision LT776s 17" LCD Monitor
Mag Innovision LT776s 17 in. Flat Panel LCD
I have the same problem except it usually happens after Ive left my computer idle for a while... i.e . Overnight, I usually turn off the monitor and I hit the button after I come back to turn it on. I get the same flashing light for several minutes. This has been a problem for several months, but only recenly have i gotten the same error message you mentioned. Each time ive booted the computer up cold or restarted it has worked fine but this time it took longer along with displaying the message: Top Left to Right: SH770 P001 Bottom Left to Right: AU M170EN05 Anyone else who can clear this up?
Mar 04, 2007 | Mag Innovision LT776s 17" LCD Monitor
My MAG Innovision Monitor went blank, only works if I stay connected to internet
usually this problem is caused by a faulty inverter circuit. transistors might been running too hot or a leaky capacitors also.not an easy task but try looking down for any defects on high voltage sections.
Feb 24, 2007 | Mag Innovision LT776s 17" LCD Monitor
Mag Innovision LT776s 17" LCD Monitor Logo
187 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Jaime Hernandez
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
