Question about Brother MFC 9880 All-In-One Laser Printer
Brother mfc 9880 First message.... "Pls close cover" followed by... "machine error 71"
3 Suggested Answers
  • 18 Answers
SOURCE: mfc9880 machine error 71
error 71 is a problem with the polygon motor which is in the laser unit. This error usually means that you would need the laser unit replaced.
I'd suggest calling out an engineer.
Posted on Dec 12, 2008
  • 186 Answers
SOURCE: Brother MFC 9880 error 71
error 71 indicates problem with the laser unit motor.. 80% is the motor problem and 20% could be the LVPS board... make sure all the cover and interlock switch are close properly.. as any interlock switch which are not close properly will effect the voltage to the motor..
Posted on May 28, 2010
Print unable 71
Print Unable 71 means Polygon Mirror Failure on the Brother HL-4040, MFC-9840 and MFC-9440.
Pretty safe to say it means the same thing on the MFC-8880.
The Polygon Mirror is part of the Laser Unit, and its rpm isn't within specs.
The Laser Unit must be replaced.
Jan 08, 2015 | Brother MFC-8880DN Mono Multifunction...
My Brother MFC-8680dn keeps giving me a "Print Unable 72" error message. Any ideas how to fix?
According to Brother Solution Center:
The machine may not work properly because of the condensation inside of the machine caused by a temperature differential between the inside and the outside of the machine.
To clear the error message please follow the steps below:
  1. Keep the machine's power on and open the front cover.
  2. Leave the front cover open for 30 minutes.
  3. Close the front cover.
  4. Turn off the machine's power switch and turn it on again.
If you are satisfied, please rate or/and leave a testimonial. Thanks!
May 09, 2011 | Brother Office Equipment & Supplies
Cover open pls close cover error machine 71
Check the rear door and make sure it is completely closed. Open and close a few times.
Feb 10, 2011 | Brother DCP 1400 All-In-One Laser Printer
Back cover open message although cover is closed
Open the top and back covers. If you see any jammed paper or
other item, gently pull it out, then close the covers. If the error message
remains, open and close the covers again. If the FAX/MFC cannot reset
itself and return to the date and time prompt, it will display MACHINE
ERROR XX. Please call Brother Customer Service
and tell them the Machine Error number at:
In USA:
1-800-284-4329
In Canada:
1-800-853-6660
In Montreal:
1-514-685-6464
Jan 15, 2011 | Brother IntelliFax-2820 Laser Fax
May 28, 2010 | Brother MFC 9880 All-In-One Laser Printer
I GET A PLS OPEN COVER OFFLINE BUT NOTHING IS
I think the machine is telling you to look inside for a foreign object or scrap of paper:
1) Turn the machine OFF
2) Open the cover
3) Carefully inspect inside for a bit of torn paper, staple, paperclip or other such foreign object - gently clear any problem materials. Do not touch internal parts if possible. Use tweezers for small hard-to-grasp objects.
4) Close the cover, and power ON
5) If the MFC cannot reset itself, or if no foreign material is found, the machine should report an error code, for example "Machine Error XX"
6) From this code, brother support should be able to diagnose and help with your problem
Mar 11, 2010 | Brother MFC 8500 All-In-One Laser Printer
DCP-1400 HAS ERROR MESSAGE "MACHINE ERROR 71" HOW DO I CORRECT THIS?
May 07, 2009 | Brother DCP 1400 All-In-One Laser Printer
Brother MFC 8220 Error code 71
that code indicates that your laser unit has gone bad. no way to reset or repair without a tech replacing the laser unit itself.
razors
Mar 18, 2009 | Brother MFC-8220 Fax
Mfc9880 machine error 71
Dec 12, 2008 | Brother MFC 9880 All-In-One Laser Printer
Brother MFC 9880 All-In-One Laser Printer Logo
82 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
