Question about HP Photosmart C4280 Aio Printer
Hp all in one says USB IS NOT CONNECTED when I try to scan
I have an hp c4240 all in one printer scanner and copier. I cannot get it to scan, it will copy and print fine though. It keeps telling me that the USB is not connected but it is. Do you know how I can fix this?
  • 12 more comments
  • Anonymous Dec 14, 2008
    I have the same problem
  • Anonymous Dec 17, 2008
    this printer blows. i have the same issue.
  • Anonymous Dec 18, 2008
    does anyone know the answer?
  • AJgirl Dec 19, 2008
    I'm having the same problem - it worked ok till I took it to my summer job.  When reconnected at home I now get USB not connected message when trying to scan.
  • Anonymous Dec 31, 2008
    okay is there an answer to this problem
    pretty disapointed in HP... so many people with the same problem...and no solution... even the HP Print diagnostic tool cant fix it.
  • lanierlady Jan 03, 2009
    I share the same problem and disappointment and hope someone will come forward with a resolution.
  • old speckled Jan 10, 2009
    Same problem I can copy and print but won't scan says no usb connection Eamonn
  • kvanhammond Jan 12, 2009
    Does anyone have an answer to this???
    Kim
  • sbryan06 Feb 04, 2009
    same problem, reinstalled software, no resolution :(
  • Anonymous Feb 05, 2009
    usb is not connected! same problem :(
  • Anonymous Feb 17, 2009
    Me too, have a photosmart c4270 and vista
  • Anonymous Mar 22, 2009
    Exact same problem. Please help!
  • Anonymous Mar 28, 2009
    help...hp all in one says USB IS NOT CONNECTED when I try to scan
My hp c4380 won't scan gives out a error message the usb is not connected but it is.
Posted on Dec 12, 2008
When I try to scan something it tells me the usb is not connected but it is. Use to work fine and now won't scan.
check different usb ports. and check usb ports by Pendrive. if pendrive works fine then use different cable. best of luck
Jan 17, 2011 | HP Photosmart C4240 All-In-One InkJet...
Hp c4240 prints fine but says usb not connected when i try to scan
re install the driver and that should get rid of your problem .
Sep 27, 2009 | Office Equipment & Supplies
HP Photosmart C4240 all in one keeps stating in que and won't print
I had the same problem. Make sure the usb cable is plugged in properly connected from the computer to the printer
Sep 22, 2009 | HP Photosmart C4240 All-In-One InkJet...
My HP Photosmart C4240 won't scan any more
I have a hp C4240. It suddenly quit scanning to hp Image zone. It
still prints and copies but I get several different error reports. I've uninstalled abd reinstalled the printer and also did the same with
the computer.......no luck.
Aug 11, 2009 | Office Equipment & Supplies
I have a HP Photosmart C4240 All-in-One printer. When I try to scan something it states that the USB is not connected. Everything is plugged in and it use to work. Any suggestions?
Try plugging the USB into a different port on your computer.
Try it in another computer.
Try a different USB cable.
Uninstall the unit from Start, control panel, Add Remove Programs.
Turn off computer.
Start computer, place driver disk in drive.
See if the computer will recognizes it and sets it up again....
Jul 07, 2009 | Office Equipment & Supplies
Printer and copier work fine- scanner says USB not connected.
I had this same problem and it is fixable, but not the way you would probably like, though you can still scan with the printer. You just have to open the Paint program and click from scanner or camera, and then choose your printer and click scan preview, and then scan, it works just fine but its a little time consuming.
Jun 01, 2009 | HP Photosmart C4280 All-in-One InkJet...
USB NOT CONNECTED ERROR WHEN IT IS CONNECTED
This is a HP hardware/software error and HP has not fixed it.
The C4250 may report that "USB is not connected" but the printer works just fine and when you use the Microsoft Scanner and Camera Wizard to carry out a scan, it works just fine too. So the error message is wrong.
The Microsost Scanner and Camera Wizard can be found on the Control Panel.
May 05, 2009 | HP Photosmart C4250 Multifunction Photo...
I have an hp c4240 all in one printer scanner and copier. I cannot get it to scan, it will copy and print fine though. It keeps telling me that the USB is not connected but it is. Do you know how I can fix...
Forget the scanning software form HP. This solution below works! At least untill HP do something to solve this. Windows Vista offers a built-in feature, named Windows Photo Gallery, that allows for scanning without using any imaging software. Follow these steps to scan with Windows Photo Gallery.
  1. Make sure that the product is on and that the USB cable is connected correctly.
  2. On the Windows taskbar, click the Windows icon (c01319360.gif ), click Programs , and then click Windows Photo Gallery .
  3. In the Windows Photo Gallery screen, click File and then click Import from Scanner or Camera .
  4. Look for an icon that represents the product.
    • If no icon appears on the screen, go to Solution five: Fully uninstall and reinstall the HP software.
    • If the icon does appear, click the icon and then click Import .
  5. Make any necessary changes to the settings on the Import screen and then click Preview .
  6. If the preview of the scan looks correct, click Scan . The scanned image imports into Windows Photo Gallery.
    • If the scan was successful, use the Windows Photo Gallery wizard to scan instead of using the HP software. To use the HP software, continue to the next solution to continue troubleshooting. However, it is not necessary to do so.
Dec 12, 2008 | HP Photosmart C4280 Aio Printer
HP Photosmart C4280 Aio Printer Logo
612 people viewed this question
Seeker5211
Seeker5211
