Question about IBM ThinkPad T20 2647 Notebook
Switch on (resume) by keyboard
Hello, my IBM T20 2647 has broken display. So i have it connected to a external display and external keyboard. So I would like not to open every time its own broken display to power on. Is possible to power the notebook on by external keyboard? I guess it could be possible by the changing BIOS, because in current version (1.09) it is not possible to set up waking by keyboard.
Thank you!
Martin Jindra, Czech Rep.
  • martin_jindr Dec 12, 2008
    I had updated the BIOS, but in the latest version is not possible to set it. Do you know if there is some other solution?
    Thanks!
  • 55 Answers
Try to download latest version of bios from the website
Posted on Dec 12, 2008
How do i switch to external monitor
Virtually all IBM and Lenovo ThinkPad and ThinkCenter laptops allow you to hook up an additional monitor or projector to the computer. When you add an external monitor or projector to your notebook, you can choose to view the display on the computer, on the external device, or on both the laptop and the external monitor or projector at the same time. Toggling between viewing devices is as simple as pressing a couple of keys on the keyboard.
Shut down the laptop. Plug the VGA monitor cable from the external monitor or projector into the blue VGA port on the back of the computer. Turn on the external monitor or projector first, and then the Lenovo laptop. Allow the notebook to boot into Windows normally. Press the "Fn" and "F7" keys at the same time to switch the display from the laptop to the external monitor or projector. Press the "Fn" and "F7" keys again to enable the display on both the laptop and the external display device. Press the "Fn" and "F7" keys again to display screen contents only on the laptop LCD. choose support you need http://www-307.ibm.com/pc/support/site.wss/MIGR-54305.html http://www-307.ibm.com/pc/support/site.wss/MIGR-4YQHUC.html enable tv out on thinkpad http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-58625
Feb 13, 2013 | IBM Lenovo 3000 N200 PC Desktop
Lcd screen stuck in external screen mode
How to use the function (Fn) keys on the keyboard - ThinkPad T40, T40p, T41, T41p, T42, T42p, T43, T43p
Switching the display output location.
Switch between the computer display and an external monitor. If an external monitor is attached, the computer output is displayed in the following three patterns by turns:
  • External monitor (CRT display)
  • Computer display and external monitor (LCD + CRT display)
  • Computer display (LCD)
Notes:
  • For any operating system other than Windows 2000 or Windows XP, no additional procedure is needed. Just press Fn+F7.
  • This function is not supported if different desktop images are displayed on the computer display and the external monitor (the Extend desktop function).
  • This function does not work while a DVD movie or a video clip is playing.
To enable this function in Windows 2000 and Windows XP, the following procedure is needed:
  1. When you log on to Windows 2000 and Windows XP for the first time, press Fn + F7 and select a display-switching function in the Initial setup window. Since in Windows 2000 and Windows XP multiple users can log on to a single operating system by using different user IDs, each user needs to select the function in the initial setup window when logging on for the first time.
  2. If the Fn + F7 key combination have been assigned to a presentation scheme function, start Presentation Director, and change the settings.
Feb 28, 2010 | IBM ThinkPad T41 Notebook
Connect broken laptop screen to external monitor
Suggestion- on my toshiba fn-f5 switches display modes, but to remove display connectors, you may have messed up your keyboard ribbon cable connection. it probably has a small sliding lock to hold it in place- if the lock isn't tight, your keyboard may not be recognized, which could mess up your display. Also, make sure your battery is charged and/or your power supply to your laptop is connected. hope this helps!
mothmanmeg@gmail.com
Sep 06, 2009 | HP Pavilion dv6000z Notebook
Can i connect a presario v3500 laptop to an external momitor. @I think the display inverter is gone and i need to get some files off the lap top for work.
Yes, connect the external monitor to the port it corresponds on the laptop, usually the blue port. When you boot the computer hit the FN key located on the bottom right hand side of your keyboard and the LCD/CRT key i believe this will be the F4 key located on the top part of your keyboard this should activate the external monitor.
Tang
Feb 23, 2009 | IBM ThinkPad T23 2647 Notebook
I have a problem with my ibm thinkpad notebook i want to connect my notebook hp projector how can i
When you connect a data projector or a monitor to the video output connector on the laptop you can toggle the display in various configuration by press and hold the blue Fn key and then press the F7 key (once or a couple of times as required) this key has a blue symbol of a pair of monitors.
Press it once the LCD will switch off and the display will switch to the external video output.
Press it again and the display will be on both the LCD and the external video output.
Press it again and the display will be only on the LCD.
Jan 17, 2009 | IBM ThinkPad T30 2366 Notebook
IBM thinkpad T41 video problem
Connect your laptop to an external monitor, you will need to press the Fn + one of the Function keys that control switching the video to the external video port and the LCD screen.
If the video on the external monitor is perfect then the video chip is OK and the fault is either a faulty LCD or LCD connectors on the motherboard is not making proper electrical contact. You can pull apart the laptop and reseat these connectors, there are usually two connectors.
Nov 30, 2008 | IBM ThinkPad T41 Notebook
IBM T-20 THINKPAD LIQUID WS=AS SPILLED ON KEYBOARD CONNECTED EXTERNAL KEYBOARD BUT I CANT HEAR ANY SOUND NOE
ok
u r lose your laptop sound drivr reinstall your laptop sound driver
i hope ur problem will solve
Mar 07, 2008 | IBM ThinkPad T20 2647 Notebook
IBM ThinkPad T20 2647 Notebook Logo
112 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
