Question about Fargo DTC550 Thermal Card Printer
Error / Ribbon Jam/Broken
When open the upper cover and closed it back it make a strange noise and the error message ERROR/ RIBBON JAM/BROKEN.
  • Anonymous Mar 31, 2014
    ribbon jam er
    ror
    Problem Solver:
  • 6 Answers
When you open and close the lid on this printer, it tries to realign the ribbon. If you are getting this error, I suggestion you Calibrate the print ribbon through the print driver printing preferences on the Calibrate tab.
Posted on Apr 16, 2009
  • 3 Answers
I try to calibrate it showing insert ribbon but already ribbon installed some time ribbon broken error showing on display when i open the printer no broken pls help me
Posted on Sep 04, 2013
T652n 202.03 paperjam
1Open the upper-front cover and remove the toner cartridge.2
Look into the printer. Remove any jammed sheets of paper that you find there.
  • If the print job only consisted of this one page, reinstall the toner cartridge and close the front cover. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If the print job consisted of more than one page, confirm the entire paper path is clear before printing again. Do the following:
    1. Remove the top paper tray ('Tray 1').
    2. Remove any jammed or partially-fed sheets of paper you find here, then reinstall the tray.
    3. Go around to the back of the machine and open the upper-rear cover. Remove any jammed sheets of paper you find, then close the cover.
    4. Once you have confirmed that the entire paper path is clear, reinstall the toner cartridge and close the front cover.
    5. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If you cannot locate any jammed paper under the toner cartridge, then check the rest of the printer for any jammed paper. Do the following:
    • Remove the top paper tray ('Tray 1') and look for any jammed or partially-fed sheets of paper.
    • If you do not find any jammed pages there, reinstall the tray and go around to the back of the machine. Open the upper-rear cover and look there.
    • If the entire paper path appears to be clear, close the rear cover and power off the printer. Reinstall the toner cartridge and close the front cover. Power the printer back on. If a 200 error continues on power up, a sensor in the printer may be malfunctioning. This will require a service call to correct the issue. Please contact Lexmark Technical Support for additional information (see Contacting Lexmark Technical Supportbelow for details).
Aug 28, 2012 | Lexmark T652N PRINTER OPPENHEIMER SPECIAL...
My printer show the error 99 Ribbon Break/Jam but the ribbon is ok is not broken and i can not see some jam. Can you help me
Pls do the following:-
Ribbon Break/Jam
(PC Error Message No. 99, 108 and 109)
The Ribbon is not able to find the next panel correctly. Check for jams/breaks.
If jammed, clear the jam. If broken, repair by taping the Ribbon back on to the take-up core.
Press Resume to continue or Cancel to abort.
Thank You...........
Jul 26, 2011 | Fargo HDP5000 Thermal Printer
How do I clear a paper Jam
Try either of the following methods to clear the paper jam. The operator panel displays the Ready message when the jam is cleared.Method A:
  1. Press Paper Rewind until the Paper Empty message appears.
  2. Press Paper Advance to re-load the paper into the printer.
    The printer advances the paper, then cuts and discharges about 24 in. (61 cm) of blank paper. This reduces the possibility of fingerprints or other damage to the prints.
Method B:
  1. Turn off the printer and open the upper cover.
  2. Remove the ribbon from the printer.
    Caution: Prevent damage to the printer. Do not pull abruptly on the paper.
  3. Slowly and carefully pull the jammed paper out of the printer.
  4. Cut off any damaged or printed areas of the paper. Do not damage or mark any of the rollers.
  5. Close the upper cover and turn on the printer.
  6. Press Paper Rewind to rewind the paper into the printer.
    Note: If the Paper Jam message still appears on the operator panel, press Paper Rewind again.
  7. Open the upper cover and reload the ribbon.
  8. Close the cover.
  9. Reload the paper.
Note: If the Paper Jam message still displays on the operator panel, and you are at the end of a paper roll, it is possible that a segment of paper is too short to automatically exit the printer. Remove the front cleaning roller and remove the segment of paper.
Jan 03, 2011 | Kodak ESP 7250 All-in-One InkJet Printer
HP 3005dn Printer Tray 1 paper jam error
If message in display panel reads [13.XX PAPER JAM [LOCATION]]Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken.
Soln.
For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation.
For message 3.0 PAPER JAM [LOCATION]
means
A non-specific paper jam occurred.
Soln
1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation.
For more help check yhis site
http://www.printertechs.com/tech/error-codes/error-codes-0-19.php
Nov 26, 2010 | HP LaserJet P3005n Printer
Printer keeps saying it has a paper jam and to remove the jam from the back. There is nothing there! I think it just wants me to open and close the rear door, but that only fixes it sometimes. How do I...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 22, 2010 | Ricoh Aficio CL1000N Printer
The printer makes a grinding noise I took the right hand side plate off. There is nothing jammed inside.
Nov 08, 2010 | HP LaserJet 1020 Printer
Paper jam and still won't print
Hi
Thanks for using FixYa. Before you can clear the error message, you must locate where in the unit the paper is jammed.
Unplug the machine for safety. Now follow these instructions based on where the paper jam is located.
1. Pull the paper tray out of the machine.
2. Pull out the jammed paper.
3. Reset the machine by opening the Upper Jam Clear Cover and then closing it.
If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
4. Remove the Lower Jam Clear Cover from the back of the machine. Pull the jammed paper out of the machine.
5. Put the Lower Jam Clear Cover back on. Make sure the cover is set properly.
6. Open the Upper Jam Clear Cover. Make sure that there is no jammed paper left in the corners of the machine.
Note: If the paper is jammed under the print head, unplug the machine from the power source, then move the print head to take out the paper. 7. Close the Upper Jam Clear Cover.
8. Close the output paper tray cover and slide it forward, then push the paper tray firmly back into the machine. While holding the paper tray in place, pull out the paper support until it clicks and unfold the paper support flap.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 15, 2009 | Brother Office Equipment & Supplies
Window jam on my accent
It maybe the track guide clip has broken or the track bolt fell out, or the guide is out of adjustment. The door panel will probally have two be removed and checked for operation and any missing or broken or bent parts.
May 22, 2009 | Hyundai Motor 1995 Accent
Cover open Error message
I'd say maybe the switchs is broken and your machine reminds me of a lexmark fault. Look for the cover switch, under lid on base, at rear, small hole, find the switch that get's activated when openning and closing the top, maybe it is missing, or broken.
link to lexmark fault, that I think you will find your answer.
Feb 06, 2008 | Canon MultiPASS MP360 All-In-One InkJet...
Carrier Jam
i have a problem with my printer it gives a message saying 'clear carrier jam' with a big noise.its not working it is going too fast
Sep 26, 2006 | Lexmark P6250 All-In-One InkJet Photo...
Fargo DTC550 Thermal Card Printer Logo
2,614 people viewed this question
Top Fargo Office Equipment & Supplies Experts
pkwc
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
