Question about Nikon Coolpix S4 Digital Camera
Lens Error Skiing in Switzerland, two-month old Nikon S10 gives "lens error" message. Apparently not a rare problem. Is there any first aid possible (if not send St. Bernard with brandy). Love this camera, hope it's not fatal.
  • 3 more comments
  • Monkeygym Nov 05, 2007
    About 1 year old Coolpix S4, lens error all the time. Tried removing batteries for a few minutes; no change. Obviously if it's a $150 repair for a $180 camera, it's not worth it. Pretty disappointing, as the pictures are good.
  • Anonymous Dec 02, 2007
    Try gently tapping with your while powering up. Worked for me first first try on my Nikon S10. I had about given up on getting it too work.
  • Anonymous Mar 29, 2008
    i dropped my nikon s10 about a week ago and a white screen popped up and it said "lens error" in red letters and it wont turn off unless i remove the battery ,i tried tapping it ,gently dropping it turning it on and im about to give up...any DIFERENT suggetions??
  • Anonymous Apr 16, 2008
    same problem , any solution
  • gmggmg65 Oct 13, 2009
    please help me with nikons10 lens error
    Genius:
  • 2,985 Answers
Could be fatal - looks like it need to go to hospital- Nikon support Looks like CoolPix dont like that sort of Cool huh
Posted on Aug 31, 2007
My d90 flashes an err sign somtimes when i shoot at manual mode.. but when i change my apperture and shutter speed setting, it will not appear anymore. Even at auto mode sometimes it flashes an err. Does...
Try shooting in manual mode with lens set at maximum (wide open) aperture. Then try at a smaller f-stop, say 5.6 or 8. If the error message appears when your lens is set to the smaller aperture, you could have a lens problem. Try another lens using the same test. If a known good lens gives an error message, then the problem is in the body. Also try zooming to different focal lengths and see if your 18-105mm gives the error at particular focal lengths. An error here would indicate a lens problem. In any case, your lens or body would have to be repaired by a professional as these repairs require major disassembly and re-calibration.
Nov 19, 2010 | Nikon D90 Digital Camera with 18-105mm...
D80 Digital Camera with 18-135mm Lens: I have a Nikon D80 with 18-135 lens. Just had err...
Having gone over a month with no response, I assume this is no longer a problem.
May 16, 2010 | Nikon D80 Digital Camera with 18-135mm...
Lens error message(nikon l16)
I was having a "Lens Error" with my Nikon Coolpix S10 camera and this websites' tips fixed my camera.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good Luck!
Sep 27, 2009 | Cameras
Nikon s50 lens error
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Aug 04, 2009 | Nikon Coolpix 2200 Digital Camera
My 9 month old camera (Nikon s210 coolpix 8.0mp) that I
Hi!
It sounds like the lens focus is stuck. If you don't have experience in camera repairs, you should give it for a repair to your local Nikon service center or other camera service center.
Tom
Jul 31, 2009 | Nikon Coolpix S210 Digital Camera
''Lens Error'' with Nikon Coolpix S10
Turn the Coolpix S10 on using the button to the left of the 'OK' rocker which has a picture of a camera and an arrow beside it. You may need to hold this button in for several seconds before it responds.
The camera should turn on in the mode used to view stored photos, and this may bypass the lens error message. Pressing the button again can get the camera to switch to picture taking mode. This worked on my S10 after I dropped it. Hope it works for you! regards Thomas Mann
Jul 19, 2009 | Cameras
Nikon Coolpix S202
My nikon coolpix s210 had a "lens error" after several months of use. The tapping of the camera against my hand did not work. Eventually i did use the method of putting my nail under the lens and pulling as I tried turning the camera on. I had to apply a good amount of force and was afraid i would break the camera, but after doing this several times, the lens did click back into place.
Jun 01, 2009 | Nikon Coolpix S210 Digital Camera
Nikon Coolpix S202 "lens error"
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 28, 2009 | Nikon Coolpix S210 Digital Camera
Nikon D40 Error Message
Get the kit changed. That should not happen right out of the box, but make double sure the next time around, you charge the battery completely before using it the first time. Not doing this can cause problems.
Nov 18, 2007 | Nikon D40x Digital Camera
Lens Error - Cool Pix L6 - Camera unuseable
Dont know if this will help anyone. I had a lens error for ages. In my long lasting devotion to google serk I found that many equall contenders found that a strike with a soft book in different directiions solved the problem. I ended up beating the camera from all angles with the palm of my hand. But hey! it worked. 4 months later im looking for the cure to system error 2. If you can help wi that one.
Sep 11, 2007 | Nikon Coolpix 5200 Digital Camera
Nikon Coolpix S4 Digital Camera Logo
459 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
