Apex Digital GB55HD09W 55" Rear Projection Television Logo
Derick Foroutan Posted on Mar 23, 2007
I got a tech to fix problem. we just cant seem to find parts for this model tv
The red convergence is bad;the others are fine but its almost impossible to get parts. If any one has any idea how to get the parts i need for this tv please help. thanks, derick
Anonymous
Level 1:
  • Contributor 41 Answers
  • Posted on Jul 01, 2007
Anonymous
Contributor
Level 1:
Answers
41
Questions
0
Helped
8122
Points
38
IC's and resisters can be purchased from www.mateclectronics.com
My Mitsubishi 1080HD model WS-55315 colors are not correct. The blue is good and the green seems to be, everything else seems to be a shade of light brown or tan. I thought maybe the red tube was bad but...
The tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines like R,G,B mis alignments,also tv have any colors shaded shadows pictures or a 3D pictures look alike?Yes,than the tv have a convergence board problems and it is dead to causes all of these problems.The tv convergence board must have to repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops repair a DLP tv convergence board will cost u like $300-$350 for parts an labors.
2helpful
55 inch mitsubishi rear projection tv red lamp out of adjustment
Have convergence IC's replaced. I believe this unit uses STK-392-570 convergence IC's Only one has gone bad but replace them both, because if one has failed then the other is not far behind, for Blue and Green. One handles Red, One handles BLUE and Grn. There are only two of them in the set, They are the two largest IC's in the entire set.
3answers
Can't control red convergence on VS-45607
The STKs are three channel ICs they each control horizontal and vertical of one color the third channel controls part of green and the other half of green is controled by the other ICs third channel. Its customary for the Ics to fail and only have one channel bad in the IC. However its recomended to change both because of the bad Ic having green it can actually weaken the other IC and that one will fail shortly.
Convergence board
Your model uses a convergence IC Its a STK393-110 you can get a new replacement at the following link and they will provide free instalation instructions with pictures so you can do the repair yourself. They also offer free tech support to all their customers. heres the link.
http://servicemanuals.vstore.ca/
Converges problem for my RCA 52
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
2answers
Red convergence is out of alignment
i think your convergance amp ic are bad.
The STKs are common and if you have an experienced electronics tech around they can replace them for much less money but the tech must have advanced soldering and IC exchange experience.
The STK ics, two of them, can be purchased on line for around $20 to $40 each.
http://www.partstore.com/GetModel.aspx?MfgName=Toshiba&BrandName=Toshiba&ModelNu...
Partstore has two models available - one for around $40 and another for around $55.
The part number is STK392-110 and if you google you can find them for as little as $6/each but I don't recommend the cheap ones as they are not reliable.
It takes a good tech around 3 or 3 hours to take the old ones out and solder in the new ones. Also, it is likely one or two resistors are burnt and will need replacing as well.
Don not run the tv till you have it fix you will cause more damage!
Convergence
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
2answers
Convergence problem
At present, bad connect(s) on red convergence IC. Soldering pins will fix temporarily.
Usual fix = replace STK392-110  IC's. A 400.00 dollar repair at
your local tv shop......T.
2answers
Pioneer rear projection 51inch tv
moving big screens around may throw off the convergence, look to see if you have red,blue or green or all.. ghosts or edges in the picture. you will need a tech manual ..not owners manual to fix it, I would call a local tech and hear what he thinks for just a service charge. good luck
Top Apex Digital Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
