Question about Regal Ware K6725 Kitchen Pro Bread Maker
Hello, I have a K6731 Model Bread machine. I cant pull the paddle off of the bottom of the mixing cup. Is it supposed to come off for cleaning? Plus, I could use a link to an instruction manual that I could download. Thanks.
I found a copy of the manual. I would be glad to make copies availiable to others for 10.00 dollars per copy. I can be contacted at chiefcw1@gmal.com.
Posted on Dec 14, 2008
Bread not rising as it used to, not sure if problem with paddle or...?
just as a hint - there is few thousand breadmaker manufacturers... each of them is making several models... we do not live with you...
how we can help if we do not know what manufacturer and model?!? telepathy is overrated...
now, paddle have nothing to do with rise of the bread, yeast and temperature do! if paddle is mixing the dough - there is no problem with paddle!
buy pack of new yeasts (dry if you use dry, i prefer live ones), then try bake again, if bake is ok, you solved your problem, yeasts were old and enzymes stop working, if there is no change in results with new yeasts, try use same yeasts in different machine, if result is ok in different machine, you heating element is at fault... time for new machine...
you do not need to be super accurate with your baking, allow little play...
my favourite bread:
3.75 cup flour (non-bleached!)
1.75 cup milk (tepid, body temperature)
2 table spoon olive oil or butter
1 teaspoon sugar
1 teaspoon salt
3 sachets dry yeast (21g - 0.7oz) if live yeast - about golfball size
enjoy!
and do not forget to vote...
Feb 11, 2015 | Kitchen Appliances - Others
Is there anything I can do?
I don't know about your specific model, but in most bread makers there is a removable paddle that goes in the bottom of the bread pan after you put that in the machine. The paddle usually has a flattened side on the hole which slides on to the post sticking up from the bottom of the machine. If you look at the post straight down from above it should be D shaped. The usual procedure is to put the pan in the machine, install the paddle, and then add your ingredients. Assuming you are doing this and it is still not working, trying running it through a mix only cycle (like for pizza dough) with the machine empty to see if the paddle is engaging and spinning properly. If it is not, contact the manufacturer for assistance.
Aug 08, 2014 | West Bend 41053 Bread & Dough Maker
Mixing paddles come off during mixing, am using teflon tape on shaft to hold paddles on, what is a better fix?
Sound like you need new shafts or paddles and I know the paddles can cost $30 each. so think about a new model or buy one at a thrift store and try those paddle or use the machine. I got a great one for $10 . :)
Jul 30, 2017 | Black & Decker B2300 Bread Machine
I just bought your breadmaker B2200 and i am looking for recipes for a basic white and whole wheat bread.The booklet does not have basic recipes. I am looking forward to baking bread for a long time to...
Basic White
1 1/3 cups lukewarm water
2 tablespoons powdered milk
1 1/2 teaspoons salt
1 tablespoon sugar
2 tablespoons butter or margarine
3 3/4 cups white flour
1 teaspoon yeast
1. Measure ingredients in the order listed into Baking Pan.
2. Insert Baking Pan securely into unit; close lid.
3. Select BASIC setting and 2.0 lb. loaf setting. Choose LIGHT or DARK crust setting.
4. Push Start button. There will be a 15-minute preheat delay before mixing begins.
5. The Complete Signal will sound when bread is done.
6. Using pot holders, remove Baking Pan from the unit and carefully turn bread out of Baking Pan. (Mixing paddle may remain in bread. Remove paddle when load if cool.)
7. Allow to cool before slicing.
Time 3:50 hours
100% Whole Wheat
1 1/2 cups lukewarm water
2 tablespoons powered milk
2 tablespoons honey
2 tablespoons molasses
3 3/4 cups whole wheat flour
1 3/4 teaspoons yeast
2. Insert Baking Pan security into unit; close lid.
3. Select GRAIN setting and 1.5lb. loaf setting.
4. Push Start button. There will be a 25-minute preheat delay before mixing begins.
Time: 4.10 hours
Feb 19, 2011 | Black & Decker Bread Machine
I bought the bread maker last night and it doesn't seem to mix the dough. I have spots of flour and salt in the dough. It seems like there is a paddle or something that is missing. Do you know if I am...
There is supposed to be a removable small paddle in bottom of pan.
If it's not there, you will not get dough at all. Just wet flour.
If paddle is there, but you have half way dough.. AND you followed directions exactly, machine has a problem. Take it back for refund or exchange.
Nov 17, 2010 | Oster 5838 ExpressBake Bread Maker
The machine gets warm but the paddle doesn't turn.
Hi, The paddle should turn freely by hand with the bread pan out of the machine. Make sure the pan is inserted in the machine correctly. If the motor shaft turns but the paddle doesn't then the sealed bearing that the paddle rotates on has failed and is frozen so the paddle does not turn.. You may need a new bread pan. Hank
Jul 01, 2010 | Kenmore KTR2205SPR Bread Maker
Bread machine - clunking noise when mixing
In order to point you in the right direction I would need an actual model number of your bread maker. Here is a link to the West Bend replacement parts page. There is an link there for support. Hopefully this will give you the hep you need.
http://www.focuselectrics.com/catalog.cfm?dest=dir&linkid=54&linkon=category
Sep 03, 2009 | Kitchen Appliances - Others
My Black and Decker All in One Automatic breadmaker seemed to be working fine. It was making the right sounds but when it finished the bread was not mixed. The yeast was still on top with the flour and the...
Empty the bread pan and clean it out. Put the pan and paddle back in the machine but do not add ingredients. Start the bread cycle and look in the window (or lift the lid) during the mixing cycle. You should see the paddle spinning around.. If not you probably need a new belt.
Hank
Jul 27, 2009 | Kitchen Appliances - Others
How to remove bread from bread pan
This is model specific. Ask here for user manual for your model.
Jul 22, 2009 | Sunbeam Kitchen Appliances - Others
The machine bogs down when mixing the dough for bread
You should be using a dough Hook not paddle I have a Kitchenaid stand mixer and it uses a hook for dough paddles offer too much resistance for dough.
Apr 02, 2017 | Black & Decker B2000 Bread Maker
Kitchen Appliances - Others Logo
59 people viewed this question
Top Regal Ware Kitchen Appliances - Others Experts
Irene Tulloch
Are you a Regal Ware Kitchen Appliances - Other Expert? Answer questions, earn points and help others
