Question about Wacom Bamboo Fun 5.8" x 3.7" USB Tablet with Cordless Pen and Mouse - Black
Wacom Bamboo stylus shaky cursor
I only encounter this problem on Windows, I switched from Vista to a Mac when I first encountered it, but now I'm back to XP and having the same problem, it's not the USB ports, I think it may be the drivers, Windows' messages me saying "tablet driver is not running"
Any suggestions?
Animation is my passion, there has to be a way around this problem, I've used tablets on this laptop before.
  • 1 more comment
  • Anonymous Jan 04, 2009
    I have the same problem. But it happens when im drawing as well. I cant draw a straight line cause it always looks like the cursor is virbrating.. even when the pen is prefectly still and against the tablet
  • Sauny Feb 01, 2009
    Hey. I have the same problem with a black, Wacom bamboo tablet. Thing is, I have two computers.. it works fine on the newer, flatscreen Gatewayone with windows Vista, but shakes when I try to use it with the older Dell computer with Windows XP. It started shaking after having it a few months on the XP version.. so it's something that happened to my computer I'm sure. Researching it, some people said that things in the OS drive may be interfering with the tablet. ..I am not a technological genius.. I'm far from it. xD I have NO idea what the OS drive is, how to access it, or what ever it could be that might conflict with the tablet. While it is not an epic need for me to fix this, I would like it to be fixed for me as well, considering the computer it works on is not as available as I would like it to be.
    Oh, I also had two tablets.. I thought the tablet was broken when the first one quit working, but now I have a relatively new one and it won't work at all on this computer... the same thing.
    It's the computer.. not the tablet, this I'm sure of.
    Hope I was of some help.
  • Anonymous Mar 06, 2009
    same problem, shakey cursor
Ur issue is that the tablet itself can not be above the tower or the laptop. Magnets make it shake. I had that problem to anytime it was by the computer (only above for some reason) or by something magnetic, so avoid that and you should be fine.
Posted on Jan 23, 2009
    Problem Solver:
  • 5 Answers
When i put my tablet on my laptop keyboard, the cursor starts shaking buy when i put it on my lap the cursor dosen't shake. Hope this helps!
Posted on Apr 07, 2010
I had the same problem randomly over the past year, not very often though. It just seemed to go away on its own.
I just unplugged my mp3 player that was charging + tried the tablet - the shaking has stopped..
plugged it in again + the shaking started up again.
Might be worth a try unplugging usb devices + see if that makes any difference.
Posted on Mar 01, 2009
I fixed my problem with the shaky cursor,often people dont look properly at what can cause the problem,I checked everything and then thought id have one last go with it,assuming ur laptop charger is fake as in not the original itl happen,buy a new laptop charger and its fixed,my laptop keypad stopped and started working the same way.cheers :)
Posted on Jul 03, 2011
It's annoying. I have the same problem, you get use to it. For one thing it doesn't shake when your drawing although hoover over buttons can be a hassle.
Posted on Jan 04, 2009
I just came to this site looking for a solution when it hit me; my tablet was spazzing like this because there was too much STATIC ELECTRICITY in the room. Once I sprayed everything down with a bottle using mist, it went away instantly. (DO NOT spray the computer/tablet. Only the furniture/surfaces)
Posted on Dec 25, 2010
  • TheProwler Dec 25, 2010
    If reinstalling, downloading drivers and moving your tablet away from the computer don't work, GIVE THIS A TRY. It's free and worked for me. Spray down the surface and furniture with a mist of water. DON'T DRENCH, and don't spray electronics. Static electricity can build up and cause the connection between the pen and the tablet itself to go haywire. Give this a try before you go looking for other drivers for a fix.
    This worked for me; and if you do spray electronics, make SURE it's a flat surface with no holes gaps cracks or crevices to **** out the static from the electronic; probably better off unplugging it too before hand.
    New Friend:
I have the same problem but only when I'm using the Illustrator, when I desinstall the driver of my tablet the problem stops, but it is impossible to use the tablet withou any driver. I tried move my tablet away and stay away from energy sources but it didn't worked.
Posted on Sep 25, 2013
When tablet is to close to mains power source like power cable, extension lead , magnetic field generated by current in cable affects tablet. Just move apart tablet and magnetic field source and your problem will disapear.
Posted on Mar 20, 2011
If you have a standard mouse also plugged in, try turning it upside down or unplugging it outright, if you don't need it. It is probably playing tug of war with your cursor.
Posted on Jul 23, 2009
Does the Wacom Intuos2 Classic Pen (xp 300e) work with the Wacom Bamboo CTL 470 tablet?
From what I read on Wacom's site, they are NOT compatible.
The Bamboo use a stylus that is different than the nib pens that the Intuos use. The stylus for the Bamboo is more like the stylus you can purchase for smart phones. The Intuos pens are pressure sensitive and have different nibs you can use for different effects and feel. You can go to their website and look for compatible pens and stylus' for your specific tablet.
Aug 02, 2014 | Wacom Intuos2 Classic Pen (XP-300E)...
My few week old bamboo input device is malfunctioning. The graphics tablet isfine according to the program checklist for troubleshooting, it also recognizes the stylus/pen when it is tapped on the active...
When was it last working?
Well first, try restarting the Bamboo program or restarting your system. It has more than one program that runs at the same time. For example, one program may be the one to control the movements and another may be there to help manage your bamboo device.
Second, installing the bamboo drivers and software may help. Registry can be edited, but that can lead to more issues.
Goodluck! :)
Jan 15, 2011 | Wacom Bamboo (MTE450K1) Graphic Tablet
Wacom bamboo pen doesn't work it doesn't move the cursor
Go to This website and post the same question http://forum.wacom.eu/viewtopic.php?f=9
Feb 07, 2010 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
Wacom Bamboo Fun Tablet-Mac. Yellow box pops up under pen cursor.
Your tablet is set under the handwriting setting. Go to system preferences and select ink under hardware. Then turn off handwriting recognition.
Jan 20, 2010 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
Issue installing software for my new bamboo tablet
make sure the software you are installing is compitable with the tablet there maybe a update on there website or something that would work better
Jul 21, 2009 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
Have the graphire 3 tablet, Not working well.
Wacom tablet not plugged into your computer with the USB cable.
Go to Add/Remove Programs, (Start>Control Panel>Add/Remove Programs), and -> Remove
the Wacom software.
Restart your computer.
After Windows XP has fully loaded again, install the Wacom Graphire 3 CD, in your CD/DVD drive. Reinstall the software.
If you had to reinstall your Windows XP operating system, you may have corrupted some of the Wacom tablet's drivers. (Hence the shaky stylus cursor) Removing the Wacom software, and reinstalling it will repair.
Now plug the Wacom tablet into your computer.
You should see the, "Found New Hardware", pop-up out of your taskbar tray.
Jul 16, 2009 | Wacom Graphire3 White 6X8 USB (cte630pe)...
Wacom Bamboo Crashes Power Mac G5
Try unplug bamboo tablet,repair permissions, intall newest driver from web page , run repair permissions again and plug bamboo, it should be it.
Jun 18, 2009 | Computers & Internet
Wacom Bamboo Fun Error
i was just having the same issue. My tablet was working fine in Windows XP but couldn't install it in Windows 7. was getting the same error. Found the solution here ...hope it helps :)
http://windows.microsoft.com/en-US/windows-vista/Make-older-programs-run-in-this-version-of-Windows
May 03, 2009 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
Wacom Bamboo Fun 5.8" x 3.7" USB Tablet with Cordless Pen and Mouse - Black Logo
6,967 people viewed this question
Top Wacom Computers & Internet Experts
toddmat
Level 1 Expert
jasbo
jasbo
William F. Bryant Jr
Level 1 Expert
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
