Question about Nokia 2100 Cellular Phone
Nokia 2100 security code
I played with my message settings. i think i changed the number of my 'sending profile' and now if i try to send a text it comes up with 'sending message fail'
my serial number is 351523008128460
i tried to restore to factory settings but i dont know my security code or how i can find/change that
  • ssteeefffff Dec 12, 2008
    i dont have the manual. clearly this phone is about a zillion years old, i would have thrown it out sometime when i moved.
    that code didnt work..
    ill have a llook at the website tho.
    Master:
  • 623 Answers
It's not too hard for someone who has the manual,all you have to do is do according to the instruction on the manual book.i hope that will really help you a lot.
try this code 3446415063
or try this site
www.unlockme.co.uk/security.html
Posted on Dec 12, 2008
Why cant i receive text messages but can send them
Follow this step your problem will be solved
You should call the customer care there they will tell to change the message center number.
*Select menu
*Select message settings
*Select sending profile
*Select sms center 1.
*message center number.
Thanks for your question.
Jun 20, 2011 | Nokia 7230 Cell Phone
My nokia 2600 will not send a text message. Possible problem is the message centre setting. I reside in Bulgaria
Hello.
In the menu go to: Message settings ->Sending profiles-> Message centre number You obtain this number from your service provider and you need it to send text messages. Call the customer service of you provider and ask the number or if they can send a sms with all the info. Usually this number is obtain automatically by you phone when is first connected in the network, but it can "get lost". I don't know your gsm provider, so you have to call them and ask the number.
Regards, Achil
Mar 09, 2011 | Nokia 2600
I cannot able to send a text message, it is always said sms sending failed. my phone is sonny ericson P900i, i tried already changing the message center setting as recommended by the network...
click on to menu, click to sms setting, click to message settings, click profile settings, click the service provider, you will see and option service provider name, text code number, maximum and text. make sure it is on text and if not change to text.
Feb 03, 2011 | Sony Ericsson P990i Cellular Phone
I can't send messages using my N71. i've been using it since may 2010, but just yesterday, i can't send, even checking my load was a failure. when i changed phones, i was able to send a message, so there's...
First restore the phone to it's default settings. Menu > Settings > press up key once and "Restore Default" enter the code 12345 (if you have changed it, please use yours) and let it restart itself. Now try sending the message again.
If this doesn't help, you need to check the message center number from the message settings, Go to message, select options and settings/message settings and then text message settings and look for sending profile or message center, delete all the message center numbers and create a new one with the number that was on your other phone or copy it from another friend/user who is using the same network sim card or just restart the handset.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Aug 18, 2010 | Nokia N71 Cellular Phone
I can receive txt msg and make and receive calls on my nokia e65 but cannot send txt msg. Why would this be?
hi....
I think when you send text message it says message failed...right..???
This is because there is option in your mobile called as message service centre number.please check weather this number is correct.Call your service provider and you can get this number.
And also there is an option called as reply via same message centre please put this to 'NO'. now you can send messages
To go to this options please check follow these steps....
1.open 'menu'
2.open 'messages'
3.Go to 'message settings'
4.in that open 'text message'
5.there is an option called as 'message centre',please entre your new message centre number and save it. set this as your message centre
6.Check the option 'reply via same centre' and please put it to 'NO'
Thanx
Jul 17, 2010 | Nokia e65 Cellular Phone
Will not send texts
Check your message setting, Open the Profile in your message settings and clarify the center number, you can compare with other's who is using the same service operator. The Center number should be same. If you see the center number is not correct, you can edit it and save it. If it's similar, then reset your phone to default settings "Restore Factory" using the code 12345 (if you haven't changed it), and check once again. If this even doesn't solve, then contact the service provider using the customer care number and tell them your problem. Good luck
May 21, 2010 | Nokia 6126 Cellular Phone
I am unable to send text messages in nokia 5230 w. when i tried to send my first text message it asked me to enter message centre number but i entered any random digits after that i cant send any msgs
I am unable to see new messages on my nokia 5230 until i go into the message center manually. How can i correct the settings so i will have an indicator to inform of new message
Mar 21, 2010 | Nokia 5230 Cell Phone
How to send messages on the surge
go to messaging settings, text message, messaging centers create a message center if it doesnt have SMS Settings listed name it SMS Settings and straight talks number is +13123149810 (Note: You have to keep the + sign at the beginning. that can be found by holding down the o key)
Oct 30, 2009 | Nokia 6790 Surge Cell Phone
I get a failed message when I try sending a text
It may the Message Centre has been set up incorrectly or changed from your service provider.
Check the number you have by going to Text/ Options/ Settings/ Message Centre.
If this isn't as it should be or changed - Check with your Mobile Network the correct number along with the prefix codes.
Jun 01, 2009 | Nokia N76 Cellular Phone
CANT SEND TEXT MESSAGES
I) if you want to send Text Messages or SMS messages go to SMS(where u normally send messages ) and then select Message Settings and then select Profile Settings and u will have two profiles(radio buttons) edit first profile(by pressing edit button) an then will get some settings to be made, u have to edit the number or phone number(if you are not sure about the number, contact ur customer care to get the number and enter it....)
Thanking you
M. Sridhar
Jan 08, 2009 | Dual Electronics CECT P168 Cellular Phone
Nokia 2100 Cellular Phone Logo
135 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
