Question about Kenwood VR-207 Receiver
I have a VR-207 that seems to non responsive to its own remote. Is there a simple way to fix this or reset the system board?
  • Ken Johnston
    Ken Johnston Apr 13, 2007
    I took the power off of the Kenwood receiver and the remote worked for one or two clicks of the remote power it up, torn it off, change the source, watch tv for an hour or so and then go back to turn it off and no responce!!!
    I feel that your ideas worked well but the rest of this problem may be due to something else, woud there be some other type of thing that would cause the intermitant, time related problem??
    President:
  • 3,130 Answers
You will first need to check the remote control for the unit. Point the remote at a video camera and see if you see the remote light up. If it does try first to UNPLUG the unit for at least a couple of hours. If that as well does not work, you will need to have the unit serviced, as it may have a bad remote sensor on the front board or the microprocessor is No good. Depending on how old this unit is, it may not be worth repairing. Good Luck
Posted on Mar 21, 2007
Kenwood vr 207 push power button goes into standby with flashing power lite
Same thing just happened to me the other day....I'm thinking it an internal fuse/surge!?
Aug 28, 2010 | Kenwood VR-207 Receiver
I have a kenwood vr 406 and a kenwood rcr0609 remote. After some time, the remote stopped working , so we got a new remote. This worked about a day. The remote itself seems to be working, because I can...
Kenwood receivers recently have a commonly known problem with its receiving IR diode within the receiver, to fix this you will have to re-solder the connection on the receiver panel within the faceplate of your kenwood receiver.
Instructions to fix it are at the following link if you are willing to open up your receiver and repair it. lots of people have reported this fix as successful so it is widely believed to be a design flaw in the VR line-up of receivers as it has occured in all the VR families so far.
good luck.
Jan 20, 2009 | Kenwood VR-406 Receiver
Receiver will not work by remote
Hi!
Here are suggested solutions for you!
Unfortuntately, you and many others have this problem. I will point you in the direction of two "fixes" I have found.
Fix 1 is from Kenwood themselves, per the following quote:
"First try replacing the batteries if you haven't already. If that doesn't help, try resetting the receiver. Simply unplug the receiver, then press and hold the power button on the receiver while you plug it back in. Turn the unit on, and the display should say 87.50 to confirm the reset. If the remote still does not work, use a digital camera as an eye, face it towards the IR of the remote control. Depress any of the remotes buttons; you should see IR flash each time a button is pressed. If not then the problem is with the remote. If the remote works fine, then the problem is with the receiver. In order to determine the cause of the problem, I suggest you take the defective unit to a Kenwood authorized service center for evaluation. You can find information for authorized service centers in your area by visiting our website at www.kenwoodusa.com."
The second fix involves some very simple soldering, and has been endorsed by many as the solution:
http://www.remotecentral.com/cgi-bin/mboard/rc-theater/thread.cgi?3016%2C3
I hope this helps. Good luck and please let me know if this solves your problem!
Bob
Aug 29, 2008 | Kenwood VR-407 Receiver
Remote dosen't work, trying to code my Sony RM-V302
there's a good chance it's the receiver and not the remote. Just fixed mine this afternoon with help from this blog.
http://blog.moertel.com/articles/2007/05/25/repairing-my-kenwood-a-v-receivers-remote-control-sensor
this worked on my kenwood vr-209. 10 others fixed their kenwood as well from the posts.
Jay
Dec 25, 2007 | Kenwood VR-209 Receiver
IR receiver on unit not working?
Sounds to me like the issue is the rx in the unit. It can be fixed with very little work if you can locate the part. Let me take a look and see if I can locate the part number for you. Although I have to say that Kenwwod can keep a tight lip on their parts lists.
Nov 22, 2007 | Kenwood VR-309
It seems to be a general problem on Kenwood Receivers. Pls check this out http://www.moerk.org/kenwood/ or this http://resnet.uoregon.edu/~gurney_j/kenwoodrepair/
regards sgershoj
Nov 06, 2007 | Kenwood VR-505 Receiver
IR Reliability--Intermittent
The Kenwood VR-510 does indeed respond to IR remotes. I now use a Logitech Harmony H659 which is IR only.
Your issue is a problem with the VR-510, actualy the whole series had a problem with cold solder joints on an assembly behind the front panel. Fix that and fix the problem. It frustrated me for 5 yrs.
Go here for the fix:
This site has the fix well documented: http://resnet.uoregon.edu/~gurney_j/kenwoodrepair/.
All is working great now!
Jun 08, 2007 | Kenwood VR-510 Receiver
Remote control not working...
I'm not sure of the exact fix, but when these components were assembled a few of the connections involving the remote sensor were not saudered. An easy fix if you know where to look.
Apr 15, 2007 | Kenwood VR-405 Receiver
Kenwood VR-207 Receiver Logo
319 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Duncan
Mike Duncan
rigger094
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
