Question about Brother MFC 9880 All-In-One Laser Printer
Mfc9880 machine error 71
First message "PLS CLOSE COVER"
followed by "MACHINE ERROR 71"
  • Anonymous May 18, 2009
    mfc9880 machine error 71
    Problem Solver:
  • 18 Answers
Error 71 is a problem with the polygon motor which is in the laser unit. This error usually means that you would need the laser unit replaced.
I'd suggest calling out an engineer.
Posted on Dec 12, 2008
    New Friend:
Nasty tech support, no straight answers, machine used very little, and keeps giving this errot message. Best solution: switch to a different brand. Brother is really s stinky brother-in-law!
Posted on Jul 21, 2015
I have brother DCP 7055 it shows print unable 71 error pls suggest
I have brother DCP 7055 it shows print unable 72 & some time it show 71 error pls suggest
Dec 18, 2012 | Brother Dcp-7055 Laser Print Copy Scan...
Faxing
How to clear the "Check Original " error message? Description: This error can occur if the document being sent or copied is not inserted properly, fed incorrectly or is too long. Follow the troubleshooting steps and recommendations listed below:
  1. Remove any paper that is not jammed from the ADF.
  2. Open the top cover by lifting the lever on the right side of the top cover.
  3. Pull the original toward the front of your fax machine.
  4. Close the top cover. Press down on both sides of the top cover until it clicks.
jam06.gifBefore placing the document(s) in the Automatic Document Feeder (ADF), verify the error message "CHECK ORIGINAL" no longer is displayed on the LCD. If the error message continues to appear on the display, unplug the unit for 30 seconds and then plug it back in.
Let me know if you need any further help
May 06, 2008 | Brother MFC-8440 All-In-One Laser Printer
Cover open pls close cover error machine 71
Check the rear door and make sure it is completely closed. Open and close a few times.
Feb 10, 2011 | Brother DCP 1400 All-In-One Laser Printer
Message 'Clean Sensor' has appeared. Followed advise to open Cover D and close it again but to no avail. Has anyone got any other suggestions, please?
Follow the steps below to clear the "Clean Sensor" error message.
  2. Slowly close the cover again. c2600_close_cover_d.jpg This action will move the lever shown below and clean the sensor.
  3. Open and close the cover several times. Once the front cover is left closed the printer will start to calibrate.
Once complete, the error should no longer appear and the printer should resume normal operation.
Note: If the error message is still apparent after following the steps above, contact Epson for further advice.
Nov 16, 2010 | Epson AcuLaser C2600N Printer
Brother MFC 9880 error 71
error 71 indicates problem with the laser unit motor.. 80% is the motor problem and 20% could be the LVPS board... make sure all the cover and interlock switch are close properly.. as any interlock switch which are not close properly will effect the voltage to the motor..
May 28, 2010 | Brother MFC 9880 All-In-One Laser Printer
Get error message pls close cover on a brother 4420c printer/scan
They will do this if the document feeder cover is not closed good. Make sure it is pushed all the way down.
Jun 16, 2009 | Brother Office Equipment & Supplies
DCP-1400 HAS ERROR MESSAGE "MACHINE ERROR 71" HOW DO I CORRECT THIS?
May 07, 2009 | Brother DCP 1400 All-In-One Laser Printer
Malfunction code C00 71
These codes are generally related to the toner motor, if you have changed the toner lately.Check the install of the toner cartridge, remove it and reinstall it, close up the machine and try again.
Hope this is of som help.
Ed
Apr 26, 2009 | Minolta Office Equipment & Supplies
Error mesage
No solution, but I have the same problem. THe printer starts up fine, I hear no grinding noises or other "funny" nioses, and then displays no error message... UNTIL I ask it to print. Then I get a message that says, "Pls (please) Open Cover".
I open the cover and it says "Please Close Cover".
I close the cover and it says, "Please Open Cover"
and this happens forever!
Does anyone have any ideas? Can anyone help me?
Stefan
Mar 05, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother Intellifax 2800
Pls open cover = Please open cover. Probaly has a jam - Open the cover remove the drum/toner unit and check for jammed piece of paper under of in the drum unit.
Jan 24, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother MFC 9880 All-In-One Laser Printer Logo
2,379 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
