Question about Honeywell Programmable Thermostat Heater
-AC appears in the display of chronotherm III
I have a Honeywell Chronotherm III programmable thermostat. While attempting to adjust the temp I noticed -AC in the display where the temp should be displayed. I replaced the batteries and yet it still won't work. Any ideas?
Thanks,
John
  • jliso Dec 12, 2008
    Thanks squamos1 really appreciate it ... I will check it out
  • Anonymous May 11, 2009
    Thanks to you
    squamous1
    I got a same problem and by following your advise,, I fixed it ,, be safe
We had this problem recently. The heater would come on for a minute and the thermostat would display "Hold" plus the temperature. A minute later we would hear a "click" at the thermostat, and then "-AC" would appear where the temperature should be. The heater would then shut off, only to come on again a couple minutes later. The intake was also very loud. Anyway, we found the solution to be simple - my husband decided to just try changing the air filter, and all of a sudden everything was working perfectly! We thought it was a broken thermostat, but thankfully we tried an easier (and what should be obvious) solution.
Posted on Dec 16, 2009
    Problem Solver:
  • 10 Answers
I have had the same problem- twice. It was a similar but different problem each time. The -AC means the ac control voltage isnt making it to the thermostat. In my case both times it was a switch in the control circuit that wasn't closing properly. The easiest was the front cover switch. If the front cover is removed from the furnace or has vibrated loose, the switch will open, preventing the furnace from running. The other instance I ran into was a flow switch on the exhaust blower which ensures the there is flow OUT the chimney. The switch wasn't functioning, so the furnace wouldn't start. The blower would come on for a short time, but the burners wouldn't light.
Hope this helps,
Posted on Dec 12, 2008
Display shows LLL
PDF]Chronotherm III 7 Day Programmable Thermostat - Honeywell
https://customer.honeywell.com/resources/techlit/.../69.../69-0352.pdf
O I" O 0. HEAT M10 COOL OF ow to operateyo. This Owner's Guide will show you how to get the most benefit from your new thermostat. Your new Honeywell ...
Sep 13, 2015 | Cars & Trucks
My honeywell chronotherm III says -AC any ideas
The problem is your 24v power source. I am unsure as to why you put "other than power source or batteries". If you did indeed check that your thermostat is receiving 24v, then I would say that you have a bad thermostat. Hope this helps
Jan 22, 2010 | Heating & Cooling
I have a Honeywell Chronotherm III Thermostat and in instead of showing the temparature in the display it shows -AC. I've replaced the batteries, and tryied adjusting Temp up and down for cooling and...
It would appear to me that you have lost the 24 volt power supply to the thermostat. In referencing the manuals for this thermostat, available @ www.honeywell.com, I've found that when the thermostat is not connected to the wall plate (plate mounted on the wall, that the thermostat either snaps or screws into), it will display the -AC. This being said, either the thermostat is loose on the wall currently, or your 24 volt transformer has died. Hope this helps.
Dec 23, 2009 | Honeywell Power Humidifier: Furnace...
Thermostat not functioning correctly
-AC means there is no power coming from the furnace. not a tstat problem
Sep 24, 2009 | Honeywell Programmable Thermostat Heater
Replacing aging erratic honeywell chronotherm III
Hi, your replacement part can be purchased on amazon, take a look here: Amazon com honeywell chronotherm III thermostat. I hope this was helpful. Cheers
Nov 30, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
906 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
