Question about Maytag Neptune MAH5500B Front Load Washer
No Lights, Loud repetitve slow click, can't open door. Tried to start or stop. Lights flicker on and then off. Has just been sitting there clicking for about an hour now. Almost like it is turning slowly and something is hitting inside. I'm going to try unplugging. don't want to leave it like this. Don't know if there is water inside tub or not now.
  • 1 more comment
  • martha swaim Mar 29, 2007
    I took the door off because I wanted to reverse the direction it opens. I cleaned the door and the latch. The only thing I see that could be called terminals on my model are on the top center of the door and opening, so don't see why I needed to remove door to clean terminals. Maybe I have a different model or am I missing something?
    got door back on. "do" light went off when I closed door, but came on when washer started after beeping twice. This happened a couple of times. now can't even open door with green fishing line.
  • martha swaim Mar 30, 2007
    called repairman, paid $162.00 to get new door latch installed. works now.
I had same problem. But door locked and could not get it open. Turn off machine and used manual release (under dispenser- you have to take dispenser tray out with 4 screws) pull on green fishing line to open door). Took off door and cleaned terminals on door switch assembly. Replaced and now it works
Posted on Mar 24, 2007
Central locking making loud clicking sound
Try opening the door from the outside (or get someone else to do it for you) whilst sat in the car to see if it still does it. Then lift yourself off the seat and see if it stops. If it does stop whilst you are not sat down it may be a problem linked to the seat occupancy switch that activates when you sit down.
Oct 08, 2015 | 2006 Holden Barina
My laptop emachine g720 screen flickering
Laptop computers have LCD displays that are sensitive to many things. LCD displays have faults that sometimes produce a flickering screen, lines, dots or a faint display. These screens are sensitive to magnetic fields or electronic items near the computer. Speakers, cell phones, lights and other electrical items are examples. Your display also could be flickering due to software issues such as the video drivers or hardware issues relating to the inverter going bad or the LCD screen itself needing to be replaced. Trace the cause of your problem to come to a resolution.
1.Turn off the computer. Disconnect all external devices. Turn the computer over (bottom facing up). Take out the battery and reseat it. Turn the computer on.
2.Reset your resolution and refresh rate.
Windows XP:
Right click an open area on your desktop. Click "Properties" in the drop-down menu.
Click the "Advanced" button at the bottom of settings tab. Another dialog box appears. Click the "Monitor" tab. Change the Refresh rate to your default, or 60 hertz. Click "OK."
Windows Vista:
Click "Start, Control Panel." Find and click "Appearance and Personalization." Click "Adjust Screen Resolution." Change resolution to the default, or 800 x 600. Click "Advanced Settings." Click the "Monitor" tab. Change the refresh rate to the default, or 60 hertz. Click "OK."
Windows 7:
Click "Start, Control Panel." Find and click "Display" Click "Change display settings" on the left side. Change screen resolution to 800 x 600. Click "Advanced Settings" in the lower right. Click the "Monitor" tab. Change the refresh rate to 60 hertz. Click "OK."
3.Check the computer's surroundings. Move away any speakers, fluorescent lights, fans, cell phones, radios and any other electrical device that can cause flickering. Temporarily move electrical items away from the computer to see if they are producing this issue.
If the flicker stops, put back one item at a time to determine what is causing the problem.
4.Connect an external monitor to your laptop computer to see if that screen is also flickering. If there is no flicker, then the problem is strictly with the laptop, indicating a possible hardware failure. Contact the manufacturer for a replacement LCD.
If the flicker continues, go to next step.
5.Reset/Update your video driver. Click "Start" and right-click "My Computer." Click "Properties." The "System Properties" dialog box will appear.
6.Click "Device Manager." A list of items will appear. Click the (+) sign next to "Display Adapters."
7.Right-click the video adapter and click "Uninstall." Confirm removal. Restart the computer. The video driver will automatically reinstall itself.
8.Check to see if the flicker still exists. If so, go to the manufacturer's website. Download and install the newest video driver and BIOS for the computer.
9.Restart computer once drivers are installed. Continue to the next step if there is still flickering.
10.Open up your display screen all the way. If the flicker stops by opening it a certain distance, it is the display inverter. If the flicker still exists, the LCD screen should be replaced.
11.Contact the manufacturer of the computer for more information and a possible replacement inverter and LCD display. This will depend on the manufacturer and the computer itself.
I hope you find it very helpful. Thank you for using fixya.com
Aug 19, 2011 | Computers & Internet
The door opens when i push to open but when i push to close it starts to close until i stop pushing the button. When i release the button the garage door opens back and clicks 10 times
Check the door sensors. They must be pointed at one another and the small light on each one must be lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have either a bad sensor or the wiring to them is shorted or broken.
May 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
Recetnly purchased a used 2003 Suzuki Aerio from dealership. Car was running fine. Then suddenly would not start after being parked at work. The interior lights went dim when door opened, and battery...
i would say thats a good idea, if you got an extended warranty! from most of the symptoms i would say it sounded like your alternator was hooped. the clicking from the dash...if it's coming from the engine side it sould be your solinoid which clicks back and forth to open and close the circuit to send the signal for the started to crank when you turn the key. why it would be on when everythings is off and then shut off when you open the door i don't know. sorry i couldn't more (if any) help
May 01, 2010 | Suzuki Aerio Cars & Trucks
I have a Hot Point HSM25GFRF SA refrigerator, first the ice maker / water stopped working then the the refrigerator started making a clicking noise and every time it clicks the fsn does one rotation then...
I have the exact same problem.
It stopped dispensing water and ice, then it started to make a clicking noise and now the freezer and the refrigerator don't work.
It's interesting that this failure occurred 3 months after the 5 year warranty expiration.
Apr 13, 2010 | Hotpoint Refrigerators
The door opens when i push to open but when i push to close it starts to close until i stop pushing the button. when i release the button the garage door opens back and clicks 10 times
Check your door sensors. The need to be pointed at one another and make sure the small light on each one is lit and not flickering. Tweak them a bit. If you can't get both lights to come on one of your sensors has failed.
Mar 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Loud click when I press the start switch 1989 LS650 Savage
The loud click kinda indicates the starter is the problem. A fainter click would implicate the starter relay as the failing component.
Since I can't hear the noise, I would say first check the starter for 12 volts from hot to ground when the ignition is in start position. If you get 12 volts upon this test, then it's most likely the starter relay.
Then check the relay for continuity with starter disconnected from it and the ignition in start position. To find these components, just trace the red cable from the battery.
More info, let me know.
Charlie
P.S. The lights flicker because the battery voltage is dropping when the starter tries to turn over.
Aug 29, 2009 | 1996 Suzuki LS 650 Savage
My vehicle dies everytime I turn it off...
how old is your battery,have you tried a new one?Sometimes a really stuffed battery also interferes with the ECU,and can result in switching things on and off.
Dec 15, 2008 | 1994 Mercury Grand Marquis
Maytag Neptune MAH5500B Front Load Washer Logo
94 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
