Question about Panasonic PV-DV51 Mini DV Digital Camcorder
Green dot being recorded to tape
My camera is recording a green dot. I have tried to clean the head but my head cleaner may be too old. It is almost like there is a cluster of pixels that have decided to be all green adn it is growing. I am assuming it is the sensor. If so is it worth fixing or should I just buy a new one? Thanks for your help.
SOURCE: blue lines in play mode
This is not a problem with the tape but the camera. The only way to fix it seems to be to find an empty spot on the tape or a spot you don’t care if you record over. Then record for a second then go to video mode and you can play the tape without the blue lines. Or buy something else to play the tapes which should be fine either way. Darn camera !
Posted on Mar 28, 2008
SOURCE: Panasonic PV-GS500
I had the same problem but without the needing cleaning message on my Pana PvGs12, weird as it sounded, I stopped it but left it on and gave it a whack on my palm and then tired playing it again and it fixed it. But I have heard it may also need professional head repair and that it may be out of alignment too? Try switching from doing it in the camera mode and or in the playback mode. I'd also try the reset button.
Posted on Apr 06, 2008
SOURCE: Recording and playback problems
Profession diagnosis was that the drum is out of round and cost of repair prohibitive, so I bought a new Panasonic PV-GS500 with a service contract this time! I had actually dropped the GS-150 when it was fairly new and the fall was cushioned by landing on the battery, so I did get a couple of years of good use from it.
I continue to use it as a still camera -- Amazingly, it takes great stills (better than my GS500). Unfortunately, my husband lost the lens cover (and the lens is kind of scratched now), so I would like to replace these parts if I can do so at a reasonable price. Thanks.
Posted on Jul 13, 2008
  • 1223 Answers
SOURCE: Camcorder has a green tint to it. It looks green
actually it is CCD failure !
kindly contact panasonic they will do it free of charge i am pretty sure even if u are out of warranty bcoz it is a known problem many are facing just call them they will arrange repairs
see this
go to and go to ur region and call them
Posted on Apr 10, 2009
  • 126 Answers
SOURCE: DVX100A panasonic camera tape mechanism not working
You can open the cassette cover and spray inside the upper left side of mechanism(closer to the back) with contact cleaner spray,because there is a rec inhibit switch.If it's not damaged and just dirty you solve your problem ,but if is damaged it needs replacement.
Posted on Feb 02, 2010
  • 172 Answers
SOURCE: My Panasonic pv-gs180 doesn't record.
If you have Head Cleaning Cassette play it at 10 seconds or use new Cassette for 10 minutes play or record. Otherwise Video Head damage
Posted on Mar 10, 2010
0 characters
1 Points
After recording and replaying, the picture is "sliced up". I've tried cleaning head with dry tape, seemed to help but still there. Trouble is it seems to vary each time I play the same tape.
Do not use a head cleaner - they can damage the heads. Insert a brand new high quality tape and perform a record. Let it record through the entire tape. Then, play back an original prerecorded tape and check playback.
Nov 15, 2010 | Canon GL1 Mini DV Digital Camcorder
I have a samsung scd103 digital cam and when i record something it looks good on the screen while im recording it but when i play it back there are grey lines and distorted sound
Have you tried cleaning the recording heads? Use a dry type cassette cleaner only. It's just like a vcr head cleaner tape, only in the small mini-dv tape size.
Sep 30, 2009 | Samsung SC-D103 Mini DV Digital Camcorder
Got a brand new samsung d381 camcorder and when you playback recordings there are horizontal green lines across the screen and no sound, what am I doing wrong? or should I send it back as faulty? I have...
May 28, 2009 | Samsung DouCam VP-D5000i Mini DV Digital...
Pixelated recordings
clean heads and tape transport with head cleaning tape, worked for me. had to run the tape 3 times at 10 second intervals with a 30 second cool down between runs. Dont clean for more than 10 seconds at a time as the cleaner tape heats up head and will fuse dirt onto head if overheated.
Jul 07, 2008 | JVC GR-D290 Mini DV Digital Camcorder
Canon camocorder thick gray lines on ever recording
Canon support was of no help. They ****! To fix the problem this is what I figured out.
  1. Before you start filming what you want record or just advance the tape 10 secs or so.
  2. Record/ video whatever you planned.
  3. Now when the thick grey lines come up on play back don't freak out.
  4. Simply rewind the tape to the beginning and record briefly in the blank portion at the beginning (careful not to tape too long as to tape over your intended recording).
  5. Rewind and play the thick grey lines should now be gone.
How did I figure this out just a fluke. No cleaning, no spray pretty simple. At first did not understand it but it works EVERYTIME for me. I'll deal with it until I get around to buying a new HD video camera and it won't be a Canon. Hope this helps.
Jan 13, 2008 | Canon ZR100 Mini DV Digital Camcorder
Will not record or play back.
the head may be dirty, try cleaning the head with a cleaner tape and try recording again.
Oct 23, 2007 | Sony Handycam DCR-TRV340 Digital Camcorder
Sony DCR-HC38 not recording or playing
try to clean the video head...just forward a blank new tape 5 times...until the head is being cleaning...dont use a video head cleaner...just think using a sand paper to the damaging the head
Aug 08, 2007 | Sony DCR-HC38 Mini DV Digital Camcorder
Problem with sound during playback
do not used that cleaning cassette it will ruin your video head...cause the cleaner is very rough....just forward a blank new tape for cleaning...the problem of your camera is the tape alignment...
Jul 24, 2006 | Panasonic NV-DS29B Mini DV Digital...
Panasonic PV-DV51 Mini DV Digital Camcorder Logo
57 people viewed this question
Top Panasonic Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
