Question about Alienware PC Systems Alienware Area-51® 7500 Desktop PC
Booting problem with customized area-51 7500
The computer has power but nothing apears on the screen for hours i tried rebooting i eaven tried changin screen to see if it was it but the only thing i ear is the fans working and it cant possibly be a heat problem i already checked the temp is ideal for the cpu to work
  • 1 more comment
  • simonrouss Dec 13, 2008
    sorry i should of clearified its new i got it 2 weeks ago
    desktop
  • anxioussky Feb 11, 2009
    What you may want to try is to disconnect all other devices (dvd rom/Hd/etc) and leave one stick of memory installed, see if you get an image now, also pay attention to beeping errors. If you get an image, then connect your hd, if you loose the image it may be a damage hd or cable follow the same step until you reconnect all devices. Worst case contact OEM (but you will need an account number located on back or bottom of desktop) and they can troubleshoot. But if you dont have account number you can contact motherboard oem to test it for you they may replace.
    Good luck.
    Problem Solver:
  • 5 Answers
Possible solutions;
The Ram (memory) might be faulty,
The processor might be faulty,
If this does not work then change the Vga card
If that is not the problem then your mainboard is faulty
Posted on Dec 12, 2008
  • Alfred Rono Motelin
    Alfred Rono Motelin Dec 13, 2008
    Thanks for your mail. Is it a desktop or a laptop?
What would cause my screen to go black and then can't reboot 8.1 on dell pc??
If this is a Laptop, remove battery, Plug in charger to PC and then try to reboot. A bad battery will suck all the power from charger and won't allow the computer to have enough power to boot.
Aug 18, 2014 | Computers & Internet
My acer 3260 have a start up problem apear blue screen and when i run desktop i able to use some time automatic stoped and apear ***stop: 0x00000CE
When you reboot the computer please press F8you will get "advance boot option" Please select "Last known good configuration" .
If it not working reboot the computer press F8 go to Safe mode. In the safe mode go to command prompt and type this command "chkdsk /f /r" after that please restart the computer. After restarting please go to Normal mode.
Aug 05, 2010 | Computers & Internet
Acer aspire m1640 not booting all the way up
Reboot2_bing.gif yor machine while holding the F8 key as it boots back up. A menu will apear. Choose -->"start windows in safe mode with networking".
The os will start in safe mode. run an AVG virus2_bing.gif scan, then run Defrag by exploring your computer, right click on C: drive, click PROPERTIES, then the TOOLS tab, click the "check now" button, and only checkmark the top box 'fix file system errors', then click ok, the computer will then tell you it will scan upon next reboot., Now click the DEFRAG NOW button. the choose defrag. After Defrag runs for about an hour and it is finished, restart the system. If is still won't run normally, go back into Safemode buy pressing F8 on reboot, then run a registry2_bing.gif fixing program such as uniblue registrybooster, then reboot again. If it still won't run right, you may want to reinstall Windows and see if that works. If reinstalling windows doesn't fix it, it is definitely a hardware problem.
Good luck.
PLEASE RATE THIS ADVICE WITH SOME THUMBS UP!!!
Apr 25, 2010 | Computers & Internet
Gateway/vista black screen with no ctrl+alt+del but a nice cursor
Try this, before it boots up and just after in posts press F8, it should bring up a page where you can choose your boot option, choose "Safe Mode", if the computer does boot to safe mode there are a few steps you can do to remedy this.
First goto my computer, c:drive/windows and scroll down to a folder called prefetch open the folder, highlight everything in that folder by left clicking once on one of the icons and holding control(ctrl) then pressing A once everything is highlighted hold down the shift key and press delete, everything should now be gone, exit out of all the windows do a disk clean up, my computer right click on c:drive (your main drive) and click on disk cleanup tick all boxes and then click ok to start deleting the temp files. once finished reboot mechines and leave it to boot up. if you still are having problems or it wont boot up into safe mode post back. cheers.
Feb 01, 2010 | Computers & Internet
Screen black on reboot
start the computer and when the computers splash screen shows (dell) etc. tap the F8 key repeatedly until you see the multiple startup choices. Scroll to "safe Mode with Networking" and select it, you will see the operating system listed as the target operating system, click that (hit enter) start in safe mode. When it boots do you see the screen with no problem? if so then the resolution may be wrong on the normal start up. On the dektop in a clear area free of icons, right click and scroll down to properties, click on settings, then move the resolution slider to either 800 X600 or 1028 X 768. click on yes to change the settings, restart the computer by hitting start > Turn off computer > restart. Reboot it normal mode (just let it boot as you would normally) If you can see the screen, you are all set, if not there is another issue to deal with.
Sep 03, 2009 | Computers & Internet
Boot problem on inspiron 1150
Try connecting it to an external monitor.
When you do, as soon as you press the power button to turn on the laptop, close the laptop lid - as this forces the laptop to display on an external monitor.
If this works, then it means the laptop screen is bad.
If it doesn't, the most likely cause would be that the laptop video card went bad.
For a while, some older Dell laptops with high-end nVidia graphics cards tended to die suddenly.
Mar 27, 2017 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Harddrive does not boot up to desktop
It is the hard drive. The EXACT same thing happened to me. You will need to replace the hard drive. You can backup all the info onto another computer using a firewire cable as I did. Boot your computer and hit "apple" "T" while booting, a firewire logo should appear and bounce around the screen. Makes your computer a giant external hard drive.
May 11, 2008 | Apple iMac G4 Desktop
Alienware PC Systems Alienware Area-51® 7500 Desktop PC  Logo
277 people viewed this question
Top Alienware PC Systems Computers & Internet Experts
Martin Murray
Frank Zabroski
Frank Zabroski
Larry Chandler
Are you an Alienware PC Systems Computer and Internet Expert? Answer questions, earn points and help others
