Question about Nikon Coolpix S600 Digital Camera
Coolpix nikon S600 won't turn on
I have a coolpix nikon s600, from pawnshop.. the battery is fully charged but camera won't turn on at all, what could the problem be?
  • 4 more comments
  • Anonymous Dec 15, 2008
    bought the camera from a guy in expo center and charged new batteries. still wont turn on
  • egan4ever Dec 19, 2008
    I have a new nikon coolpix s600 camera. The battery is charged. The camera will not turn on
  • donshafer Jan 11, 2009
    Turned on the camers and the lense assembly slid out into position but nothing came up on the rear screen. Turned camera off, green light on top next to on/off switch went out, lense assembly stayed extended. Turned on/off back on, green light came on, still no rear screen. Removed battery, simm card, recharged battery, waited 60 minutes, inserted battery, same results. Any ideas???
  • bikechef Jan 14, 2009
    I too have a new coolpix s600 and have the same problem. The camera will some times turn on and the lens slides out but nothing on the back screen and then I can't shut the camera off. the power indicator light goes off and the lens stays open. After an hour or so I can turn the camera off. the battery charger shows the battery to be fully charged.
  • Anonymous Feb 27, 2009
    I also have this same problem the camera turns on, the lense comes out, but no picture on the LCD, 5 seconds later the camera turns off by itself.. HELP!!
  • Anonymous Apr 12, 2009
    I have a similar problem. When I remove the battery and put it back, the camera can be turned on. But whenever the Mode button is pressed, the camera is completely gone - no screen, no power-on light, nothing.
memmory24k
  • 5 Answers
SOURCE: Casio Exilim EX-S600 not charging
Good day on you sir , you have same problem about my friend of mine,, Who have also Exillim S600..
Two Problem you may encounter for that 1st is you need to change battery for that and the 2nd if it not function after you change battery its mean that theres a problem to your current supply need to change repair it into the licence repair man , you may not be worry for the fees coz its only affordable and easy to repair you must avoid those who repair shop that needs you large amount of fees..
Posted on Jan 15, 2008
SOURCE: camera turns off
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Posted on May 22, 2008
t0pc4t
  • 132 Answers
SOURCE: Coolpix S600 Drivers
I believe that this is one in the same camera....
Try
http://www.sony-asia.com/support/download/product/dsc-s600
Posted on Aug 15, 2008
  • 11967 Answers
SOURCE: Everytime I zoom in or out I get a lens error
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 05, 2010
  • 11967 Answers
SOURCE: lens error message and shutter
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Posted on Nov 03, 2010
I have a Nikon S600 Coolpix. The Mode Button does not work anymore. I push the button and the camera zoom is activated. Can I fix this?
I have the same problem. Nikon told me to remove the battery and digital card for 24 hours, then put ONLY the battery back in and try. It didn't work for me, but it is worth a shot.
Aug 27, 2010 | Nikon Coolpix S600 Digital Camera
Tip
Nikon CoolPix S600
Good day,<br /><br />It sometimes happen that you lose your cameras user manual.<br />This can be very frustrating as you need to look up something, but you can't seem to find a manual anywhere!<br /><br />Well if you follow <a href="http://www.retrevo.com/s/Nikon-S600-Digital-Cameras-review-manual/id/12050dj380/t/1-2/">THIS </a>link you can download your cameras user manual on your computer and thus keep a digital copy handy for all the times you need it.<br /><br />Please let me know if this information was helpful!<br /><br />Kind Regards
on Jan 05, 2011 | Nikon Coolpix S600 Digital Camera
There is a problem with connecting the camera nicon coolpix s600 to the computer. Equipment is installed with an error. OS-Windows XP/
Having gone over a month without a response, I assume my suggestion about using a card reader solved the problem.
Aug 19, 2010 | Nikon Coolpix S600 Digital Camera
Nikon coolpix s600 black screen or lines after taking a picture
Black screen after clicking a picture means aperture motor not working or lens flexible circuit damaged, it has to be checked by expert technician & is replaceable part.
Sep 30, 2017 | Nikon Coolpix S600 Digital Camera
Shutter Problem NIkon Coolpix S600
The link address does not seem to be correct as no image is shown!
Aug 19, 2017 | Nikon Coolpix S600 Digital Camera
Lens do not open
try smacking the sides of camera.also try to make the lens up down with you hand couple of times.then check out.
Mar 23, 2009 | Cameras
Sony dsc-s600
1= Use rechargeable battery cells and must be fully charged.
2= Check battery terminals in camera battery compartment. Must be cleaned and shiny.
3= Sony camera DCS-S600 won't charge batteries through USB cable plugged in PC. You need external battery charger to charge battery cells.
Oct 22, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Try
Aug 15, 2008 | Nikon Cameras
Nikon Coolpix S600 Digital Camera Logo
148 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
